Home Forums Chat Forum Grouse moor licencing, Scotland.
Viewing 40 posts - 641 through 680 (of 809 total)
  • Grouse moor licencing, Scotland.
  • highlandman
    There should be dozens of different habitat types, blending, mixing, varying and rubbing shoulders. That’s the way that biodiversity increases. Look at the work now being done to replant willow species into the Loch Avon basin, restoring the high altitude scrub woodland that used to be common above 600m across the Highlands. Higher up, tundra species of plants supporting vertebrate and invertebrates; just around the corner, Scots pine woods, with a new understorey developing rapidly as species spread naturally into the developing system.
    Grouse and wader populations will survive and if some have to diminish in order to restore the wider range of land to greater diversity and help with carbon capture, fine.
    It’s worth remembering that ‘natural’ is a temporary term; after all, much of this land was buried under a kilometre or more of ice, not so very long ago.
    tjagain
    That is a huge can of worms to open Vlad.  Rewilding yes – but to what?
    this is just from a poor memory and knowledge – others perhaps know a lot more
    Post ice age it was taiga forest I think – so scattered birch and pine on impoverished thin soils.  10 000 years ago
    As things warmed up and trees grew ( In most of scotland – not all) more diversity of trees and denser forest. 5000 years ago
    then humans arrived they started cutting the trees down.  so even 5000 years ago humans where altering the landscape.    also at this sort of time the peat stated developing – so human were hear and altering the landscape before the peat developed
    1000 years ago a lot of the trees would have gone from valley bottoms but still be on the hillsides, Then came the highland clearances and any remaining trees over large areas were removed for sheep grazing and deer farming for shooting  200 years ago ish?
    You will have seen in many areas that in the peat you can see the stumps of the trees cut down during the clearances
    for me rewilding should be going back to the pre clearance landscape / level of tree cover.  We can hardly remove the peat and go back to Taiga
    Heather should also be much deeper and longer than it is.  in “Kidnapped” the hero hides in the heather in Glencoe.  Yo couldn’t do that now – its only a foot or so high
    Some areas would be temperate rain forest – differnt areas would have differnt flora and fauna
    Modern day highlands are a man made landscape of sheep, deer and grouse farms with impoverished biodiversity
    futonrivercrossing
    Rewinding is just that, letting nature get on with it and sort out what works.
    tjagain
    do that in much of scotland there will be no native trees, vast overpopulation of deer and a denuded over grazed landscape.  Large areas have no native trees to regenerate from.  Deer without predators the population will explode and over graze the land
    matt_outandabout
    I’ll take the most important one first:
    And, more to the point, would eradicating grouse moors dramatically reduce the number of midges? 😄
    Having spent time in Atlantic rain forests, the answer is ‘no’… 🙁
    Although there is little evidence of the scourge of the midge in historic writings and records. So either we’re nesh of there were fewer midges.
    vlad_the_invader
    Thanks TJ
    I was always under the impression that the clearances were clearing people, not trees (though I guess that’s secondary to make the landscape suitable for sheep farming). I also believed that a large swathe of British trees were felled for military purposes during WW1. Is that an urban myth, or maybe most of Scotland was already bare of trees…
    matt_outandabout
    Except our currently changing climate and the damage over the last 200-300 years is so deep and damaging it needs our intervention. An example – there are many valleys without the few ‘granny’ trees to supply seed. Therefore we need to plant those trees, reduce deer numbers so they don’t eat the new trees, manage rabbits, re-seed understory and montane plants (etc etc). I believe RSPB at Abernethy have a 1000 year management plan…!
    matt_outandabout
    The growth of sheep and other more intensive farming precipitated a huge change in people and environment.
    This is true, and partly led to the formation of Forestry Commission.
    tjagain
    The highland clearances does refer to clearing people off the land.  the landowners did then remove a lot of the remaining trees to provide more grazing f for sheep I think.
    ratherbeintobago
    This is the biggie – but how. Can’t realistically bring back wolves, by all accounts even serious culling isn’t getting the numbers down (and the carcasses are valueless as supply exceeds demand), introduced disease is problematic…
    matt_outandabout
    Just a lot, lot more culling of numbers over probably a couple of decades.
    tjagain
    Feshie estate just shot every deer on the estate IIRC.  Others have reduced numbers to sustainable levels by culling
    no real logistical issue to do a big cull.
    thestabiliser
    Not really, rewilding is about getting stuff back to roughly the end of the last ice age. People think that means boreal and deciduous forest but there were a lot of large ungulates that kept signifcant grasslands, heath and open moor as well as climax community forest. Most of the mega fauna from that period are now extinct so primitive breeds of cattle, horses and deer are used as proxies in larger scemes.
    dissonance
    When did Grouse moors become a thing?
    The driven grouse moors are a Victorian invention which was when it became convenient to catch the train to a remote area for a bit of shooting fun. Since grouse cant be reared in captivity (not commercially anyway) it needs very heavy intervention both in terms of killing predators or anything else which might look at grouse in a funny way (eg mountain hares) and in terms of burning the heather back to ensure there is always patches at different stage of the heather lifecycle to suit the grouse.
    And what was the landscape like prior to this?
    The highlands would have been Scots pine (if you ever go to Glenmore lodge take a walk out in the woods behind it to get an idea of what they are like) and the lowlands more oak etc.
    They were put under pressure way before the grouse moors due to normal agriculture both clearing for crops and also sheep grazing higher up plus the need for fuel (making iron for example uses a lot of wood).
    As with the rest of the UK I think its uncertain when exactly most of the woodlands got cleared with quite a lot possibly happening when people returned after the ice age especially in areas which were already under stress from the climate change even a fairly small impact from people could quickly clear it.
    squirrelking
    I did beating at Invergeldie one summer back in my student days. 3 weeks, the second was spent digging gravel pits as there weren’t enough grouse. No jobs the next year or the year after and probably the year after that. I wouldn’t be surprised if it was on its arse anyway hence being happy to sell, we haven’t had any decent winters in years.
    dovebiker
    Deer numbers need to be reduced significantly if there’s to be any chance of rewilding the landscape – they do and will eat anything. They had a ballot to cull the deer on an estate on one of the Uists, but it was rejected, particularly by those with an interest in tourism. As well as Scots Pine, native trees include oak, birch, hazel and poplar – there are still some native temperate rainforest areas in some coastal areas, often where the ground is too steep for it to have been cultivated. What there wasn’t was large stands of monoculture Sitka spruce, larch and pine planted so dense that the light doesn’t reach the ground that barely anything grows or lives there – much of it planted post WW2 by the Forestry Commission to create jobs, and now clear-felled to create what can be best described as post-industrial landscape totally devoid of anything that’s going to take decades to regrow.
    scotroutes
    Unfortunately very few estates are undertaking “serious culling” and in many areas the red deer population is still more than double the sustainable level. As TJ mentions, Glen Feshie estate has a zero tolerance approach and will despatch a shooter as soon as a deer is seen. Of course they are still wandering in from other estates, hence the frequent intervention.
    Feshie is a bit of a poster boy for what can be achieved. There’s very little planting going on and the growth in the glen is all just being allowed to happen.
    Conversely, the Brewdog-owned Kinrara Estate is being fenced ready for intensive planting of native species. This is partly because it was previously a grouse moor and so there are few native plants able to begin recolonisation. However, by fencing it off, they are encouraging the red deer to migrate into areas where successful regeneration is already happening. Once again, the answer isn’t more fences, it’s fewer deer
    squirrelking
    Ah but ‘shooting bad’.
    I know nobody here is saying that but a lot of people outside do. People have a massive issue with guns and hunting in this country from poor associations with the US and just general ignorance. As said, once you get deer down to manageable numbers you could licence the hunting but that would probably be quite unpopular amongst those who wouldn’t take part.
    The shooting community often doesn’t help itself either with vocal absolutists amongst their numbers who will defend anything with a slippery slope argument. Again, these people need to get on board and the BASC and SACS (and all organisations tbh) need to start encouraging their members to act in a more thoughtful manner.
    1
    tjagain
    Not just thoughtful but not illegal.   Those organisations are part of the criminal conspiracy
    I have no moral issue with deer stalking.  Nor really with walk up bird shooting.  Its the driven grouse moors that are a criminal conspiracy and they are protected by those organisations
    ratherbeintobago
    I think the Norwegians offer variable numbers of deer hunting permits depending on the population size and health – more deer, more permits.
    From an animal welfare POV we have too many deer, even with our the overgrazing.
    dissonance
    It can have similar issues to driven grouse moors. In order to ensure some targets for customers on certain estates numbers are kept way higher than they should be.
    tjagain
    Thats not a moral issue tho – thats a environmental one.
    futonrivercrossing
    this is what I was trying to say, somewhat clumsily.
    Introducing locally extinct species, such as Bison in Kent, and letting nature take its course. Trying to return a landscape to some previous condition, 5000 or 10000 or whatever years ago is futile. Increasing biodiversity in our depleted ecosystem is the aim. Shelling hunting dear as a sustainable ecological benefit might be the way to go?
    ratherbeintobago
    @dissonance I thought that was a reason why some estates are against adequate culling (and as above the end result is that animal health is suffering as the population is too large, never mind the overgrazing)?
    scotroutes
    Yep. And the “value” of an estate is often determined by the number of deer shot annually. Make them scarcer and the poor shooters will actually have to walk around a bit in order to find their targets. That leaves less time for champers and dinner. 😂
    tjagain
    Futonrivercrossing
    Feshie had grandmother trees to reseed the woodlands.  Some valley systems do not – so even if all the deer are culled no native trees will grow because there is no seed source
    highlandman
    TJ’s right; the presence of grandmother trees in Feshie isn’t just about those individual trees themselves, it’s also an indicator for the whole range of associated species having survived there alongside those few ancient trees. So the ecosystem there still contains the fungi, bacteria, invertebrates and most other elements of the system. This means that the forest restoration and tree regrowth is really rapid; trees never do as well unless their whole support system is present. They need those other organisms, forms of life for access to nutrients, for ‘soil health’, for want of a better expression.
    Just planting scots pine or birch out onto a depleted moor will be desperately slow until many of those support species are also present or introduced. That’s what a broad ecosystem should contain and helps all of the species to thrive, not just the totem pole, visible apex plant species. Oak will always do better when it expands its range (or is planted) into ground that previously hosted birch, for example. Rapid birch and willow growth creates shelter and begins the process of creating the organic biomass, the loam that lots of other species want to live in. This isn’t rocket science; I was taught this in my first year botany course at uni, 40 years ago..
    franksinatra
    So rewilding is tough. but that doesn’t mean it shouldn’t be tried and it has to be better than the wildlife desert of a driven grouse moor.
    futonrivercrossing
    Happy to learn things about this stuff 👍😁 – fascinating, really.
    highlandman
    Some more positive news, for anyone who hasn’t come across this yet:
    https://treesforlife.org.uk/dundreggan/
    The location is a bit of a diversion off a Badger Divide/Great Glen Way ride but is almost bang on the route for anyone doing a relaxed HT550, a Great North Trail mission or anything similar. Or you’re driving to or from Skye, Torridon etc. I’m told that the cafe at the new centre is well worth a visit.
    matt_outandabout
    Pippin
    I have just read the piece by Nick Kempe posted by scotroutes. Given that I am fully aware of the rationale behind the trial, and of the challenges of pinewood regeneration in a core pinewood area, I can only say that I wish he had actually come and ask questions before throwing stones.
    matt_outandabout
    That seems Nick Kempe’s approach to lots in his articles.
    Another related tweet. Too many deer and sheep = this would not happen.
    highlandman
    I can recommend Andrew Painting’s book ‘Regeneration’ for anyone who fancies a bit of bed time reading on this subject. Lots of interesting worked examples from around the Mar Lodge estate. He’s not claiming to be perfect or to have all of the answers but has certainly participated in a lot of good, on a very large estate that is next door to Feshie and is leaning on Invercauld.. Quite a contrast.
    1
    matt_outandabout
    matt_outandabout
    Interesting. I listened to a radio 4 piece which suggested that released birds were the dominant vector for avian flu, due to there being so many in such a small space.
    https://amp.theguardian.com/world/2023/may/18/rspb-calls-for-suspension-of-game-bird-releases-over-avian-flu-fears
    Jamz
    55 million game birds reared each year to be shot – what an insane activity. How big is the carbon footprint? How much de-rainforested land is used to grow the feed? How much damage to the local ecosystems? And all just for a brief buzz when the trigger is pulled, nothing achieved at all.
    1
    franksinatra
    Yep, but don’t forget that they are guardians of the countryside and there are a few more curlews because of grouse moors…..(also more fires, less peat, fewer raptors, restricted access, little in the way of native flora and fauna, massive vehicle tracks across the country, lead shot everywhere, straightened waterways etc etc etc etc)
    1
    matt_outandabout
