Home Forums Bike Forum Customizing a helmet.
Viewing 33 posts - 1 through 33 (of 33 total)
  • Customizing a helmet.
  • 2
    Merak
    I have a rather bland new helmet and I’m going to attempt to give it a bit of a subtle lift with some colour and details.
    Very few (surprisingly) tutorials on YouTube for this kind of thing so it’s a make it up as you go along deal.
    Rattle cans only I’ve not got an airbrush and I wouldn’t know how to use it anyway.
    Much masking is the first bit…
    1
    nickjb
    You could try some Sharpie art. There’s loads of examples if you search and some YouTube tutorials iirc
    8
    kormoran
    Just leave it like that but don’t go on a touring holiday in Russia
    2
    kormoran
    I know it’s boring elfnsafey mate, but is the helmet ok to have rattlecan paint on it?
    1
    zerocool
    Keep it like it is and you’ll look like a cheap Tron cosplayer.
    1
    rOcKeTdOg
    don’t the solvents in normal rattlecans melt the polystyrene?
    Merak
    Nah, the polystyrene is masked!? It took hours!
    The paint I’ll use is specifically for plastic.
    Never thought about Sharpies will check that out😎
    Merak
    I can categorically assure you TJ the Polycarbonate paint I will use will not have any detrimental effect on the substrate other than to enhance the aesthetics (subjectively of course) 😎
    3
    kormoran
    TJ do you remember a road safety film from the late 70s or 80s with the guy who goes in a motorcycle shop with a helmet covered in stickers etc? They rip him to bits and then point out his visor is fubared too😁. The sticker solvents damaged the helmet shell
    Was actually quite good and stuck in my mind since I was a kid
    DT78
    i havent sprayed a helmet, but i have sprayed foam. most aerosols will damage it. i normally seal with a pva / water mix to protect it.
    probablu a good reason there isnt many tutorials….
    1
    tjagain
    If it is the correct type of paint and you are sure then crack on.  some paints are OK some are not.  Do you know the actual plastic type of the shell?  Not that the shell is a critical part of the helmet anyway – the EPS is the bit that does the work
    Saccades
    https://www.laxwrap.co.uk/
    These lads are good.
    2
    Merak
    First paint pass.
    Handwringers stand down, no EPS was harmed in this part of the process.
    1
    Merak
    Merak
    PXL_20240122_151705198
    1
    uselesshippy
    Ignore the nay sayers, I’ve sprayed loads of my lids, just make sure, like you have, you mask the foam.
    bikerevivesheffield
    Biggest question – why?
    Merak
    Bigger question – why not?
    FTFY.👌
    Merak
    Gunmetal this evening.🙂
    PXL_20240122_182744940
    1
    temudgin
    Thought this was going to be a thread about an intimate piercing…
    8
    Merak
    razorrazoo
    Thought it would look rubbish, actually like the Boba Fett tribute result!
    1
    cookeaa
    Not sure if a distressed effect would be my choice, but it looks good. I’ve got a couple of quite boring ‘B-team’ lids currently that I might have a play with some paints on now.
    1
    I like it!
    2
    matt_outandabout
    I hope you’ve got matching Fett baggies and jersey… I think Shimano MW5’s for the shoes…
    1
    noeffsgiven
    More vandalorian than mandalorian 😁
    a11y
    Good effort. I’ve got a boring helmet (fnar) – it’s the comfiest fitting helmet I’ve found but colour options were black, black or black. Not sure I’ve got the patience/resolve to mask and paint it up though.
    chakaping
    Nice work OP.
    Should be a good conversation starter.
    “Hey, how did your helmet get so battered?”
    supercrosss
    Custom painter that does a lot of helmets here, painting them is generally fine as long as you are careful to fully mask all the EPS. Literally every helmet brand paints helmets for their pro riders, so it’s not quite the drama people often point out.
    Main thing you need to do first is scuff the entire surface of the helmet and then apply a plastic compatible primer, or else your paint will flake off in no time at all. Prep is the most important part of any paintjob.
    Harry_the_Spider
    I like that a lot! Boba Fett meets Starship Troopers.
    rOcKeTdOg
    That looks like the first few weeks of a new relationship 😆
    Like it
    zerocool
    That helmet looks sweet. 👍🏻
