I unplugged it from everything, then reconnected it to my network using ethernet, scrolled through the impenetrable menu and got it to do a firmware update, somehow (god knows how) reconnected it to my phone and then managed to do a full scan of DAB stations which brought back radio 4 5 and 6. Then got the net radio to tune into 6 music (much better than DAB when it works).
done (most of) this now thanks john. went through the menu and found firmware update, it said it had been successful although when i checked the version it was still the same number (2.14, is that the same as yours?). switched off and on again, but it still hasnt brought dab back. its still connected to my phone through wifi so been trying to find a scan. think i found the scan through the remote control (init scan?), so clicked for it to scan but its just gone back to ‘tuning…..’
btw, fm still works, just dab that doesnt, so that implies that it isnt a loose connection between aerial and PCB doesnt it?
i may try and open it up tho to check.
i found 6 music on net radio as you suggested, so im happy enough for now, be nice to get it working properly tho…..
thanks
EDIT: john youre a star! just as i came off here i thought id try a second ‘InitScan’. this time it went from 0-100%, found 67 channels, and im back in the game! no idea why, but its good as new again 🙂
thank you very much.
