Home Forums Chat Forum Bose soundlink Mini battery replacement
  • This topic has 8 replies, 4 voices, and was last updated 1 year ago by jkomo.
Viewing 9 posts - 1 through 9 (of 9 total)
  • Bose soundlink Mini battery replacement
  • jkomo
    This Bose was a favourite here a few years back, and mine has finally died after daily use. It’s only the battery that needs replacing and it looks pretty simple. I can’t find a genuine one so it might have to be aftermarket. Are these things generally okay or a bit explodey? Is there a good manufacturer of copy batteries to look for?
    v7fmp
    hi jkomo. How do you know its the battery? We have 2 in the house and one has stopped working. Doesnt turn on. And nothing happens when plugged in (no lights).
    Reckon changing the battery is worth a punt?
    1
    andylakes
    Had similar. Contacted Bose customer service. Out of warranty but offered a very good deal on a replacement. Worth a call?
    mtnboarder
    I had the same, but after shelling out for a battery, realised there’s two version- one of which has the battery soldered in directly and can’t be replaced..
    Guess which one I had?
    Replaced it with a Marshall Emberton which is not as good sound wise, but feels more sturdy and has much better battery life
    v7fmp
    andylakes – good shout! cheers 🙂
    andylakes
    Hope it works out for you!
    jkomo
    Mtnb I don’t mind a bit of soldering.
    When I plug in the charge light flashes red, so I’m Pretty sure it’s battery. Might give a ring though.
    mtnboarder
    Cool, fancy doing mine too?!?!
    jkomo
    If it goes okay I’d be happy to!
