Replacing the big s...
[Closed] Replacing the big sprocket on a Shimano 11spd cassette
[#8056612]
I have an XT M8000 cassette on my main bike. It has an aluminium 42t sprocket that's mashed, some way before the rest of the cassette. It's on a cluster of three cogs. Is there a cost effective way to replace this cluster, do Shimano offer this as a spare? SJS cycles don't have it so I suspect not.
Is there an alternative that's cheaper than a new SLX cassette at £50 that'll do the same job, like an expander? I've found one but it's $110 before shipping or taxes which sort of defeats the point. I'm loathe to throw away a functional cassette for the sake of one cog.
Posted : 15/09/2016 11:38 am
 scud
If you search "Rose bikes Cassette sprockets" they do parts of the cassette, both the rear group of three, and individual 11,12, 13 etc small sprockets?
Posted : 15/09/2016 11:45 am
 cp
i'd look on rose as above. Dave Hinde used to break up cassettes and sell indivdual sprockets, but doubt you'll want to go there 😉
Out of interest, how much use has you cassette had?
Posted : 15/09/2016 11:48 am
One Up 45t includes 18t?
[url= http://int.oneupcomponents.com/products/45t-sprocket-18t ]Link[/url]
The M7000 SLX 11 speed represents better value.
Posted : 15/09/2016 11:54 am
I'd get a smaller front ring at the same time too, if you're wearing out the 42t you're geared too highly
Posted : 15/09/2016 12:11 pm
Agree with Steve, smaller ring needed.
The spare part is 1RK 9805. I found one shop with stock, it's €67.50! Madison don't seem to even bother.
Edit: €50 on Bike24. I'd still get a new cassette.
Posted : 15/09/2016 12:14 pm
Rose don't do them unfortunately. nor Hinde.
A normal expander is meant to work with the worn 42t rather than replace it so it won't work unfortunately.
cp- I was just trying to figure out how much I'd used it but it looks like my Strava has been hacked so I can't get my mileage up 😕 . From memory it's about 1,000 - 1,200 miles almost all off road.
I run a 30t up front, which is in good condition. Surely the bigger problem is the cog being made of aluminium?
Thanks for your sleuthing njee, I'll have to get a whole new cassette then!
Sunrace are the same, don't think you can get those either. You can for sram but they're so expensive, they're more than a whole XT cassette.
Posted : 15/09/2016 12:23 pm
Well yes and no, it won't wear out unless it's being used, that it's worn out so quickly just further reinforces that you use it a lot, which is solved by using a smaller ring. FWIW I've got 2000 miles on my XX1 cassette, the 42 is fine, but I probably only use it 1% of the time, at most. Many rides I never use it.
I did spec my chainring size with the intention of limiting the amount of use I give the aluminium sprocket.
Posted : 15/09/2016 12:33 pm
 D0NK
which does kinda beg the question why a presumably ali 30t is just fine when a whopping great ali 42T is shagged....?
Posted : 15/09/2016 12:43 pm
D0NK- it certainly does. When I say shagged, I mean proper shagged. Bent teeth. Teeth missing. It was new in January and I've been up maybe 8 mountains and do ride fairly steep stuff around the Peak day-to-day, but the previous 10 speed cassette on the old bike did that and lasted a couple of years including the Strathpuffer. This is the shortest time I've had a cassette last since I switched from SRAM 7 years ago.
Posted : 15/09/2016 12:50 pm
How many chainrings did that setup have?
Posted : 15/09/2016 12:52 pm
2x.
Just sayin.
Posted : 15/09/2016 12:55 pm
That was 1x too, lowest gears was 32 front 36 rear. It did go through an alloy chainring in just over 18 months but I think that's acceptable.
Posted : 15/09/2016 12:56 pm
Im on my second one in a year. First was a 42 current one is a 40 and im pretty sure the top 3 are steel not ali. Its all to do with chain line, wears quicker on the out side most rings. My 42 went on 9,10,11 and im running a 30t front.
Posted : 15/09/2016 1:13 pm
Thanks bigpins, that's useful to know. I'll try and adjust the chainline but since I've got BB92 I doubt I can do much about it.
It's tough living in the future...
Posted : 15/09/2016 1:27 pm
It was a lot cheaper than the 42t too.
Posted : 15/09/2016 1:55 pm
How's your chainline? Is your chainring sitting too far out?
Posted : 15/09/2016 3:21 pm
2x
Correct answer.
Posted : 15/09/2016 3:30 pm
The 42t sprocket is quite a but narrower than the teeth on the chainring, no?
The answer to your problem is to go back to 1x10 and use a sunrace 11-42 with the steel 42t sprocket (can't remember the model and can't find the email, but from Triton Cycles).
Also keen an eye on Revolution Components. They're a small NZ outfit but I was riding with someone who had a steel big sprocket made to replace the alu one from a SRAM 10-42 cassette.
Posted : 15/09/2016 4:18 pm
I was reading this with interest, as I've managed to take a tooth off my 42t cassette 🙁
Still, rides OK so I'll live with it 🙂
Posted : 19/09/2016 11:17 am
The 42t sprocket on them Sunrace cassettes is thicker than all the rest, seems a good design choice!
Having said that Shimano cassettes are hardly lightweight flimsy things are they! SRAM equivalents are usually machined skeletal things in comparison.
If it's a standard 104 BCD crankeset you can space the front ring inward. It often needs about 4 mm which is a pretty thick washer. I got some commonly available (not specialist aritisanal unobtainium bike taxed) alloy split washers that did the job. Depending on the crankset you [b]might[/b], most likely though, need longer chain ring bolts as well.
Posted : 19/09/2016 1:47 pm
If you are that stressed you NEED to go to HR / occupational health and tell them - you are on the verge of being unsafe at work if not already over it. Stressed folk make mistakes
I have been transferred in a hospital reorganisation into a role that I didn't have the skills for and the stress nearly did for me. After working the system I am now in a suitable role.
Posted : 19/09/2016 4:13 pm
I never stress over the state of my cassette. Occasionally about the rear mech. Or about having STW open on too many tabs at the same time. 🙂
Posted : 19/09/2016 4:27 pm
Posted : 19/09/2016 6:55 pm
