Has anyone any experience of this kit?
Got a couple of Smashpots that are great but looking for a cheaper conversion for a less used fork.
Mine has been great, after I returned the fork and TF Tuned installed it correctly (they fitted it originally at the same time as a service). Can confirm it is not pleasant sounding without the top out bumper fitted.
Other than that, it depends what you’re after. I wanted less faff with shock pumps before rides, more sensitivity and to have a less abrupt spring curve than the standard (non-debonair) spring in my pike. It’s delivered on every aspect of that, no bottom out issues – typically use less travel than I did before but with a more sensitive fork.
I think it adds some weight but I’m not in the habit of weighing my forks before and after servicing them. Worth noting I’m running a pretty firm spring rate (~10-15%) compared to what many on here seem to run. Can still get close to full travel on big hits with a little extra for emergencies.
Depends how lucky you are getting a spot-on spring rate (as I seem to have), though I guess you have a good feeling for this if you’re riding coil already.
I’ve not touched a shock pump in 10 months!
