Evening.
Hopefully somebody far more knowledgeable than myself can help me with diagnosing and offering a solution for an air-leak from my Fox Float R 140mm forks.
I noticed the day after a ride that my forks had lost all pressure and there was fluid around the air-cap on the left upper tube.
I inflated the forks back to my usual 70 PSI but it immediately began losing pressure with the sound of air hissing out accompanied by some pockets of bubbles forming where the air cap meets the steerer assembly.
I’m hoping that it is something as simple as the upper air-seal has pinched and failed or perhaps the air-cap is slightly loose which is weeping air & fluid under pressure.
Has anybody else experienced this issue or would you agree that the seal/cap is likely to be at fault? Or something more concerning! 😐
As soon as I get the nod from you guys I’ll order a 26mm socket, seal and float fluid pillow.
I appreciate you taking the time to reply.
