Home Forums Bike Forum Gear ratio help
  • This topic has 2 replies, 2 voices, and was last updated 10 years ago by AD.
Viewing 3 posts - 1 through 3 (of 3 total)
  • Gear ratio help
  • larrythelathe
    Hi this doing my head in trying to work this out!
    If I have a32 tooth cranks and a 34 tooth cassette running 650b what front ratio would I need to achieve the same with 29er wheels.
    Also would I be right in saying you would need to put more force in when spinning up 29ers due to the increased lever?
    dpfr
    Either 32 front/36 rear or 30 front/34 rear would get close I think.
    AD
    Have a look on here… http://sheldonbrown.com/gears
    I think it’ll help – though I suspect dpfr is probably right!
The topic ‘Gear ratio help’ is closed to new replies.
