Turbo about to go? Turbo diesels do whine/whistle although modern turbo diesels are quiet. They do whistle/whine a lot when the turbo is on it’s way out…might be worth a check.
I’ve only had wheel bearings go once many years ago and as I recall I couldn’t feel any play in them but the whining and getting less when turning does sound familiar
You’ll not feel a wheel bearing rattle unless it’s properly fubared. They just get grumbly or whiney. Decent garage will take the calipers off and then feel for roughness by hand.
Whilst giving a mate’s girlfriend a lift, I once went sufficiently fast in my old rally car that the whining stopped. Either the frequency had gone above the level that I could hear, or she was curled up in a ball sobbng quietly.
Either way, she didn’t ask for a lift ever again ?
Wheel bearing possibly. Usually won’t see play until they’re absolutely shod. Replaced several that are fine when spinning the wheel but were the cause of the noise.
Its almost certainly the wheel bearing. Don’t leave it too long or it might destroy the ABS sensor which is expensive if a garage fixes it. Don’t ask me how I know.
I had an Octavia a few years older than that, developed a really annoying whine which turned out to be from wind over slightly deformed rear window rubber trim, was a common problem according to briskoda. A very fine application of decent black silicone along the length into the rubber v shaped grooves sorted it. Would fit with what you describe, likely a trim on RHS as the wind angle across it would change and be shielded to an extent through turns. You can trial it with electrical tape
2have been replaced, so do i decide which end of the car it comes from, and replace that, or is there a better test i can do?
so if it goes quiet in a righthander, does that mean its worn on the left or right?
It doesn’t matter if it’s left or right – you do both, but it’s almost certainly the left bearing as during a RHT, the right wheel bearing will be under substantially less load.
You don’t normally do both bearings just because one has gone. It doesn’t affect handling. And IME one going doesn’t seem to mean the other is at the end of its life. They only need doing in pairs if they’re built into a brake drum or disk as a single unit.
But yes, it’s the inside wheel on corners where it goes quiet. Front/rear you can usually figure it out by listening or jack the car up and have a feel, it’s usually obvious once the wheel is off.
Depending on the car it’s either a really quick job or an absolute nightmare depending on how it’s built.
Yes, as above sounds like wheel bearings. Just replace the one that’s gone. But fwiw, when they started going on a Megane I once had, they all went within about 5k miles at around the 80k miles mark. The same car also had sticky/seized calipers later, but that didn’t whine.
I have a dodgy window in my car that’s often a crack open. Sometimes it makes the wind whistle, which of course gets louder as you go faster. It’s only on one side so makes sense that it might stop on certain corners, but I haven’t gone round any sufficiently fast corners to test this.
Anyway, just saying. Wouldn’t want you to take all the wheels off and find that you’ve just left the window open :-p
No guarantee it’s not one of the replaced ones if they were the cheapest no name bearings. Paying extra for something that a manufacturer you’ve heard of will put their name on will be less than the labour to replace a cheap one again and again.
Currently annoyed that 6 years ago I bought the cheapest exhaust I could for the Fiesta, firmly believing that there was no way we would still be driving it in 6 years.
1 new back box
1 extra clamp to cover a rusted joint
and 1 entire new system later I’ve just replaced it with the same again because there’s no way we’ll still be driving it in another 6 years ?
No, they tend to get louder the more loaded they are / go quiet when unloaded.
I remember once having to take an MGF on a test drive for the garage because the customer thought it had a rough wheel bearing. 2 or three of us must have driven it, taking it for it’s MOT, etc, and all came back with a different answer. Turned out it was a front and a rear, a left and a right so whatever way you turned the noise moved around!
If you jack it up it’s usually easy to feel though. There might not be any play in them yet but they’ll feel rough just like bike wheels feel rough when you spin the axle long before they develop play.
