Am I the only person who doesn’t see this as an issue?
I assume you must be. As everyone who is interested in mountain bikes & does a bit of work on them are universally aligned in how stupid an idea it really is.
MTB headset bearings generally don’t last that well from new, as most brands skimp out & use some tat like Acros, so now your simple, easy bearing replacement involves a brake bleed & an overly complicated headset made up of ill thought out parts, with a bunch of uncooperative cables/hoses.
Which, speaking of cables, get absolutely savaged in the steerer tube area, meaning more regular maintenance and checks, just to make sure a gear cable or a dropper post isn’t literally sawing through your steerer tube, without you even knowing.
The looks thing is also subjective. Personally I think it looks terrible. Cables are bend at un-natural angles & it also compromises performance because the radius of the curve is tighter (more of an issue with a dropper post).
And yes, we have a bike with it, and having ridden bikes for a long enough period of time to see some stupid sh*t by brands, this is universally the most stupid design I have ever seen on an MTB.
