chilled76 – Member
Id personally run the axis so weight is on y.
If I get bored I’ll see if I can model the trend algebraically for you and extrapolate. In fact my A Level class can do that Monday morning as a starter
Be interested in the real answer to see how accurate we get it.
I actually work with several postdoctoral mathematicians who could pop out an answer for me in a few mins !
quick google at the Asym i29s in 29″ that i have and found this in about 2 seconds:
26″ 538 35mm TBA 559x35c 32 / 4.5mm
27.5″ 563 29mm 538g 584x29c 32 / 4.5mm
27.5″ 563 35mm 570g 584x35c 32 / 4.5mm
29″ 599 29mm 583g 622x29c 32 / 4.5mm
29″ 599 35mm 612g 622x35c 32 / 4.5mm
Can’t imagine there’s too much difference to that
Considered that but
1) the at rims are quite different in cross section
Vs asym
Also 29 at i25 is about 45g heavier than frequency i25 and but also with non linear increase as you vary rim width
There’s also the issue of manufacture weights being BS !
