Home Forums Bike Forum glentress black on your own
  • This topic has 45 replies, 22 voices, and was last updated 12 years ago by br.
Viewing 40 posts - 1 through 40 (of 46 total)
  • glentress black on your own
  • richieokeefe1
    just wondered how extreme the black is at glentress ? going up with family so a couple of days I will be going there on my own but just wondered how bad the black is ? I will be also doing the blue and red runs
    cheers
    Rich
    radoggair
    its pretty easy if your a capable rider. No jumps etc, technically its pretty o.k. You go up, then you come down. Pretty simple really. From the top to the bottom if things do go bad then your never far from rescue ( about 3 miles or so)
    the_lecht_rocks
    not a problem – i ride it solo mostly.
    richieokeefe1
    ah cheers guys just what I wanted to hear 🙂 I have been to wales quite abit and the peaks but never to scotland and wondered what there black grading is like 🙂 I take it its well sign posted around the trail 🙂
    kimbers
    it can feel a bit long and lonely on your own, which is really nice!
    edit signage is great
    theres nothing too technical on it, you can even take a signed shortcut back at some point if its too long for u, iirc
    iain1775
    Black for its length rather than technicality
    Northwind
    It’s not all that black tbh, honestly I reckon if it were opened today it’d be red. There’s a couple of short sections at the end (the bitch, wormhole and double x) that raise the difficulty but they’re right in beside the red route, and so relatively busy.
    It’s lovely though… Very wet in places just now, needs a wee bit of drainage fettling I reckon, but it has a fairly “out there” feel which still in reality being pretty compact and not too far out. Do take a map, though, as the bailouts aren’t always that obvious.
    d45yth
    To be honest the Black isn’t that good. Do Innerleithen and then go and do the red at Glentress…much better!
    athgray
    I think the black is good. The climb is interesting and long without being technical. Britney Spears and Deliverance are good descents. Redemption can be a ball ache though. I tend to do the black on my own but stray onto the red instead of Double X and the Bitch.
    Mackem
    Did it by myself last year, in the sodding rain. I’m no trail God and had few problems. Proper mountain bike ride though.
    raisinhat
    The black is just draggy, and the climb has absolutely no redeeming qualities at all. Deliverance is fun, and there’s a few odd little bits of descent that actually offer a challenge, but it’s mostly just not worth the effort.
    Go do the innerleithen red – an actually interesting climb with enough techy bits to keep it challenging, and a descent that rewards you for the climbing effort. Then if you still fancy riding do the red at glentress, far more reward for your effort.
    richieokeefe1
    when you say in length how long is it ? on the website it says 29 km , is that correct ?
    OmarLittle
    I’m pretty shit technically and find it quite a bit harder than the red overall particularly towards the end. With the red i can do all the features, dont really need to think about anything but on the black there are some bits (like the rock garden at the start of the wormhole) that i struggle on and dont particularly enjoy riding.
    However despite that as an overall trail i like it and continue going back for more as it is usually very quiet and i wont see or hear anyone else for a couple of hours – it gives you a feeling of being a bit out on your lonesome, unlike the red where you are never far from someone else.
    raisinhat
    It’s just under twenty miles, but it feels like it goes up and down the hill twice, so you end up riding for quite a long time grinding up dull climbs.
    richieokeefe1
    I see maybe do the the inertheithen instead ….im staying there so might give that a go …whats the verdict on this trail ?
    nick1962
    Do it on my own too regularly and not tricky at all with no big surprises.IMHO to get the most out of it you need to know when to hammer it and when to pace yourself,which unfortunately usually only comes with having done it.Britney,Boundary trail and Deliverance hammer it but make sure you’ve got plenty of air in your back tyre as a puncture on Deliverance can spoil things-watch those stream crossings.If you plod/mince it may appear dull.There’s plenty of time for plodding on the rest of the trail! Don’t look too far forward/upward on the Tower ride climb and get a low gear you can keep on spinning in esp.if wet. Pace yourself on Redemption and once you get to the switchbacks you’ve cracked it.And make sure you take the black choices rather than red when you rejoin the main trails if you like technical stuff. The Bitch(despite the name) is one of my fave bits just wish it went on longer as it’s over in a couple of minutes.
    Most people mix red ,black and blue to suit.
    d45yth
    richieokeefe1 – Member
    Do it! It’s better than Glentress. If you’re staying in Innerleithen you can just bike across the bridge to the forest too.
    legend
    The black isn’t good enough for some, so they recommend Inners instead……really??!! There’s far more to the GT black than Inners in my book. Inners is just a long slog up with trail-centre-by-numbers trails back down, and if riding solo you’ll do it in no time whatsoever. At least you feel like you’ve done something and had some decent riding on the black
    Northwind
    Innerleithen’s good too, not so much better or worse as different. GT black has a more laid back, slightly backcountry feel, Innerleithen is more your incredibly manmade, gravel path + features sort of trail. Some standout bits and a pretty interesting climb, but a bit lacking in variety if you only do the red. (and where does the altitude go? You pedal as much on the descents as the climbs)
    Anyway- if you’ve got time do ’em all. Otherwise do the ones that ticks your boxes. I don’t think anyone rides these trails once and complains, I’ve ended up a bit less impressed with innerleithen than I used to be but it took a few goes before it wore thin. Doubt you’ll have a bad ride at any of em.
    thisisnotaspoon
    It’s pretty tame, more techy than the red, but then I think the red is pretty straight foreward. The whole center seems designed to be ridden on sight with no suprises so when I a lot of it of it twice in a weekend I wasnt actualy any faster 2nd time through.
    And I’m unfit but reckon it was twenty ‘easy’ miles, some places like the Lakes 20 would leave me dead, GT isn’t one of them, I did the red and black back to back with no issues. Innerleithern’s worth doing too, it’s easy to do the black, then the red on one day, then do the blue and add spooky wood onto the top, then turn off and do the blue decednts again, and even then the climbs are fairly short so you could double back and ride any you fancy. Then do Innerleithen red in the afternoon, but be aware the climb is a killer. It’s ridiculously steep for the first few miles, then suddenly flattens out and becomes quite fast for the 2nd half. The decent is cracking though.
    jonba
    Innerliethen is really short – not a days ride unless you do some of the down hill runs as well.
    The black is fine if your a fit rider*, the uphills really aren’t that hard and there is plenty of entertaining down – its a bit less bmx track than the rest of Glentres. If you look at the map it is really easy to do the black to redemption and then join the red back up to the top of spooky wood and do that as well. Might even be worth splitting from the red on the way back to take in the blue bits like berm baby berm.
    If you want, berms, jumps and smoothness then GT red and blue. If you want way marked fun “natural” riding then the black.
    *If you are genuinely fit then you can ride most of the red blue and black at GT comfortably in a day. GT Black, Innerliethen, GT red combined is about 40 miles if you ride between them.
    d45yth
    legend – Member
    The black isn’t good enough for some, so they recommend Inners instead + the red at Glentress too!
    We used to do Inners, go and have something to eat at Glentress and then do the red there plus a bit of the blue. We used to do it that way round so we could either have a shower if it was muddy or play around on the freeride park to put a few more hours in.
    For anyone who hasn’t been to Innerleithen, there’s just a car park with a portaloo.
    d45yth
    thisisnotaspoon – Then do Innerleithen red in the afternoon, but be aware the climb is a killer. It’s ridiculously steep for the first few miles
    ??? The climb just moseys away, it does go on for a bit though. The climbs at Glentress are worse, especially the one to the tower on the black.
    cynic-al
    d45yth – Member
    Both wrong…the first bit is steep switchbacks going by the DH tracks, then mellows, up/downs, then up to the top.
    legend
    cynic-al – Member
    Alternatively, when going up the first bridleway, completely ignore the sign pointing you up the trail to the left (shitty rock steppy section) continue for 50 yards, join the fireroad, arrive at quarry after a few hundred yards and continue on knowing that you’ve just skipped the boring meandering bits 🙂
    d45yth
    Whatever cynic-al. None of it can be classed as steep.
    thisisnotaspoon
    Spot the difference between those two statements?
    naa, that climb’s over and done with in a couple of minutes? The hill before that’s harder work (upto the shelter), but even that’s rideable in the middle ring. The bit past the DH tracks at inners is a granny ring winch that seems to go on for ever (then it levels out, demoralizes you over the steps, then flattens out, goes along the fire road, and from then onwards is actually quite an enjoyable spin to the top.
    athgray
    The start to the climb at Innerleithen isn’t steep but you do get into it straight from the car park. This means you are not yet into a rhythm when getting to the rocky bits.
    druidh
    bridleway? 🙄
    ChrisL
    If Spooky Wood is your absolute, no questions, most favourite bit of the red and you often just ride straight up the fire roads to get to it, then you’ll probably not appreciate the black too much. If you like the narrower, wigglier bits of the red and can cope with a rougher trail surface and longer climbs then there’s much to enjoy on the black.
    legend
    druidh – Member
    legend »
    bridleway?
    Call it whatever then, it aint singletrack and it isn’t a fire road so whatever boring description is in-between
    Northwind
    druidh – Member
    bridleway?
    Everyone calls it that, don’t know why… But a bridleway doesn’t have to be an english approved-for-traffic style bridleway, it can just be an old horse track.
    Not that I approve of skipping bits of interesting climbing in order to ride up boring forestry road, regardless of whether it’s a bridleway or not 😉 Let alone skipping a whole climb and descent and riding straight to the quarry. Why not just ride once round the carpark and go home?
    nick1962
    Don’t know how I ever make it up Inners or get round GT black for that matter running 1×9 and those who I saw on rigid SS well….. 🙂
    br
    I regularly ride both Inners and GT, all trails – and enjoy them all. Black is pretty satisfying.
    Is GT Black ok for a solo? Sure, but if you do crock yourself just beware that its not that highly used and you may have a wait for help – and there are many mobile dead-spots.
    Inners is good fun, but its basically 6 miles of climbing then 6 miles of descent – up/down in 2 hours at the most.
    rOcKeTdOg
    the descent off minch moor is well worth the effort to get up there
    legend
    Not that I approve of skipping bits of interesting climbing in order to ride up boring forestry road, regardless of whether it’s a bridleway or not Let alone skipping a whole climb and descent and riding straight to the quarry. Why not just ride once round the carpark and go home?
    Wrong quarry. It takes you to the quarry you go through on the way up, not the way down
    glupton1976
    The minch moor climb makes for a belter of a descent at 3am on a monday morning in january when there is a full moon. Makes you realise just how long the climb is.
    He means the quarry with the big bombhole like feature with a choice of two chutes after it, or one before it. There is a descent into that, albeit a short one.
    Northwind
    legend – Member
    Er, what are you talking about? It takes you to the quarry at the end of the taniel hill descent- so as I said, skips a whole climb and descent 😕 it’s not like it’s a long route so why cut bits off?
    thisisnotaspoon
    I feel slightly inadequate now only manged it on 1×10……………
    Besides, I said inners was a granny ring slog, not GT, although I manged that 1×10 too, but it wasn’t pretty.
    athgray
    Is it possible to take a route avoiding the rocky steps low down but still come in above the quarry, as I like the descent to it on Taniel Hill?
The topic ‘glentress black on your own’ is closed to new replies.
