Home Forums Chat Forum Carbon capture project cancelled
Viewing 40 posts - 201 through 240 (of 252 total)
  • Carbon capture project cancelled
  • Edukator
    So what’s the R rating of the isulating material you used, TJ? A description of the material is all we need to work it out if you don’t know.
    Once again you make the assumption that other forum contributors “know nothing”, TJ. Before long you’ll be telling us “we haven’t got a clue”. Other forum readers just see you refusing to reveal your gas, electricity and transmort use, and dissing pdfs published by the competent authorities.
    TandemJeremy
    Why should I accept your presumption that I know nothing about listed buildings or the authorities that deal with them?
    Well its fairly clear to me that you don’t know anything much as you keep telling me to do things that are not possible and you keep showing your ignorance of it
    I ask you again – what is your experience of insulation of 130 yr old listed buildings in a conservation area in Scotland?
    Your experience of working with Historic Scotland is?
    Its not my ignorance don – its your inability to accept that I know my building, what is allowed and what is not.
    Edukator – the insulation was put in by contractors working for the council so I do not know what it was – its a green ( I think) semi rigid board 100 mm thick – it meets building regs suposedly. Looked like polyurethane foam
    I do not refuse to reveal my energy consumption – I do not have the numbers. Its high – I can tell you that. A consequence of living in a building that is hard to insulate well – although its one of the best locally – as the snow stays on it a lot more than neighbouring buildings. All my external walls are lath and plaster to timeber to either slate or lead or roofing felt.
    Those PDFs are general guidance. I know the specifics for my building because I have discussed it with historic Scotland. I know that in Edinburgh I can only replace the windows with replicas which precludes the use of triple glazing
    It does amuse me that two people who don’t even live in the same country and have had no dealings with the authorities know more about the building I own that I do and they know all these things that are possible to do despite historic Scotland refusing to allow them or it not being possible due to the construction of the building.
    So yes – clearly neither of you know or understand the issues I have and have no desire to know. I know I have done as much as is possible
    flap_jack
    “Salmond is hopping”
    now that I would like to see
    TandemJeremy
    Well he is a toad 🙂
    Edukator
    I’ve rubber stamped a lot more British planning applications than you, TJ.
    Anyhow we’ve now assertained that the energy consumption of you home is very high and the insulation woefully inadequate. We also know that you are much keener on finding excuses than doing anything about it – much like the power company you started this thread about.
    donsimon
    Tandem, why should I answer your questions when you’ve refused to answer mine? But I will. My experience with CWI and loft insulation in 130 a year old building is zilch. But then again I have never claimed any thing different, so I’m not sure what you’re trying to achieve with that. But if it makes you happy, who am I to complain?
    And unlike Edukator’s experience you’ll just have to keep guessing on mine, it’s more fun that way.
    TandemJeremy
    So its established then – neither of you know anything about my building, my situation, or the regulations I have to work with.
    Nothing either of you have suggested is a possible way to achieve a better thermal performance. You have also missed the most obvious one – secondary glazing. ( of which I have some)
    so spending many thousands and many many hours fitting the best insulation I can is finding excuse rather than doing anything.
    If either of you actually had something relevant and possible to suggest it would be useful. Instead yo just want to be ignoarnat and unpleasnat trolls. byee to both of you
    donsimon
    You have now just made my day. Wher the **** do you get off? You sir anre indeed an i***t of the highest order. 😆
    unpleasnat trolls.
    And this is the cherry. Show me the unpleasantness directed at you? I can show you the derrogatory comments and misguided assumptions you have, again, made about me, if anyone should be affronted, it’s me. You know what that say about hot kitchens, don’t you?
    TandemJeremy
    don simon – Member
    You are both ignorant and stupid – too stupid to understand the limits of your knowledge and experience.
    donsimon
    What’s CWI and loft insulation got to do with windows? Zero experience in these areas will mean that I don’t give advice here and if you care to look back you’ll see that I haven’t spoken about CWI or loft insulation because I do know the limits of my experience, unlike some. You’re too easy Tandem. 😆
    TJ in another not listening shocker!! 😯
    Kit
    This thread is really **** embarrassing to be associated with 🙁
    TandemJeremy
    sorry kit – I forgot “don’t feed the trolls”
    Edukator
    So we’re both ignorant and stupid now, TJ. Time for bed I think.
    The thermometer on my wall reads 19.2°C; the heat from three people, the TV and a computer has raised it by 0.2°C on a cold, star-lit evening. It’l still be nice and warm in the morning. Think about that as you get out of bed in your freezing attic, or do you leave the heating on greenhousing the planet all night?
    Kit
    In case anyone reading this is still interested in actual thread topic, this opinion piece is interesting:
    http://www.guardian.co.uk/environment/2011/oct/20/carbon-capture-uk-european-funding
    donsimon
    I’m sorry that you don’t think that indivuals taking responsinbility for reducing their own consumption is important. But hey, each to their own.
    TandemJeremy
    Don – which is why I live a lower carbon lifestyle than many and why I have insulate my house as much as possible.
    uponthedowns
    Jeez TJ and Edukator. I thought all you eco-warriors were on the same side.
    bigjim
    DenDennis – That diagram is pretty meaningless as far as I can see by itself, maybe it might makes some sense in the context of its accompanying chapter. I don’t understand why its crossed out eg shallow offshore wind with the line ‘not near my birds’ when offshore windfarms are being built having gone through the planning process where impacts on birds would have been assessed in EIA.
    I had a quick look at the link and the first chapter I looked at on offshore wind was a bit alarmingly written:
    Conven-
    tional wisdom seems to be that shallow offshore wind (depth less than 25–
    30 m), while roughly twice as costly as land-based wind, is economically
    feasible, given modest subsidy; and deep offshore wind is at present not
    economically feasible. As of 2008, there’s just one deep offshore windfarm
    in UK waters, an experimental prototype sending all its electricity to a
    nearby oilrig called Beatrice.
    Starting a paragraph with the phrase “Conven-
    tional wisdom seems to be”
    is a bit worrying and I would suggest a lot of the technical aspects of that chapter are looking a bit dated already when you look at the depths of Round 3 zones and projects like Hywind II.
    I’ve not read the rest but based on that I would bear in mind that it might be a bit dated already.
    Kit
    If you say so.
    ojom
    In other ‘edge of the seat as it happens’ related insulation and efficiency news, the wife n me bought 7 rolls of wool for the loft and the FIL fixed a buggered hallway window that was draughty and noisy to boot.
    As you were Eco Soldiers.
    wwaswas
    Chapeau for Don Dimon on this thread.
    TJ, as per usual, ignores the evidence that doesn’t suit his argument and resorts to insulting the intelligence of those that disagree with him.
    TandemJeremy
    wwaswas – what evidence that does not suit my argument?
    The kept trying to tell me I could do stuff that is specifically excluded because of their ignorance of my position.
    Don Simon and Edukator – neither of them live in the UK. Neither of them know my building, neither of them have had any experience of dealing with historic Scotland.
    I have specifically asked historic Scotland about replacing windows and the only acceptable replacements for my flat are wooden sash and case windows that are replicas of the original which completly precludes the use of triple glazing.
    The two of them arrogantly assumed they could point out where I could do more and then could not accept that I know more about what is possible in my building than they do.
    I have fitted as much insulation as is possible within the constraints of the listed building in a conservation area.
    They were both extremely offensive towards me if you read the thread.
    donsimon
    *Waves from Shropshire*
    wwaswas
    A link to about 8 different suppliers of ‘approved’ double glazing where you insisted there was only one?
    TandemJeremy
    wwaswas –
    Thats because there is only the one manufacturer who makes the type of DG units that can be fitted into the type of windows I have to have fitted.
    donsimon
    Who is this mysterious manufacturer? And what are the specifications of the DG units?
    Bearing in mind I’ve already linked to 9 manufacturers on a Historic Scotland document.
    wwaswas
    that can be fitted into the type of windows I have fitted
    well you would say that, wouldn’t you.
    on the other hand;
    You’ve clearly done a lot to insulate where you feel it’s possible.
    But to be so absolutist about stuff is just asking for people to come along and say ‘but what about ‘x’ or ‘y’?’
    It may be that there is no more to be done but your approach to being quizzed tends to lead people to believe that you’ve got the blinkers on and believe that chez TJ is incapable of further improvement and that your mind is not going to be swayed by discussion – you’ll subsequently just defend the position you currently have until everyone gets bored and moves on.
    TandemJeremy
    wwaswas
    They came on and told me I could do more without knowing what I had done, when asked for specifics told me I could do things that are not allowed or possible and then got very offensive towards me. They did not ask what I had done nor sugest things I could do – they told me I could do things that re specifically excluded and / or not possible due to the construction – then got all offensive when told it was not possible
    In the 20 years I have been here I have done my best. For two people who do not know the building and do not understand the regulatory environment to tell me that I can do more and accuse my of lying and hypocrisy is a bit much.
    Just ask yourself – who is likely to know more about what is possible in a specific building? the person who has lived there for 20 years and have discussed improvements with the rregulators of two people who have never even seen the building?
    wwaswas
    I’m not saying you’re wrong TJ, just that your somewhat, errmm, forthright way of dealign with what were, initially at least, fairly reasonable questions and comments tends to lead to lead to escalation.
    TandemJeremy
    wwaswas – “fairly reasonable questions and comments” this was their opening sallies
    Edukator – Member
    What TJ does know is that for an attic flat which if properly insulated would be heated by the people living below his energy bills are embarrassing and would demonstrate just how hypocritical he is on this thread – moaning about others not doing anything to cut their carbon emissions when his own home is greenhousing the planet.
    don simon – Member
    “My attic is as well insulated as possible -“
    I wager it’s not.
    I’d put good money on your windows only having a u value of about 1,5W/m2ºC and don’t take full advantage of solar gain… And your walls not being 0,35W/m2ºC… And your roof….
    Jumping straight in to the attack with a load of wrong assumptions.
    No one lives below me. I have as much insulation fitted as possible, I have fitted the best windows I can. Because they do not know either my building or the regulatory environment………………..
    donsimon
    Where’s the attack?
    And I think you’ll find that in reading this document,
    http://www.historic-scotland.gov.uk/slim-profile_double_glazing_2010.pdf
    you’ll find the double glazing u values range from 1,1-2,8 w/m2ºC, so hardly a “wrong assumption” either.
    Focus on what people are saying and not who is saying it.
    clubber
    TJ – step away now, seriously…
    I’m pretty sure that your two main tormentors are having a good giggle at you with this thread since I’m fairly sure their aim is simply to turn your ‘show me proof’ stance on every other thread back at you.
    FWIW, despite my reckoning that you’re probably right about the potential for any (practical/realistic) further improvements to your home wrt to this discussion, reading your responses to Don and Edukator does not show you in a good light IMO. You are rude and insulting where there’s no real reason to be. I’d suggest that considering the way you deal with other people, you should have thicker skin to deal with the apparent slights headed your way.
    TandemJeremy
    clubber – Member
    I am sure your right – I only replied to wwaswas – those two are now on my killfile so I don’t have to see any more posts from them.
    FWIW, despite my reckoning that you’re probably right about the potential for any further home improvement wrt to this discussion, reading your responses to Don and Edukator does not show you in a good light IMO. You are rude and insulting where there’s no real reason to be.
    Only in reply to insults from them – questioning my integrity, calling me a liar and a hypocrite.
    Teh insults came from them first
    donsimon
    TandemJeremy – Member
    don – you don’t know what you are talking about.
    wwaswas
    I think Iwas really trying to say what clubber said, perhaps just less succinctly.
    clubber
    That’s kind of my point though TJ – you read some comments as insults which as an independent observer I don’t believe are or were directly intended to be.
    This for example
    don simon – Member
    I wager it’s not.
    It’s not an unreasonable comment in itself. Most people I reckon could have replied “you might think so but I’ve checked it all out and spent a fortune on it and can’t find anything else to do. If you know something I’ve missed, please let me know” rather than take is as a grave insult.
    And I’d also consider that it was a hook to get you into a position where you’re unable to provide ‘proof’ to your own standards on other threads which might be something to think about too. Not being able to provide a link to proof is not the same as saying that something isn’t correct.
    TandemJeremy
    Oh aye – I was stupid to bite on the hook and thats clearly what it was.
    Its pretty offensive to be told I am wrong and hypocritical about something where they know nothing about the situation.
    But the insults were intended to reel me in and I fell for it
    clubber
    ps I’ve just added a “TJ goes into orbit ” tag as I thought it was appropriate here 🙂 Seriously, take a step back and wonder why it’s always you.
    clubber
    was the one I quoted REALLY an insult? To call you to task considering your stance which comes across as an absolute isn’t unreasonable is it?
    Saying that someone may be wrong isn’t an insult in itself – you should hope not as it seems to be a common accusation you make. Hypocritical is maybe more insulting but then you often talk in absolutes which basically makes a hypocrite of almost everyone in some way so I’d take that as more a comment on that than a direct insult…
    donsimon
    Take a step back clubber, we’d hate to lose you.
The topic ‘Carbon capture project cancelled’ is closed to new replies.
