Home Forums Bike Forum Which single crankset?
Viewing 25 posts - 1 through 25 (of 25 total)
  • Which single crankset?
  • quintet100
    Hi
    As above.
    Running 1 by 10.
    Ideally black and light.
    Thanks in advance
    dirtyrider
    RaceFace Next SL
    jobro
    Race Face Next SL for me. Very black and very light.
    Works component ring.
    mattbee
    Yep, another Next SL here.
    jobro
    Use the rubber boots provided though – I didn’t 🙁
    quintet100
    Thanks chaps
    I have a absolute black oval to use.
    njee20
    Next SL. Unless you have a Trek.
    quintet100
    Anything cheaper than NEXT SL?
    I already have XT, but fancy a change if worth it.
    Gotama
    Raceface Turbine? Think that’s where my money will be going shortly.
    robj20
    Sram cranks xx1 or x01.
    wrecker
    TBH, for the money not much beats Shimano hollowtech. I looked recently; Hope are too expensive for what they are. Raceface use relatively pricey proprietary BBs, as do E13.
    You can buy XT for £95 or less, and replacement BBs are £15 or so.
    dudeofdoom
    I had the turbine – non-cinch version and it was nice but pricey at the time(£200) got some of the x1 sram cranks to go on which were £100 and seem nice( Was going for hopes but 280ish spend when I could get a pike for 480 which would make a bigger difference ride wise)
    I suppose it depends on whether its for pimp or purpose 🙂
    bigrich
    zee single ring cranks are basically XT and pretty cheap.
    wrecker
    Zee are very different to XT cranks. Indented at the rear rather than hollow, heavier. More comparable to Deore (stronger axle and pedal inserts)
    rocketman
    Saint
    It’s like having a tailwind all the time everywhere
    benji
    Middleburn RX8 X-Type with there Uno thick thin ring.
    fr0sty125
    Midleburn are heavy these days the new M9000 is very light works out at about 630g that’s with BB and 32t so lighter than XX1.
    monkeysfeet
    Using a Race Face ride . Linky- http://www.chainreactioncycles.com/race-face-ride-narrow-wide-single-chainset/rp-prod113370
    Not sure howlong the BB will last, but at under 100.00 it looks fantastic.
    fr0sty125
    Apart from that it is heavier than SLX.
    Gotama
    I thought the new raceface stuff fit shimano BBs?
    fr0sty125
    Shimano use 24mm RF and SRAM 30mm
    Gotama
    Ah thanks. Puts raceface and sram back on equal pegging then.
    RustyMac
    Only top end rf is 30mm
    30mm. Turbine, next and six others are 24mm
    honourablegeorge
    bigrich – Member
    Zee single ring cranks are basically deore and heavy
    cliffyc
    Shimano XT and Hope 34T .
The topic ‘Which single crankset?’ is closed to new replies.
