Home Forums Chat Forum What's your favourite conspiracy theory?
Viewing 40 posts - 201 through 240 (of 302 total)
  • What's your favourite conspiracy theory?
  • TandemJeremy
    grantus – Member
    The WTC was designed to withstand the impact of a similar sized plane to those which hit them nope designed to accept a hit from a much smaller plane, 707 sized not 747 sized
    grantus
    you are quoting a small part of what I wrote to make it look like I tried to make an authoritative statement when I did not do that.
    This is a typical way of trying to discredit someone’s opinion.
    grantus
    the nyc planes that hit the towers were 767s which are a similar size to 707s
    not that it really matters as I won’t change your opinions and you won’t change mine
    TandemJeremy
    Not at all grantus. Its just my understanding is they were not designed to survive and impact from a plane that big. Nothing beyond stating that was my intent.
    Northwind
    grantus – Member
    However, a catastrophic failure of the steel leading to collapse doesn’t really explain to a layman (i.e. me!) why all the concrete in the building turned to dust.
    It didn’t. Good enough?
    grantus – Member
    If they burned at over 700 or 800 degrees C or whatever was required to melt the steel
    The steel didn’t have to melt… In fact, it almost certainly didn’t- steel softens long before it reaches melting point, so even if there was anough heat there to melt it (open to debate), the structure would be badly weakened before it reached that point.
    TandemJeremy
    Hmmmmmmmmmmmmm – you are right- 767S. Bigger and heavier than 707s but not double.
    toys19
    you just picked up on the fact I don’t know the precise location of the pentagon to dismiss me as a crank!
    I didn’t read anything in that post that dismnisses you as a crank, I thought he was quite restrained. I think he and I would just prefer you to check your sources before you make such claims. Its easy to do..
    I am not trying to discredit you, but you have stated a position, a hunch, suspicion or whatever, and it is obvious from what you have written that you know very little about what actually happened. So to address your concerns:
    The WTC was designed to withstand the impact of a similar sized plane to those which hit them.
    which isnt accurate – some analysis was done but it can only be that, analysis. The post collapse anlaysis was done with some pretty advanced methods which were not available at the time of the design/build. And no one is really sure exactly what analysis was done with regard to aircraft impact ie what conditions like, airspeed, fuel load etc.
    see this wikipedia entry
    If you take the time to read the wikipedia article you can get an excellent understanding. see this
    Read that and then come back and tell us if you cannot understand how it happened, perhaps we will be able to expalain any of the bits that seem funny to you.
    grantus
    Fair do’s Jeremy.
    Toys19, re. the Pentagon and where it is – it was a question I had in my mind as to why there wouldn’t have been more video capture of events there that day, for example from tourist perhaps – not stating anything as a fact. Regardless, I would have expected TV crews to have been either swarming all over the Pentagon, if not rapidly converging there, at the time of the explosion in Washington as this was forty minutes after the second attack in NYC and therefore clear that it was not an accident. This is why I am surprised there is no footage of the Pentagon incident other than the very grainy CCTV camera where you see a flash of something then an explosion. I, personally, find that surprising and therefore suspicious.
    Northwind – I agree – my use of the term ‘melt’ is simplistic. To weaken to the point of structural failure is of course the correct terminology. What I find hard to understand, however, is that the steel would need to fail almost instantaneously at virtually every location in order for the building to come down within it’s own footprint – for example as we see in controlled demolitions when strategically place charges are detonated at the same time.
    However, in my mind, I would expect the random nature of the impact to have caused failures in some areas and not others. Failures which could perhaps cause catastrophic collapse but not in the manner in which it happened i.e. a partial collapse or a collapse to the side, for example. This is why I have trouble accepting the official version of events. Now, if every source explained why my simple thinking was flawed and therefore wrong then fine. Problem is, there are a lot of far more knowledgeable people than me who have argued this viewpoint in greater scientific detail. (and i’m not talking about the David Icke types out there)
    To toys again, it is no good posting links that explain it. The point I am trying to make is that there are other sources which also make conflicting arguments with equal eloquence and professionalism which argue that there must be other contributing factors to why, for example, the buildings collapsed in the way they did.
    The internet is full of people who debunk the official version with compelling arguments and evidence, and vice versa. Both make convincing arguments if you take the moral issue away from it. i.e. if you don’t think about the evil behind the act (whoever perpetrated it) then both sides of the fence make compelling arguments.
    However, when you factor in how unthinkable it would be for someone to plan and/or allow such attacks to take place on their fellow citizens with their knowledge then, I agree, it almost does become too hard to accept as it goes beyond almost* anything we have seen in human history in terms of man’s inhumanity to man.
    *while almost being beyond anything evil history has recorded, it is not as bad as the worst examples we know about i.e. the Holocaust and the Gulags, etc. People are capable of wicked deeds in the pursuit of power and money. In answer to your sarcasm, I don’t find any of this funny at all.
    I think there is more to those events than the official story. Let’s agree to disagree.
    toys19
    I disagree with this, if you follow all the work done by the conspiracy theroists it is easy to prove it wrong. Just because there are differing opinions does not mean you can give them equal weight.
    grantus
    fair enough mate. At the end of the day there are good people and evil people and a lot of good people died that day and since as a result.
    Thing that struck me when watching a lot of the programmes about it this week is that you can seethe emotion on the faces of the people who lived through it i.e. The fire fighters, police, people on the street, rudy giuliani, etc. But when you see the likes of rumsfeld and cheney – these to me are wicked, unfeeling people. Not a flicker of emotion on them. as for bush – he is just a buffoon. not saying this is any sort of sign of guilt or whatever that others sometimes insinuate – more of an observation about what does and doesnt matter to these people.
    As for dubya, if the quote attributed to him is genuine, that he said he watched the first plane hit live and he thought, man, that is one bad pilot – then that just epitomises his buffoonery.
    Elfinsafety
    This is an accusation which can just as easily be levelled at you, toys.
    Got to ask; other than what the rest of us have in terms of info about 911, what is it that you know makes your onion so much more valid than others?
    Really?
    Go on then.
    No really, I’d like to see you prove the claims made by the Official Enquiry absolutely irrefutably correct, and those made by anyone questioning the Official Enqiuiry, with it’s numerous omissions and innaccuracies as wrong.
    Go on.
    Considering you have only the same information as any of us.
    Go on.
    Before you attempt to dismiss any alternative views, prove that the Official Enquiry’s results are the Absolute Truth.
    I’m off on holiday for a while. Have fun.
    X
    RamseyNeil
    Agree with Elf and Grantus although I couldn’t have put it as well as Grantus . My favourite theory is that that dangling a little strip of plastic from the back of a car to touch the road would stop you getting travel sick .
    I think there is definitely a lot of suspicion about Dr David Kelly cutting his wrists to kill himself , also I thought it ” convenient” at best that Robin Cook died of a heart attack while out walking in the hills after he had a big fall out with the government .
    Elfinsafety
    And as for the senseless slaughter of thousands of innocent people on 911; why do you think the Powers That Be care any more for those souls than the hundreds of thousands of innocent souls destroyed during the Iraq and Afghanistan conflicts, not to mention countless other theatres of war worldwide that the US has bin involved in?
    Do you know what the word ‘expendable’ means? Ever heard of the term ‘Collateral Damage’?
    Kevevs
    Golf is a weird organisationation of people with small balls and sticks wandering around on some Organisised tidy bit of grass and somehow plotting world domination before their wife knows they have gone.
    MrSalmon
    I don’t think it’s about whether you believe that They would ever do such a thing- I can believe that They might do some pretty surprising things if They thought it would further Their aims and that They’d get away with it.
    But beyond that, actually carrying it out stretches credibility too far IMO. For instance, why the planes at all, if the plan is to blow the towers up anyway (making sure to do it just the same way as a regular demolition, of course). Doesn’t make sense to me.
    Why would you demolish a building like that if you were trying to make out that that’s not what happened? Never mind setting it all up with nobody noticing.
    On the other hand, I can easily believe that very tall buildings that have been hit by airliners might behave in seemingly surpising ways.
    ernie_lynch
    You don’t believe that do you ?
    He was pushed.
    toys19
    Well I can’t say I really disagree with this, but not giving a sh*t about 3000 dead does not make you guilty of killing them. And tbh what they have perpetuated in Iraq, afghanistan and elsewhere is sickening, an awful lot worse than sept 11th.
    Aside from the obvious, it is a fantasy to believe that 9/11 was perpetuated by the us govt, they couldn’t even keep a blow job in the whitehouse a secret.
    I’m happy to consider that they/someone might have known about it coming or may have even helped in some way by keeping security lax etc, but controlled demolition and missles is just a load of crap. TBH as far as Bush was concerned I thinkhe must have thought all his Christmases had come at once. But I still don’t believe in controlled demolition, missiles or any of that. (you might also be able to convince me that U93 was shot down, what everyone fails to consider is that a fighter jet has armaments it can lock on and fire at an airborn target from about 100 miles away, so knowone would have seen any jet, they could aslo have done it with a SAM from even further away, but I think its highly unlikely, as the consequences of being found out are too great)
    The problem with conspiracy theroists is that they often ignore science to further their politics, I imagine grantus and elfin that our politics on iraq, the war on terror etc are the same. But you guys discredit your aims by pushing a fantasy, and exposing a lack of logic, reason or thought.
    Grantus by admission you are a layman, I guess you mena you arent science/eng so maybe you would find it hard to understand the way the towers fell, in which case I don’t see that you have any right to pass judgement on wether it’s true or not when by your own admission you cannot understand the evidence.
    Elfinsafety
    Golf.
    Now that’s definitely a conspiracy…
    Oh behave yourself Toys. Loads of science stuff from ‘conspiracy theorists’, not least physical evidence suggesting the possible (note, ‘possible‘) use of thermite charges.
    And other stuff. Just Google it; that’s how you’ve got most of your information after all. 😉
    In fact, the suggestion that al three (yes, WTC Building 7 too, remember that?) towers were brought down in a manner identical to a controlled demolition, isn’t all that preposterous at all, if you actually look at the scientific evidence. scientific evidence which seems to have bin deliberately ignored by the Official Enquiry.
    Then there’s the seismic reports which suggest several ‘spikes’ in seismic activity which are virtually identical to sudden explosions….
    The problem with narrow minded sheep is that they often ignore actual scientific evidence rather than what they’ve bin told to further their politics….
    Ooh, I’m cleverer than you cos I’ve got a bit of paper proving it which means I can be condescending and derogatory towards you…
    TBH Toys; you’re coming across as quite narrow minded and unwilling to consider alternative theries and possibilities, tbh. Seems like you’ve already made your mind up, and cant abide anyone challenging that which you have chosen to believe in, as that threatens your fragile sensibilities.
    Almost evangelical, in fact….
    Northwind
    grantus – Member
    But no, it doesn’t. There’s 2 stages to it, a progressive first stage and a catastrophic second stage. If you were to collapse the building in a single process then yes, it’d need to be simultaneous (controlled explosion, basically), but that wasn’t what happened.
    First stage is the building slowly weakening- individual parts of the structure weaken and deform. Comulative process. Then as parts fail outright, the other components get overloaded and fail in turn til eventually, the top section drops onto the bottom section. But clearly there’s no need for this all to happen in the blink of an eye- it’s no different to a wheel collapsing or similiar cumulative failure.
    The second stage of the collapse comes after the top section falls onto the bottom section. It’s a much faster process, effectively it’s a hammerblow… So the top section doesn’t have to fall perfectly square onto the lower section, all it has to do is fall.
    Lots of people believe that for the buildings to have landed as they did, the top section must have fallen absolutely straight down, right? And that proves that it must have all failed simultaneously, because otherwise it would have fallen at an angle?
    Kevevs
    “science stuff” so that’ll be the double blind, absolute no, incontrovertible stuff that exists only then?
    Elfinsafety
    Or so I want to believe it anyway
    FTFY.
    Northwind
    There’s one thing I really like about conspiracy theorists… They look for multiple pieces of evidence that they think contradict the official line, but they rarely care whether those pieces of evidence contradict each other. For example:
    Controlled demolition using thermite- not explosives, because there were no visible or audible blasts.
    Seismic charts which people say indicates explosions.
    People will happilly use those both as evidence even though they’re mutually contradictory. It’s like trying to refure an alibi by coming up with eyewitnesses who can put the person in 2 different places at the same time.
    grantus
    I am a layman indeed no structural engineering background other than one first year module and no fire engineering kowledge other than steel increases in strenght undr intense heat up to apoint where it then starts to soften. my basic understanding of physics is that every action has an equal and opposite reaction and that if you drop something it falls against normal air resistance on earth it accelerates at 10 metres per second until it reaches terminal velocity of around 120 metres per second.
    the towers apearr to fall without resistance. one would expect resistance from the unaffected lower floors
    piedidiformaggio
    You lot all so flipping stupid!
    You’re all blind to what really happened – planes on invisible conveyor belts
    Northwind
    grantus – Member
    No they don’t! Look at any video of the fall, the debris that falls clear of the building falls faster than the main structure, and the main structure takes considerably longer than freefalling would have taken. There’s a pretty good debunking video of this…
    Elfinsafety
    Have a little read up of stuff then it might be a little clearer to you.
    Basic thermite preparations can be modified and augmented in various ways to change their properties. The fineness of the aluminum powder determines the speed of the reaction. The use of ultra-fine aluminum powder gives the reaction an explosive quality, resulting in ‘super-thermites’.
    What I love about ‘conspiracy theorist debunkers’ is that they often ignore lots of stuff to try and seem all clever and that. 😉
    Maybe you had your playback on slow-mo: the towers all fell at a considerable speed, and according to many demolition experts, in exactly the same manner to a controlled demolition….
    How long will this argument rage for? Several days? Weeks? Months? Years?
    Until the Real Truth comes out?
    grantus
    Northwind i must admit it does annoy me that folks are labelled conspiracy theorists in such ways.
    i grew up in the 80s with a thatcher and reagan hating father lol! But i kinda thought americans were the saviours of the free world. america to me was everything good about the world. as i got older i read more and discovered that the uk and – post ww2 – america were responsible for not only a lot of good in the world but also a depressingly amount of bad.
    To study post ww2 american history in terms of foreign policy is eye ipening in the extreme. from italy in 1947/8 through to central and southern america in the 50s through the 80s to south east asia. not to mention abuses domestically via cia black operations which are now undisputed matters of fact i.e. Mk ultra, bioligical and chemical experimentation on unsuspecting civilian populations.
    The last 50 years of american expansionism has been fascistic to the extreme. it is logical to think that, no matter how abhorrent a regime, the americans could never attack their own people as it goes against all tenets of freedom, liberty, democracy – the american dream. however, is it not a fair statement to say that subsequent generations move things on in relation to the actions and behaviours of their predecessors? I.e. In the 50s and 60s the right wing of american foreign policy considered how the shooting down – or mock shooting down of an american passenger liner over the gulf of mexico would validate an invasion of cuba in order to protect america and consolidate power abroad i.e. Get rid of comrade castro. perhaps a step too far for even those policy makers. fast forward 40 years. Times change? who knows but viewed in light of the publicised strategies of PNAC could fact be stranger than fiction??
    SaxonRider
    grantus – Member
    This entire thread is worth it just for that statement. You have my complete support on that one, grantus.
    grantus
    To be honest, i have, like everyone else, must have seen the collapse hundreds of times and i have nevr seen a video which shows anything other than virtual freefall of those structures.
    Those poor people – i only hope it was bloody quick for them 🙁
    Elfinsafety
    How come Grantus is not being subjected to the kind of vitriolic crap I was earlier in this thread? 😕
    Izzit becoz I iz Elf?
    Junkyard
    It will rage for ever elfin because facts dont sway those who believe in the conspiracy and look for its evidence everywhere.
    Could they have done it ?Possibly
    Could they have done it without anyone in the know saying anything? Less likely
    Would they do it? Even less likely.
    Occam’s razor put this hypothesis on pretty weak ground tbh and the evidence to prove it is less than overwhelming.
    Elfinsafety
    Really?
    Why?
    CaptainFlashheart
    FFS…..
    Northwind
    Elfinsafety – Member
    Fraid not… The seismic traces are said to be proof of large explosions. Fast thermite is not the same thing- having “an explosive quantity” doesn’t turn thermite into a large-scale conventional high explosive. And the reason the theorists were so enamoured of thermite in the first place was specifically that it got around the awkward lack of large explosions.
    You can have exploding thermite, but you can’t have exploding thermite and no explosions. If you actually want an explosion, you wouldn’t use thermite at all.
    Slow-mo footage wouldn’t cause some debris to fall faster than others now would it? Try harder.
    Most conspiracy theories are at least plausible, but this one doesn’t stand up to even casual examination, it’s just pure misinformation.
    Elfinsafety
    No come on Flashy, don’t just come on and say ‘FFS’; say what you really think.
    Come on, don’t be shy…
    Northwind; so, you’re an explosives expert now? 😆
    Behave yourself. Seriously. Look how much effort you’re putting into ‘proving’ the ‘conspiracy theories’ wrong. Yet you’re actually proving nothing.
    Waffle wibble blah blah bullshit please believe me…..
    grantus
    Elfin is cos you is black and smoked the ganja then hid it from the police with your white friend!!! – i saw you admit it on another thread lol! – or am i confusing you with ernie lynch??
    ernie_lynch
    Cheeky git.
    Elfinsafety
    I am not black, I am brown. 😐
    I cannot possibly comment about the Ganja. Suffice to say that Babylon Dem is no capture de Elf.
    No, it’s cos I’m always right on this forum, and the wrong-uns can’t handle that. 😀
    It’s as simple as that.
    Northwind
    Nope, I can merely read and think 😉 You don’t need to know much to see through the feebleness of some of this. And TBH I don’t think you believe most of it, if any.
    For your free-falling building to be true, the genuinely free-falling debris must have fallen faster than gravity. Rocket assist? Elastic bands? You don’t need to know a thing about explosions or buildings to see through the nonsense, you just need eyes, and the ability to count past 9 seconds.
    As for proving- I’ve not proved anything. I’m out to debunk nonsense. It’s conceivable that some of the theories are true, but many aren’t (and some contradict each other).
    Grantus- no offence but you’re seeing what you want to see. Time it out, watch the debunk videos (with a cynical eye!), look at the free-falling debris. It’s a lie.
    grantus
    Saxonrider, unfortunately it seems to be an inbuilt trait of our western politicians.
    I do believe gordon brown and john major were/are decent men. Blair and thatcher – 2 peas in a pod.
    As for usa, obama and mccain i both think are honest men. God forbid what happens after obama has to stand down.
    Mccain will be too old – palin!!??!!
The topic ‘What's your favourite conspiracy theory?’ is closed to new replies.
