Home Forums Bike Forum Decent V Brake Compatible Suspension Fork
Viewing 6 posts - 1 through 6 (of 6 total)
  • Decent V Brake Compatible Suspension Fork
  • letmetalktomark
    I know there are a number of the forks from the lower end of the manufacturer range but who makes a decent higher end fork?
    80/100mm travel.
    amedias
    new or second hand?
    letmetalktomark
    Ideally new but open to suggestions.
    Ideally I need a 210mm steerer so I guess that further reduces the market.
    SprocketJockey
    You may need to look for “new / old” stock (think they were v compatible up to 2010?) but would Recon Races suit?:
    EDIT .link removed as it was to wrong fork!
    Failing that if you just want something second hand which works decently I’ve got a set of pre Taiwan MX Comp Airs with uncut steerer and V brake bosses which will be going into the classifieds shortly!
    fasthaggis
    Are these too cheap ?
    njee20
    Old SIDs?
The topic ‘Decent V Brake Compatible Suspension Fork’ is closed to new replies.
