Homemade bits and t...
[Closed] Homemade bits and tools.
[#2567321]
[URL= http://img710.imageshack.us/img710/5673/dscf0369small.jp g" target="_blank">http://img710.imageshack.us/img710/5673/dscf0369small.jp g"/> [/IMG][/URL]
Uploaded with [URL= http://imageshack.us ]ImageShack.us[/URL]
Made a shock bush press today. The sense of satisfaction from making a tool is fantastic.
What have you made?
Any ideas for other tools? Currently making a rubber faced mallet too.
[URL= http://img705.imageshack.us/img705/1329/malletsmall.jp g" target="_blank">http://img705.imageshack.us/img705/1329/malletsmall.jp g"/> [/IMG][/URL]
Posted : 15/03/2011 9:32 pm
Nice.
How do you do the rough texturing on the hammer? Is that just some tool for the lathe.
Posted : 15/03/2011 9:45 pm
Yupp knurling tool. Two rollers with spiral lines on them, when you wind the tool across the work it chequers the work. Cool aint it.
Posted : 15/03/2011 9:50 pm
I've cut the end off an allan key for a tight spot, and created a cranked spanner from a straight one. Does that count? 😉
Actually, I did make some sort of tool at school years back...I remember using the lathe to put a knurled handle on it. Can't remember for the life of me what is was...
 ton
headset press
length of 16mm threaded bar, 2 nuts to fit and 2 big washers.
works a treat.
Posted : 15/03/2011 9:54 pm
Presume you have a lathe at home to have made that.
Posted : 15/03/2011 9:58 pm
Might make a fancier headset press next achilly. Not done any threading on the lathe yet..
I have a dream of making a CNC lathe and making some hubs. (nevergoingtohappen)
Posted : 15/03/2011 10:04 pm
Did it at lunch time at work.
Posted : 15/03/2011 10:05 pm
Nice work wysiwyg.
Most of my 'tools' are bodges but it is satisfying to cobble together something that does a better job than a hammer.
I [i]need[/i] a lathe...
Posted : 15/03/2011 10:10 pm
headset press
works a treat
And me. Jobs a good'n.
Posted : 15/03/2011 10:14 pm
That mallet must be heavy?
I've made myself a sine bar, lots of clamps etc from my engineering days, got some home made mic head holders, extended drills,
Also cnc'd my pc tower case side panel with a bio hazard sign.
Wish I had access to mill/lathe etc these days. What fun I'd have making bike bits!
Posted : 15/03/2011 10:18 pm
Few years ago I made a valve spring compressor for our W123 Merc 280TE.
A mate bought the original home and I photo'd it and made copy out of all mannor of tat I had lying about(couldn't borrow it as his foreman was a tossa).
It allowed me to change all the valve stem seals - smoking into non-smoking without taking the head off.
Only just, though, as it collapsed on the last one in a Hollywood suspense film stylee.
And yes - great sense of acheivement.
Posted : 15/03/2011 10:27 pm
Stuff I made in my engineering days.
Posted : 15/03/2011 10:32 pm
Wow, a little more precision than me. I really want to get some time on the mill too.
Posted : 15/03/2011 11:25 pm
impressive machine skills. I was led to believe the better hammers had a wooden shaft as it tranfers less shock to your arm.. a falsehood?
Posted : 15/03/2011 11:37 pm
so what are the chances of making up a few of those bush presses for us mortals to purchase?
Posted : 15/03/2011 11:41 pm
Some brake pad spacers I did for my Mono Minis:
[url= http://farm6.static.flickr.com/5051/5530608940_9e188199c4.jp g" target="_blank">http://farm6.static.flickr.com/5051/5530608940_9e188199c4.jp g"/> [/img][/url]
[url= http://farm6.static.flickr.com/5051/5530609528_b068ef8193.jp g" target="_blank">http://farm6.static.flickr.com/5051/5530609528_b068ef8193.jp g"/> [/img][/url]
[url= http://farm6.static.flickr.com/5053/5530610028_1b18c9e7dc.jp g" target="_blank">http://farm6.static.flickr.com/5053/5530610028_1b18c9e7dc.jp g"/> [/img][/url]
[url= http://farm6.static.flickr.com/5052/5530025641_894129a573.jp g" target="_blank">http://farm6.static.flickr.com/5052/5530025641_894129a573.jp g"/> [/img][/url]
Posted : 15/03/2011 11:52 pm
headset press
works a treat
add a couple of smaller washers, or an old bearing, and you can then press your own BB bearings into HTII cups as well.
Drift them out with a hammer and appropriate socket.
Posted : 15/03/2011 11:59 pm
Dont think i'll be making any any time soon. That set took about 2 hrs. Probably get that down if i were to make more, its only the second thing ive made so far.
Oogles> genius or madness I dont know. But why not if youve got the gear. Assuming theyre CNC machined tho?
Posted : 16/03/2011 12:04 am
We're getting a rapid prototyping machine at work.
If I can model it, we can make it.
And I can model pretty much anything....
Posted : 16/03/2011 12:32 am
This may be the only titanium headset cup remover in existence:
and of course the old favourite:
Also have a variety of homemade presses, including one to pull a freehub off with (I suppose it's a puller, not a press, but the same principles apply).
I reckon it's even more satisfying when you bodge your own tools from items available without resort to a lathe or milling machine.
Posted : 16/03/2011 12:42 am
@wysiwyg yup CNC mould tools, takes all the effort out of it really 😉
@aracer I do love a good bodge! I think all my good ones are at home so no photos. My favourite is the bottle opener made from a brake lever blade.
Posted : 16/03/2011 12:49 am
Cut threads are a bit weak, especailly for a headset press. Buy a bit of threaded rod, the thread will have been rolled in.
Posted : 16/03/2011 12:55 am
Not neccessarily, depends on the thread, If turning them they can be made any size/ shape for strength.
threaded rod = stretching issues and generally made of crap grade steel padded with sand and sawdust.
Posted : 16/03/2011 9:06 pm
ooh and almost forgot, Aracer and Oggles, nice kit.
Posted : 16/03/2011 9:08 pm
 Ewan
Aracer - have you any details on that bottle thing? Presume it's for seating tubeless tyres? Looks awesome...
Posted : 16/03/2011 11:00 pm
This is one of the suspension links I made for my DIY bike.
Posted : 16/03/2011 11:12 pm
Workstand. Love it! 😀
I knew I'd one day find a use for those trampoline poles.....
Posted : 16/03/2011 11:31 pm
replacement dropout on my Kona A to retain the snubber roller better than the original design
[url= http://farm6.static.flickr.com/5098/5505727994_f88b1c6f9e.jp g" target="_blank">http://farm6.static.flickr.com/5098/5505727994_f88b1c6f9e.jp g"/> [/img][/url]
[url= http://www.flickr.com/photos/ir_bandito/5505727994/ ]DSC_0407[/url] by [url= http://www.flickr.com/people/ir_bandito/ ]ir_bandito[/url], on Flickr
Now sporting a cartridge bearing rather than the solid roller as the belt wore it flat.
Next job is a pair of dropouts so I can convert it to bolt-thru
Posted : 17/03/2011 12:37 am
@aracer
nice bong
Posted : 17/03/2011 12:45 am
Here are a couple of posts with more details on my lemonade bottle compressor:
http://www.singletrackworld.com/forum/topic/diy-tyre-inflator-made-out-of-old-lemonade-bottle-for-tubeless-how#post-456707
http://www.singletrackworld.com/forum/topic/tubeless-tyres-anger-management-issues#post-44698
Though I think if I was starting from scratch now I'd probably make one using a garden sprayer, as recommended on one or other of those threads.
Posted : 17/03/2011 1:10 am
Old chain in a vice to act as a chainwhip is the best I've done.
Posted : 17/03/2011 1:16 am
Best I've ever managed is cutting the bend off a 5 or 6mm allen key, supergluing the long bit into a similar sized socket, connected with an extension bar, to get to the bolt deep inside the legs of Rockshox Indy SL forks to dismantle them. A successfully bodged tool to get round the stupid fork design.
Best bodged tools are things like a bit of metal pole over the end of a spanner to undo too tight nuts and bolts, things like that. Necessity being the Mother of Invention and all that.
Posted : 17/03/2011 1:25 am
I have a piece of steel bed-angle with a short section of chain bolted to it as a chain whip 🙂 And lots of blunted screwdrivers after using them as drifts ?
Posted : 17/03/2011 1:27 am
I find old spokes are surprisingly useful for all manner of little jobs.
Posted : 17/03/2011 1:32 am
Spoke nipples make good anti-fray cable ends as well.
Posted : 17/03/2011 1:35 am
