Yeah, that weight is pretty out!
I guess if you’re running you’re medium G150 with a 40mm stem, you’re looking at reach of 648mm (608mm top tube + 40mm stem). Whereas a medium T130 is going to give you a reach of 664mm (594mm + 70mm stem). If I do go with the T130, I might try and get away with a 60mm stem, although I guess 70mm is hardly long.
Still so torn between a G150s, which is available now, and a T130s, which won’t be available in LBS until at least mid-October. While I much prefer the spec of the g150 (the brakes, drivetrain, fork, shorter stem), I just can’t shake the feeling that it will be overkill, and hence less spritely/poppy/manoeuvrable on pretty much all of my riding, except the most gnarly stuff that I’d do very occasionally – i.e. red runs at Bike Park Wales. Other than that, I will generally be limited to red and blue runs at trail centres, maybe the occasional trip to more natural riding.
Just can’t decide. Wiggles – would be keen for a ride report once you’ve Christened your beauty.
