Home Forums Chat Forum Guitarists of Singletrack…
Viewing 40 posts - 1,481 through 1,520 (of 3,954 total)
  • Guitarists of Singletrack…
  • Edukator
    With a new set of strings and some contact cleaner spray you’ll get more than you paid for it in 97. postimage is the easiest way of posting pics I’ve found.
    Edukator
    The pictures aren’t very good quality but it looks like what you say, a barely used 97 Tele. The maple necks form that period are nice but the bridges I don’t like; individual saddles and non strung-through body, right? £300 – £400 I’d guess. It depends if there’s someone after that model.
    kirkg
    Could probably be doing with a clean and polish but these are hopefully better quality pictures.
    https://postimg.cc/gallery/06HYqs1
    Edukator
    Nice looking neck and body.
    I had one of those bridges, it had a 56mm string spacing as opposed to the vintage 52mm which put the strings too close to the edge of the neck to my taste, you can see in the pics. Those saddles also made paracitic buzzing noices on the E and A.
    I drilled a top loading body through but despite my best efforts made a mess of it. I tried drilling though with a very thin pilot drill but that bent and deviated as it went through, so I used a bigger drill and that shattered the varnish on the back when it went through despite tape and drilling onto a block.
    Someone out there in guitar nerd land will want it though. I’d hope for £300 having seen the better pics if it sounds as good as it looks.
    BigJohn
    I seem to have made a serious mistake.
    At the start of lockdown a year ago I just had my trusty old Norman acoustic, that I’d had set-up nicely a few years ago. I put new strings on it. Then, I bought myself a cheapy electric, thinking if I liked it, I’d buy something better in a while. I chose a Harley Benton, their PRS copy, with P90s for under £200. For Christmas I got myself a Boss Katana II 50w amp. Then, because I wasn’t enjoying the hum, I spent another £180 on a pair of Kent Armstrong noiseless P90s.
    So now I’ve got 2 guitars which play beautifully, look gorgeous, make all the sounds I’m after (I’m currently playing along to Marfa Lights by Steelism and the Tele-like twang I’m getting is just beautiful) and make me want to pick them up and play them every time I walk past.
    So, there’s my problem: I’ve got a bunch of no-name kit, I keep lusting after all sorts of beautiful guitars which I know would cost a fortune but wouldn’t improve my enjoyment, my sound or my playing.
    What do I do? Stage a break-in or set the house on fire?
    kirkg
    Cheers Edukator.
    oldtennisshoes
    What do I do?
    Convince yourself that guitars hold their money, are actually investment and then start browsing custom shop stuff on guitarguitar.
    Your welcome 😀
    BigJohn
    Of course! The Captain Anderton Paradox: if you can’t afford a £500 guitar then you’d be better off buying a £2,000 one.
    rickon
    Hey,
    I’ve played for about 30 years, but I basically stopped for the last 10. I’ve rediscovered playing since lockdown.
    I’ve got a Les Paul Special with p90s and an ES-339, which is just for noodling at home playing blues and 50s/60s rock. No gigging!
    I’ve got a wee Sub Zero 15w practice amp, but want something nicer for clean, warm and fat tones.
    I’m thinking a small valve amp would fit the bill. I don’t want to spend more than £200, which limits my options!
    On the list at the moment are the SubZero Valve 5 or 10, Vox AV15, Vox VT20.
    What else do you think I should be considering?
    Ricks
    twinw4ll
    What do I do? Practice.
    supersessions9-2
    I’ve got a Laney cub 12r. It’s great, fantastic edge of break up tones. Sub 1w input for home volume levels. Got mine second hand for 150.
    Newer super cub looks and sounds really good on the social media feeds.
    rickon
    I spent last night deep in research. I think ideal would be a Yamaha THR10ii, but it’s just too spendy. The THR5 looks like it should fit the bill, my only concern is whether or not it would sound warm and bassy, or a little treble heavy with such a small unit?
    AdamT
    I play my 5 string bass through my thr10 occasionally (there’s a setting for this, so they do expect it). It’s surprisingly capable. I also find it amazing how such small boxes can make such a big sound. I would have thought the thr5 would be pretty similar albeit with slightly less stereo separation due to get drivers being closer together.
    chipps
    @rickon – I vote for a used Epiphone Valve Junior – it’s a loud 5W 8in combo (that can power a 4×12…) and it has volume and, er, that’s it. Turn it up and it gets crunchy… Simple, light and small and they seem to go for £100 or so s/h. Or the Marshall Origin 5? Blackstar HT-5? Both out there for under £200
    Or go digital and get the Yamaha THR or a Katana.
    eddiebaby
    Well I ought to sell my THR the amount of use it has had this week. Had to bail into a concrete roundabout on the road at the weekend thanks to a blind driver. My fingerless gloves protected my palms but my thumbs are a bit torn up by glass and thorns. Can’t fingerpick at the best of times but this makes it worse.
    With a plaster on I can’t grip a plectrum and without I cover the guitar in blood.
    Grrr.
    rickon
    Well, I ended up with a Vox Odio Air GT – catchy name!
    Very similar idea to the THR10, just a more warm sound.
    Sounds lovely through the p90s on my Les Paul Special, with it set to AC30 tube with a little gain and spring reverb.
    eddiebaby
    Schwiiiing!
    rickon
    I should have really shared a photo.
    Some folk say it looks like a Chanel handbag. I think it looks a bit future-retro cool.
    Many dials and knobs.
    eddiebaby
    They are right, you are wrong. How it sounds though is the main thing and the reviews are impressive. Looks are unimportant. Obviously we will of course still be calling you Cardi B from now on.
    guitarhero
    Still on the lookout for a ‘nice’ guitar for my 50th. Dreams of a 2nd hand PJE Macon special/jnr are evaporating as there is slim pickings at the moment.
    Currently being drawn to the Suhr Alt-T which despite not originally wanting to go down the tele route as my Crimson Descendant covers that base, the dual humbuckers on the Alt-T seems like a pretty versatile setup. Plus it’s stunning!!!!
    null
    eddiebaby
    That is rather nice. I’d kill for a Suhr Strat only ever seen on Suhr in the flesh and it was immaculate.
    supersessions9-2
    Proud dad moment as my son got the results for his rock school grade 3 exam this week and scored a merit. Really chuffed. He’s only 11 and has worked really hard.
    We had a deal that he’d get a new guitar when he did this as he has grown out of the 3/4 squire strat he’s got. Budget is based on his results and I’m pleased to say it’s costing me!
    I think a trip to the guitar shops is planned this weekend.
    He’s got his eye on a schecter or an ibanez.
    Ro5ey
    Great news, congrats to your young shredder.
    I never had any musical instruments in my house when growing up, one of the reason I started playing 10 years ago was so that a guitar would be available to my kids when they wanted it.
    Sadly that’s not happened yet, although my lad did show some interest the other day. I’m not going to force it, even if I have told him “no girl is ever going to be impressed that you are good at XBOX… twiddle your fingers on the guitar !! “
    eddiebaby
    Times have moved on sadly. The ladies appreciate a game.
    supersessions9-2
    Ha ha. I said this to him the other day that when he’s older and he wants to ask a girl out, is she more likely to be interested if she’s asked to come and see you play Minecraft or come and see your band?
    theotherjonv
    rickon
    Lol.
    Had a good few hours of programming, and it’s incredibly impressive. Some substantial sounds from this wee thing. The ‘wide’ mode that creates a bigger soundstage is pretty amazing.
    Definitely a recommended purchase. And Korg are selling brand new refurbs with full warranty for £180.
    yourguitarhero
    As far as 2H Teles go, I had this Charvel for a while:
    Loved it, but had to sell one guitar due to poverty… I do miss it.
    As far as thinlines go, I always liked the Gibson Midtown – Pelham Blue
    IdleJon
    Proud dad moment as…
    I had small proud moment a couple of nights ago. Me on acoustic and 10 yr old daughetr on cheapo uke playing Basket Case by Green Day, with her singing* reasonably tunelessly but getting roughly in time. I looked up to find that my 17yr old daughter and wife had stopped what they were doing to form an audience. Eldest walked away saying ‘That’s cool!’
    * she stopped singing at the line ‘She says it lack of sex’. 😀
    Edukator
    I love that chord in Basket Case: the E power chord open E, B, E, B, open B, open e = rarrrhh.
    I was messing with a Vox Amplug into a home stereo in this vid which doesn’t do it justice but it’s there at 1:50: “now I gotta hoang on” rarrrrhh. My twim humbucker Tele obviously as that’s the theme today.
    rarrrh
    rickon
    Hey!
    After restarting playing 12 months ago, after a hiatus, I’ve gone back into song writing again.
    I’ve played for about 30 years, but I’ve never had any classic training.
    I’m an OK player, played in a few bands.
    I feel like I’d benefit from doing some kind of training, just to expand my repertoire.
    I’ve had a look at Fender’s app training, but I’d there anything you guys would recommend having a look at?
    I use the Melodics software to practice my keys/piano playing. Would be nice to find something similar for guitar.
    oldtennisshoes
    Anyone got a set of the BOSS Waza-Air Wireless Guitar Amp Headphones?
    https://www.bax-shop.co.uk/headphone-practice-amp/boss-waza-air-wireless-personal-guitar-amplification-system-headphones
    I hate wires and these look like a good solution for quiet practice. I may need to try a pair next week.
    joelowden
    Here’s my boy with his band . He’s on Lead guitar and various vocals.
    Fingers crossed…..
    oldtennisshoes
    @joelowden that’s great 👍
    joelowden
    Cheers 👍👍
    eddiebaby
    Yup. Liked that as well.
    eddiebaby
    Due to a long planned move I’m getting rid of a lot of duplicate stuff in my life and sitting on the pile is my THR10 so it is over in the classifieds.
    guitarhero
    This may divide opinion but jumped on this Patrick James Eggle Macon Special Gold Top. Excited doesn’t cover it
    Imgur link
    AdamT
    Ooof. That’s lovely.
