DIY "steerstopper" ...
DIY "steerstopper" ? help me with ideas
26 Users
3 Reactions
For those that aren't aware the steerstopper is a lovely bit of kit for loaded touring , lifting bikes over stuff and maintenance duties . It's designed to properly stop the steering moving and lock the front wheel in line with the frame . I'll put some images below .
Basically ..yes it's unneccesary and heavy and rather bling but I like the idea and fancy something similar . I would order from the states but they are already expensive before you add the cost of shipping, taxes, courier charges etc and the exchange rate makes it worse ....SO
I'd like to make something similar ..perhaps modifying cheaper and readily available bits and pieces so am looking for ideas, ingenuity and suggestions.
I'm well aware of all the simpler options like straps, bungees, the old rhode gear flikstand etc but would like to replicate this design or something similar . Perhaps that is seen as poor form ...I'm unsure but I can't afford one and not intending to copy and sell ...it's just for personal use. I have had a few ideas but could the STW hive mind collaborate on designing an easily made , relatively cheap idea ?
The other option is to drill a hole through the head tube and steerer and use a locking pin . This has been done before but may need reinforcement of the head tube which could be more costly and I'm unsure if a diy attempt would be a bad idea and possibly dangerous ? link and photos below . Cheers Bill
steerstopper website
unlockedlocked
parts
another way
Posted : 09/07/2022 10:32 am
with regards to the final photo with the pin ... If I can't fabricate a steerstopper alternative I may go down this route but wondered what people think . I just had an idea of drilling the headtube and inserting two rivnuts to protect the tube itself . In addition to the ideas for the DIY steerstopper perhaps those in the know could advise/comment . Thanks in advance .
Posted : 09/07/2022 10:40 am
That looks great, I’m always looking for new things to smash my testicles into.
Posted : 09/07/2022 11:00 am
What about modifying a pin spanner? A quick google says wiggle sell a park one for £11 so not much outlay if it doesn’t work
Posted : 09/07/2022 11:04 am
A solution in seach of a problem? Not something I have ever needed
Posted : 09/07/2022 11:08 am
That's got 3d printed part all over it.
You could go ghetto and just loop a bungee cord around the brake leavers to the seat tube.
Posted : 09/07/2022 11:11 am
Do it. Then you'll just need a big kickstand and two large bar-end mounted rear view mirrors, preferably with your national flag attached.
Posted : 09/07/2022 11:20 am
I can see the use when in garage tinkering, but no need for something attached to bike. Struggling to see the use out and about.
Seems like a moving front end a lesser problem than the sheer bulk and weight of a loaded touring bike when lifting over gates etc.
Posted : 09/07/2022 11:23 am
Seems to be many variations on steer stabilisers (the the velo orange one below), they dampen the movement and stop the wheel flopping over, but never heard the need to lock the front completely out?
https://www.ebay.co.uk/itm/362800389080?var=0&mkevt=1&mkcid=1&mkrid=710-53481-19255-0&campid=5338749377&toolid=20006&customid=GB_888_362800389080.137935087398~1586511510840-g_Cj0KCQjwzqSWBhDPARIsAK38LY-v5Y-eMN-wTPtyRHr70ZuBNcdutj7mLVCKDh1a9ayuVQiHpV_j69MaAmx4EALw_wcB
Posted : 09/07/2022 11:30 am
I bought one of these for my wife's bike to space off her lights.  I wonder if you could repurpose it by mounting it in reverse and bending some bits. It was only 17 EUR
It's a Minoura Spacer Grip CS-500 if you are looking for it
Posted : 09/07/2022 11:34 am
Not sure if I'd want to do it, but rather than 2 rivnuts how about just one, and a thumbscrew into it, so don't drill the steerer just tighten the thumbscrew against it, which would be helpful for maintenance as you'd have a choice of positions, or partly tight for a friction based resistance rather than a full lock (or perhaps drill a very shallow hole for it to engage in).
Posted : 09/07/2022 12:01 pm
toestrap or equivalent through wheel and looped through the frame.
Also negates the need for the "brake application device"
That entire concept is daft
Posted : 09/07/2022 12:06 pm
The only useful application this has that I can see is if you have a side/centre stand and want to have front panniers on....and even then the spring version does a better job as it does need to rotate a little.
I certainly wouldn't be signing up to drill steerers and headtubes.
Look at kids bike headsets if you want to stop it spinning right round. Think acros do an adult version
Or if your really old you'll remember the hopey steering damper - professional headtube ovalisation device.
Posted : 09/07/2022 1:05 pm
Pi from clandestine bikes has a very neat solution
Not very helpful as it obviously can't be retrofitted!
Posted : 09/07/2022 1:58 pm
Think I'd try something similar to what Joshvegas mentions above.
A clamped / riveted (if steel frame) webbing with Velcro strap on the downtube.
It could be wrapped around the downtube in normal use and then through the wheel and velcrod to itself to hold the wheel still when needed.
Bit of a faff to design and get the right length etc, but probably significantly less offensive looking than those above.
Posted : 09/07/2022 3:02 pm
Still not sure of the point - but do you have a stem with a pinch bolt split up the back? Could you have something that keys into that slot and is mounted onto the top tube?
Posted : 09/07/2022 3:23 pm
Despite the ridiculing by some I still think it would be rather nice for a heavily loaded machine . It's not for mtbing I grant you but I often manhandle a heavy bike all over and the wheel flop can be annoying . I don't need one but do like gadgets ( big kid ) and tbh have read several reviews where people say it was one of their best purchases including a chap who was given one as a present and said despite being a penny picker he would buy another if that ever got broken or the bike got stolen . Horses for courses.
RE the Minoura Space grip ...yes I'd considered modifying the one I already have but it's a little bit flexy .I may still have a go however . I'm still intrigued by the pin / screw through the headtube idea and may look in to it further . I invent all sorts of things and am not scared to experiment where others may be nervous ...I accept it "might" not be the best idea but I think in practice all would be ok . Must admit though I'd be annoyed if I bugger up one of my surly bikes in the process!I'll update if I go ahead and am still alive !
Posted : 09/07/2022 3:28 pm
JonEdwards ...just saw your idea . I had also considered something along those lines . It would be nice to have a kind of jubilee clip with a tall penny washer affair for the "pin to locate into . All food for thought but I enjoy the process and tinkering . As I said ..maybe not worth the effort but over the years I have tried so many things ..some are hopeless, a waste of money ..others are great but you never know till you try for yourself . Much like so many things in life ..and I have sampled and tried many many things over 58 years !
Posted : 09/07/2022 3:39 pm
Markspark Not sure what you meant by modifying a pin spanner ...? It cant stick out all the time ..enlighten me please?
Big Dean ... I did actually see a 3d print file available online for something similar . I know nothing about that though and isn't 3d printing about plastic or are there stronger options ?
Posted : 09/07/2022 3:48 pm
Here's the 3D thingamajig ...could I easily get this printed cheaply in durable resin or stronger ?here
Posted : 09/07/2022 3:56 pm
TJ ....what do you know about touring ? I'd cycled all the way round Ireland before you were ...well 60 ! ( actually 30 yrs ago ) can't find the emojii needed ..sorry
Slowal ...apologies I missed your suggestion ..yes the first one would do it and is cheap but neither small or elegant really ..mind you many seem to hate the steerstopper aesthetics ....I personally quite like the way it looks.
Posted : 09/07/2022 4:54 pm
Can't help, other than to say that having just ridden round Europe for 6 weeks on a loaded bike, something that held a brake on and stopped the front wheel from flopping everywhere would have saved a ton of swearing, and was something I longed for....
Posted : 09/07/2022 5:14 pm
Voile strap around looped around front wheel and downtube works great, although obviously this stops you wheeling the bike!
Edit: Just seen you don't want to do that, another option would be a small (folding?) version of the things that you can get for holding the bars straight when the bike in a workstand?
Posted : 09/07/2022 5:16 pm
 PJay
SJS have a rather neat [url= https://www.sjscycles.co.uk/frames/thorn-steering-lock-limiter-striker-for-stepped-395-365-mm-head-tubes-1-18-steerers/ ]steerer limiter[/url], essentially stops that prevent the steerer turning enough to allow the brake levers to impact the top tube.
I'd have thought that you could 3d print something for the steerer tube where the stops prevent any steerer movement at all. You'd just need to come up with something (perhaps hinged or sliding) that could engage when needed and not accidentally drop into place whilst riding!!
Posted : 09/07/2022 6:03 pm
PJay ...thanks for that ...have you answered a similar question before somewhere online ? It's kind of deja vu ...I'd seen that suggested before .
I've suddenly had another idea related to that device ... thanks for reminding me .
Posted : 09/07/2022 6:46 pm
 PJay
Not me I'm afraid, I just Googled to see what came up. It looks a fairly neat and workable solution though.
Posted : 09/07/2022 6:50 pm
Maybe one of these and just use a bungee cord or toe strap round the top tube or something
https://singletrackworld.com/shop/wisecracker/
I mean, I can't see it being used for its actual purpose but anyone ever but you never know you might even do that one day.
Posted : 09/07/2022 7:18 pm
I wouldn't use it as now tea total ! I had thought of something along those lines although I could easily make something similar with some thickish aluminium plate .. yet more food for thought anyhow ..... thanks
Posted : 09/07/2022 11:43 pm
Having toured on a bike with heavy full panniers I can see the benefit of this.
However, if its anything like my bike, it will be heavy and break anything that isn't bomb proof.
My rear kickstand was always getting fixed. Next time I go I'd take an extendable walking stick to lean on that goes under the saddle.
So, unless it's really tough, a strap around the wheel and down tube sounds like the best idea.
Posted : 10/07/2022 8:05 am
Attach a loop to the front mudguard, strap around the down tube to lock the steering
(Same) strap through the wheel and around the down tube to lock the wheel for loading
Proper tourists use artisanly-crafted long metal mudguards with French names that should be strong enough with a 40-year old leather toe strap that also has a French name 🙂
Posted : 10/07/2022 8:27 am
More than anything I love that they've called a bit of string with a toggle a "brake application device" like it's some sort of wonderful, highly specialised proprietary tech.
Yes it works, yes I have one for doing exactly that that I've used for years for bleeding brakes but it really is just a bit of string
Posted : 10/07/2022 9:17 am
I'm aware and have used straps etc before but just fancy being able to lock it without any effort !
Posted : 10/07/2022 9:59 am
Oh the castration stick is a step up from a bit of string definitely, the bit of string is, however, a bit of string.
Posted : 10/07/2022 10:33 am
You could use a garmin headset spacer mount like the K-edge as it is already hinged. Hopefully you can find a cheaper version
https://www.ebay.co.uk/itm/225061069642?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=8nfhznbsqum&sssrc=2349624&ssuid=XQz0tf3FQJC&var=&widget_ver=artemis&media=COPY
Blatant copyright theft but £8.50 😝
But I'm not convinced it would last long for the use you want it for.
Posted : 10/07/2022 12:41 pm
Thanks for those suggestions ...looks a possibility but as you say ..probably too weak for the job
the other issue is that the spacer really needs to be locking otherwise it may still allow the steerer to rotate .
Posted : 11/07/2022 10:04 am
So you really want to completely lock out the steerer? Are you sure that’s what you want though? I’ve been designing a solution recently, but considering the designs already out there like the steerstopper or other “one-touch” devices, some of which are built into the frame, they seem like a liability. Imagine going fast and hitting a rough patch and accidentally triggering it or engaging the lock. You’re gonna have a bad time. So in my design I opted for just a spacer with a bulb on which to attach a nice chunky rubber band. It’s tighter and lighter than the down tube mounted spring setup. If you’re interested I’d be happy to let you try it out.
Posted : 11/07/2022 2:32 pm
Some people just can't help but accessorise their bikes with pointless tut.
Posted : 12/07/2022 10:33 pm
pointless tut.
A pointless tut seems a very stw thing
Posted : 13/07/2022 8:30 am
fruitbat reacted
"pointless" in some situations , very useful and helpful in others and appreciated by many .
Posted : 13/07/2022 8:44 am
ForkingforMasano .. if you were serious and it does sound a great idea ..I'd love too try it out and give feedback . I see your point re locking when riding etc . I will pm you . Thanks
Posted : 13/07/2022 8:50 am
 PJay
There's quite a neat, off the shelf, solution here - https://tout-terrain.de/en/the-products/accessories/378/ergo-stop-plus
Some touring frames look to be specially designed to incorporate similar systems. I don't know whether a frame maker could weld something onto the back of your head tube (I think that the off the peg system presses in under the headset cup).
Anyway, they might give you some ideas for a self-bodgeable solution.
Posted : 13/07/2022 8:56 am
Thanks P Jay ..yes I've seen that and considered trying to bodge one using a thorn lock stop kit . Apart from having a loose pin I'm not sure how I would fabricate a pin that could be pressed down to engage then pressed again to release. Anyone got any ideas or suggestions of something used for another application that might work ?
Posted : 25/07/2022 10:38 am
Good evening to you,
First: Please excuse my english and this translation, i m French Native speaker 🙂
I've been following this topic for a while and studying the steering lock problem on my wheeler 2600.
As I very frequently carry a load of around 15 kilos at the front, this rotation problem when I am stationary off and on the central stand is really ...
My vtc fell hard on its side too often for my liking.
My fork steerer is 1 inch so I tried to mount the Shimano hpnx10 to overcome this problem and be able to park with my load with complete peace of mind.Unfortunately my pivot is too short for me to screw in the fixing nut, change the fork, extend the pivot being out of the question, heading back to square one.
So I scoured the internet up and down, in French and in English, to break down the problem and try to find something functional that could be used. Steerstopper, too expensive and not very aesthetic, flickstand ditto, in short nothing seems to do the trick.
So I made something that I would like to share with you.
Parts needed:
1- A headset ring for 1 inch front brake housing stop.
2- Two small nuts and a threaded rod accepting these nuts.
3- A bottle holder ring
4- Know how to tig weld or be able to have it done by a mechanic workshop (which I did).
5- Know how to tinker at a minimum to make a knob to turn by assembly: body (your choice) stem, nut against nut, nothing rocket science.
Note: I found all these parts at the participative Vélo workshop in my town, second-hand (total: €2), the tig welding cost me €15, total €17.
1- It is necessary to file the internal lug of the headset ring for the housing stop in order not to damage the thread of the pivot since we will install this ring in reverse.
2- Arrange to pass the threaded rod through the hole in this same ring and tighten a nut from below, weld or weld the nut flat in place.
3- Solder or solder the second nut in the center of the vintage bottle cage.
That's it, the main thing is done.
All that remains is to clean after welding and before installing the two pieces.
Assembly: Disassemble your stanchion stem, loosen the headset lock nut, replace the washer located below it with the headset ring for sheath stop (sheath stop pointing down with the nut below and towards the inside of the frame aligned with the horizontal tube, front wheel also aligned.)
Fix the bottle cage ring on the horizontal tube.
Insert the threaded rod which will serve as a pin (turning knob) through the top nut towards the bottom nut until the two are screwed together.
Note that you will undoubtedly have to slightly bend the nose of the headset ring for housing stop in order to bring the plane of its nut horizontal in relation to that present on the bottle cage, otherwise the threads will not fit. They will not align correctly and we will not be able to screw the lower part from the upper part.
Once the alignment of the two nuts has been validated by tightening, attach the bottle holder collar then tighten the headset locknut, ensuring that the headset ring for the tube stop does not move in relation to the centering of the wheel .
Done...
It seems a bit complicated like that but in fact it's extremely simple to do, you just need a little patience, a file and the basic tools that go well.
Attached are photos of the required parts and the Gizmo in person to give you an idea of the assembly and basic settings. Nothing rocket science in the end.
Good DIY to you if you give it a try.
Sam
Ps: If anyone has ideas for making the Gizmo a real Gremlins, I'm interested.
Posted : 24/12/2023 5:11 pm
vxaero and vxaero reacted
