What are you actually trying to achieve?
I’ve put router bits in pilar drills when I’ve wanted to make a nice clean looking blind hole (actually lots of them – it used it to make the dots in a set of large oak dominos.
If you are wanting to make acurate straight grooves then a router table as above is quite a simple diy able thing to do. What you can’t do easily that way is plunge, so if you wanted to cut a shape midway in a board thats not so good
A further option is fitting a router collar and cutting a jig – that controls the extents of the shape you want to cut and you can fit stops on the jig so that you can repeat the position of the cut on multiple boards.
For anything complicated I draw a jig up in CAD and get a local sign making co to cut it from a bit of scrap.
