Home Forums News Whyte E-160 RSX 29er First Ride Review
Viewing 9 posts - 1 through 9 (of 9 total)
  • Whyte E-160 RSX 29er First Ride Review
  • Ben_Haworth
    The Whyte E-160 now comes in all of the wheel size flavours. It’s a height-dependent wheel size smorgasbord though. Any size bigger than a S is availa …
    By ben_haworth
    Get the full story here:
    intheborders
    Run it in steep mode and add a -2 headset.
    thegeneralist
    Things you like: big battery
    Things you don’t like: big battery
    Eh?
    Make up your mind
    mashr
    thegeneralist
    Eh?
    Pretty obvious I thought? Range = good, weight = not good, so choose your poison accordingly.
    argee
    So if you had to remove all the rebound damping and turn up the compression damping on the rear shock is it a case that the bikes undershocked, or it wasn’t set up properly, to do those settings on a shock tends to go against the norm, is it able to be sorted by spacers, or not?
    DaveyBoyWonder
    No mention of the weight? I think the pinkbike review mentioned these things were 58lbs! FIFTY EIGHT!
    tjaard
    The fact that it has a slack seat angle and short chainstays, and consequently is less good at home climbing technical Singletrack along with the heigh weight seems a bit of a mismatch with the travel.
    After all, if one is riding a heavy e-bike best suited to fire road ascending, then it might as well have enduro or DH amounts of suspension for the descent.
    I would think that the purpose of a mid travel e-bike is to make normal mtb rides (meaning singletrack uphil, downhill and level-ish) longer and more fun, by boosting speed on the flat sections, and boosting endurance on the techy uphil sections.
    danieljohnreynolds
    @Benji, how do you like the e-hybrid HX wheelset? I got a cheap pair of the 1501s for my winter (and spring, summer and autumn) hardtail and actually prefer the silence to the Hope Pro4 hubs I had before. Haven’t noticed the decrease in engagement angle at all (~30 points from the Hope’s 44).
    ads678
    Looks like a Boardman.
