Home Forums Bike Forum Yeti SB66
Viewing 16 posts - 1 through 16 (of 16 total)
  • Yeti SB66
  • jtodd109
    I’m having problems with my SB66, the rear tyre is rubbing against the seat tube whenever I do any kind of jump. I’m running the shock at the max of 300psi. Has anyone had the same problem, if so how did you sort it. Cheers
    continuity
    In the air or upon landing? Is your rear axle loose? Enough pressure in the shock? Too high volume tyres?
    jtodd109
    It happens when landing, all pressures etc are correct and the frame is only weeks old.
    Cheers for the link that’s spot on. At least I’m not the only one. Thx
    br
    Maybe this is one of the reasons why the carbon version is (well) delayed?
    patriotpro
    Why does it matter what pressure is in the shock…If it’s hitting the seat-tube, that’s a design fault and should be returned?!
    emmodd
    Wrong length or faulty shock? No problem with mine and 300 psi is a lot
    Paceman
    I agree, probably nothing to do with the shock pressure in my opinion, it shouldn’t travel as far as the seat tube.
    Northwind
    Can you recreate it in the garage by letting the air out of the shock? Have you fitted a vast rear tyre?
    jtodd109
    Only running 2.35 Ardent tyre on the rear. Will deflate the shock and see what happens. Cheers
    Superficial
    I don’t reckon that’s an accurate method.
    1) The shock I’m sure has some compressible bottom-out bumper
    2) In a hard landing the frame will deform
    3) Likewise the tyre/wheel can deform on landings
    It doesn’t sound very good, but the advice seems to be to get over it, and stick some heli tape on the back of the seat tube to protect it from scuffs. I’m not sure I’d accept that option on my brand new £2k frame…
    kiwijohn
    No problem here.
    Medium frame, 185 psi in the shock & I’ve had the o ring off the end with no sign of the tyre hitting the frame.
    jtodd109
    Cheers for the advice lads, I’ve sent an email to Silverfish to see what they advise. Thx
    P20
    As above. If the tyre hits the frame, regardless of shock type or pressure there’s a problem with its design or spec. Nothing to do with user set up. Either the shock is too short or the frame geometry is wrong.
    Paceman
    Also check it’s the right rear shock length and the wrong one hasn’t been fitted.
    rockitman
    What size frame is this jtodd?
The topic ‘Yeti SB66’ is closed to new replies.
