Home Forums Bike Forum Which PDA to GPS/ memeory map with
Viewing 4 posts - 1 through 4 (of 4 total)
  • Which PDA to GPS/ memeory map with
  • Junkyard
    As someone suggested in a lower post using one of these which ones do people use / recommend?
    Basically I would only really want to use it for memory map / gps – which I assume most will allow me too and will result in me both knowing where I am on the route/follow a trail I have pre planned in Memory map – is that correct and easy to do? Other functons would be nice but not necessary to convince me to buy but radio or tunes would be nice ans Ia sumem some external memory stick.
    If it runs from less then 5 volts even better (freeloader to charge it on tours etc) and what sort of run times should I expect from one?
    I am not an IT numpty but am a GPS / PDA /Memory map one
    tinribz
    Anything that runs windows mobile will do, as long as it has built in GPS obviously.
    I just installed MM on an MDA Vario III I got of ebay just for doing the GPS thing, unlocked PAYG phone, OS25k maps, MS Office, Wifi tinternet, 8Gb miniSD, syncs with PC, sorted.
    Junkyard
    cheers ebay searching it is then
    woody2000
    Junkyard – I’m selling one – see here (clicky)
The topic ‘Which PDA to GPS/ memeory map with’ is closed to new replies.
