Home Forums Bike Forum Changing FS Frame Bearings
Viewing 8 posts - 1 through 8 (of 8 total)
  • Changing FS Frame Bearings
  • blacksheep
    HI Guys and Girls,
    The onset of spring and the run of ace weather this week has prompted me to finally sort out my much loved abused FS bike, starting with getting the dead bearings changed in the frame/swingarm. Can I do this myself? I'm not an expert mechanic but I'm fairly practical and reckon it can't be too hard, I'm pretty skint at the moment so I'd rather do it myslef and avoid the LBS. I've got a pretty well stocked workshop and the frame is carbon so dont want to go steaming in if I'm going to ruin my bike!
    Thanks,
    Chris
    shermer75
    What bike have you got?
    blacksheep
    Hey Shermer, its an 07 Enduro SL.
    PikeBN14
    Where's Kaesae when you ned him!!?
    I did my Stumpjumper, but it is alloy.
    I could get 'behind' all the bearings to tap them out with a screwdriver or nicely sized socket, as long as you make sure the frame is held firmly when you tap them out it shouldn't matter that it's carbon.
    blacksheep
    Ha ha, I wanted to ref Kaesae in my post but didn't want it to become a ridiculous/hilarious 18 page epic!
    Thanks for that, is getting the new ones in pretty easy too?
    Cheers.
    PikeBN14
    It was for me, just cleaned the frame up with a bit of GT85 and wiped a little grease in to help them on their way.
    Oh, and I used a Black and Decker Workmate to hold the frame steady.
    blacksheep
    Hey thanks Pike, I'll order some bearings and get it done, cheers.
    GuyFox40
    I've just done the bearings on my 08 Enduro(alloy frame) and its a fairly straight forward job
    Found the best way to remove the bearings was with a vice and 2 sockets so that the vice would press the bearings out and in(it saves hammering and risking damaging the swingarm)
    Might be worth changing the bolt kit when you are doing it as a couple of my bolts were worn with grit n stuff
The topic ‘Changing FS Frame Bearings’ is closed to new replies.
