In my infinite wisdom I decided to dismantle my right/rear X9 shifter. There was a purpose to this as I was replacing the gear cable. Unfortunately during said tricky operation I decided to fettle, stripping the shifter further and then was dragged away due to work (this is the problem working from home).
Anyhoo, I’m struggling to put the thing back together and could do with some help. The front cover is off as are the two springs. The thumb shifter is off also revealing spring and two random pieces of metal.
I’ve tried the LBS but the usual two mechanic heroes who save me from myself are not there. So, in order to correct this I need some sort of technical document (or link) that details the X9 internal components. The one on the SRAM website and subsequentlly the one I received with the shifters isn’t much use. Anyone?
