Home › Forums › Bike Forum › What’s like a Transition Spur but not £5k, not a boat anchor, and available?
- This topic has 56 replies, 38 voices, and was last updated 3 years ago by charliemort.
coreFull Member
I’m perhaps asking for a unicorn bike, I know, but humour me if you will…
I’m curious to try a modern 29er as my last experiences were with 70° head angled hardtail XC bikes – I switched back to 650b for general local riding (Welsh Marches) as they just didn’t suit tight, twisty, rooty trails, though I did like the big wheels everywhere else.
The transition spur is my perfect bike on paper I think, but I don’t want to spend £5k, and I’m not financing a bike. Obvious Cotic answer is a FlareMAX but they’re a way off delivery. The new Jeht (~£3500) with a 140mm fork could fit the bill perhaps, but likely to be 33lb+ on a silver build, as opposed to 28lb ish with the (much more expensive) Spur.
I only have one MTB at a time, so it needs to do everything – XC rides, the odd marathon event, FoD, BPW occasionally, and those nadgery local trails. I’m a mostly wheels on the ground rider.
So is there anything in the £2.5 – £3.5k range that sounds suitable that I’m missing? I’m not after a Specialized, Trek or Giant, or Canyon.
euainFull MemberBird? AM9 or Aether 9 depending on what fits your requirements better. (Seems to be all I type on the forum these days, but I’m very impressed with the AM9 I recently got for my lad).
jimdubleyouFull MemberSpur was on my list, but I bought a YT Izzo instead. Just looked and they only seem to have two models listed, the factory bling Pro Race or the Blaze (which is out of stock).
I suspect you’re going to be seeing the same deal with a lot of manufacturers well into 2022.
hatterFull MemberThe new Specialized Epic seems to be in a similar vein but personally I’d just sell a kidney, get a paper round or whatever and get the Spur.
It sounds like that’s what you really want, if you have to wait a while that just gives you more time to scrape the money together.
chakapingFull MemberMay I suggest what I have? It is the custom, after all.
Secondhand Orange Stage 4 with a -2deg headset and 130mm fork.
Weighs 29lbs with an everyday build and light-ish wheels (Mavic XA), and has a very lively, engaging ride. It’s 30-31lbs with burlier wheels/tyres.
Totally different beast to a Cotic FSer, much more “downcountry” and poppy rather than planted.
The new Stage Evo would probably be slightly better, but more £££s.
BillOddieFull MemberBanshee Phantom?
115mm at the back, nice angles and lengths. I have it’s bigger brother (The Prime) and whilst only been 4 rides, I’m very happy with it.
Give Pedals Bike Care a shout and they will let you know if they have one. @Pigyn
shop@pedalsbikecare.co.uk // 0131 629 6065 // @pedalsbikecare
wonnyjFree MemberThe new Propain on the front page of this website looks very Spur like to me, even down to the colour and styling. Slightly longer travel but same sort of idea. Better spec for less money as well.
matthamFull MemberOn the Propain, I think I’m right in saying that the £3500 bike tested will be £4700 ish with VAT (20%) and import duty (14%) I think. Happy to be corrected as I really like the look of it!
inthebordersFree MemberThe transition spur is my perfect bike on paper I think, but I don’t want to spend £5k, and I’m not financing a bike. Obvious Cotic answer is a FlareMAX but they’re a way off delivery. The new Jeht (~£3500) with a 140mm fork could fit the bill perhaps, but likely to be 33lb+ on a silver build, as opposed to 28lb ish with the (much more expensive) Spur.
Not really comparing like-with-like though – at most the Cotic will be 1kg/2lbs heavier (as steel/alloy vs carbon) with an identical build, based on me going from a carbon Camber to FlareMax (and about 100mm longer).
And under the recommend what you have – get a FlareMax 🙂
OnzadogFree MemberRevel Ranger is often compared it that same category as the spur and is very well reviewed.
coreFull Memberintheborders
The top Spur build is 25lb by all accounts, with a Jeht coming in at 33lb with a higher level build from Cotic. FlareMAX should be a bit lighter with less travel and slightly lighter tubeset. In reality I guess the Spur GX will come in at maybe 27-28lb, and a similar build on a FlareMAX at 32-33lb. The weight is only one factor, what I’m really after is something that covers ground well, but FEELS responsive and involving to ride.
stanleyFull MemberRecently bought a SC Tallboy and could not be happier with it.
North West Mountain Bikes had a few in… base model would be within budget (ish).snotragFull Memberwhat I’m really after is something that covers ground well, but FEELS responsive and involving to ride.
In which case…
Thats my old bike – definitely that. I would really, really like to have a go on a new Stage Evo.
The Stage 4 was super fast, agile, and ‘feels’ really fast. I loved it but went for a longer travel plusher replacement as i have multiple bikes. If I could jsut have one MTB – it would probably still be that (or the Stage Evo, or maybe a Stage 5).
idiotdogbrainFree MemberKona Hei Hei sounds like it could be a good bet if you can find one.
snotragFull MemberOh and theres a nice looking 2020 Kona Process Carbon 134 on Pinkbike currently too I spotted. Would make a good build on the right kind of lines.
argeeFull MemberJust get the spur, everything else is just a lesser option for you, i even believe tweeks have stock of some spurs!
chakapingFull MemberOh and theres a nice looking 2020 Kona Process Carbon 134 on Pinkbike currently too I spotted. Would make a good build on the right kind of lines.
Good shout, I can vouch for the seller if it’s the one I think it is.
Perhaps the Nukeproof Reactor is worth a look too? Or the new Stumpjumper (not Evo).
jonnyrockymountainFull MemberOrbea oiz 120mm on pink bike at mo
https://www.pinkbike.com/buysell/3028469/roverpigFull MemberIt’s a pity Orange dropped the Stage 4 from their lineup as that would be a good shout. The Stage Evo sounds like it’s more of a trail bike than the XC/trail (or whatever it is called) of the Stage 4
lawman91Full MemberHonestly, sounds like you need a Spur. Nothing gets too close in terms of weight and geometry. Heavier bikes get close geo-wise, steeper, racier bikes get close on the weight. A Spark is a close match weight wise and the suspension is similar (taking the pointless twinloc out the equation).
I’m biased as I’ve got a Spur, but honestly, it’s bent my mind with how fast, fun and capable it is. The thing just generates grip and speed like nothing I’ve ridden.
I’ve just put the Rekon rear tyre on the front and a put a new Rekon Race on the back and honestly it now feels as fast as any proper race bike I’ve ridden but can still be proper trail hooligan. I rode a friends Tallboy recently and it felt nowhere near as fast. It might have an edge on really rough terrain, the kind where you think a 120mm bike is probably under-gunning it, but everywhere else, it’s not as good IMO.
The Spurs are pricey, but the back up is great from Transition if you need, they look amazing and are beyond fun to ride. I adore mine!
dropoffFull MemberThe Yeti sb130 is a thing of beauty, unfortunately suffering with the same sort of price tag.
pigynFree Member“Nothing gets too close in terms of weight and geometry”
https://www.instagram.com/p/CGLGj4bHo6J/?igshid=1kd3xotk2suzf
slackboyFull Memberhttps://www.instagram.com/p/CGLGj4bHo6J/?igshid=1kd3xotk2suzf
Do you actually have project DC frames for sale now?
My flaremax came in at around 34lbs, so not light but it did climb well and was very stable downhill. I think the frame weighs around twice as much the spur.
I’ve changed to a more xc bike as that suits my riding, but if going back to Cotic I’d get a jeht as you’re getting the extra travel for no real additional weight penalty over a flaremax.
bonniFull MemberThe Spur is a thing of beauty and would be close to top of my wish list for 75% of my riding, but some arguably similar genre bikes are out there, some for less eye-watering sums.
Marin Rift Zone
Norco Optic
Whyte s-120
YT Izzo
Canyon NeuronMore XC-marathon end of things, but still pretty capable:
Pyga Stage Max
Giant Anthem, particularly the 27.5″
Scott Spark
Second-hand: Rocky Mountain Instinct (not sure if they have been discontinued)coreFull MemberI think YT might be getting my money if they had stock of the Izzo, sadly they haven’t. But I can’t find a Spur in stock in a large anywhere either, in any colour – though I’d want the grey, and colour is important if you’re spending that sort of money.
I’m quite taken with the Tallboy but think it may be a bit too plush and trail taming for what I want?
pigynFree MemberHaha, we do ‘sort of’ have them for sale, but it has been the worst frame launch of 2020, well, behind the Spur!
We ordered SIDLuxes for them from Rockshox, there was a delay in the order being given to RS themselves and in those three weeks the lead time jumped from 60 days to 160. It’s now apparently 300 days+. We ordered a small batch of frames to arrive a few weeks before the shocks, then the shocks went back. First to November, then end of April. We actually have a Fox setup ready to ship, DPS Factory Remote with Orbea Squidlock lever, same as the build in that insta post, and hopefully the SIDLuxes will be here soon and it will be finally ready to list for official sale.
We won’t pretend it’s our design, although it is very close to what I would want. In an ideal world I would re-jig the pivots to get better seatpost insertion, but I still have an easy 160mm drop on the medium. It’s an open mold frame that other manufacturers have access to (I have seen it being raced in XCO), we have worked to get a decent shock tune and a few finishing touches to hardware in the UK. I ordered the samples last year to test whether or not a short travel aggressive geo frame would work, with the idea to get a light hardtail built with similar geo in the UK. But then it arrived and we fell in love with it, honestly just a hoot to ride and suits our local stuff perfectly. So we ordered some more rather than doing the hardtail. The Spur is amazing too, or at least the two we have been able to sell are apparently!
Frame with DPS Factory + Squidlock is £2199 and with SIDLuxe is £1899.
A medium is 470 reach, 66 HA, 76.5 SA, 438 chainstay. Large goes to 500 reach and XL is 515 I think, from memory. Max 120mm front and 110mm rear.
My girlfriend and I fight over who gets to ride the sample I have here 🤣
BearBackFree MemberPigyn’s FM936 looks great painted and a really really nice looking build!
I’d prefer the FM1001 though from Carbonda if you’re going the open mold route and gets you 120-135mm rear, 140 up front, a litle closer geo to teh spur and I’m a fan of seatstays and top tube being close to in line. (Spur, Last Cinto)
Hats off to Pigyn as addressing the shock tunes and Chinese hardware weaknesses gives a great value add!
Maybe there’s scope to have him delve into and improve other frames from Carbonda?
I’m about to pull the trigger on the FM1001…mostly because I have a 185×55 DPS and a 140mm 34 on hand.inthebordersFree MemberI guess the Spur GX will come in at maybe 27-28lb, and a similar build on a FlareMAX at 32-33lb.
So with ‘similar’ builds you think that a Spur will come in 5lbs lighter?
Your definition of ‘similar’ is obviously different to mine…
reggiegasketFree MemberCube Stereo 29 looks similar, and can be had for <£2500. Not sure on real weight though.
The Spur frame is probably 3lb+ lighter than the FlareMAX, so perhaps not 5, but I think 3 or 4lb is realistic. Then comes the real question – does it really matter…
mudeverywhereFree MemberFrame with DPS Factory + Squidlock is £2199 and with SIDLuxe is £1899
Is that the same frame as a Vitus Rapide FS? Which is 2.5k for a whole bike.
militantmandyFree MemberStarling Murmur with short travel option? Might have some hope of actually getting one. Many good bikes suggested here…but can you actually get any of them? Got to say though, if I was in the market for something like a Spur, I think I’d be buying a Spur.
https://www.tweekscycles.com/transition-spur-gx-full-suspension-mountain-bike-2021-2012364/
lawman91Full MemberThe Smuggler, particularly the later SBG frames, were heavy AF. close to 9lb for the frame and shock. You’d have to work very hard and spend some serious coin to get one under 30lb, let alone the 26/27lb build for the Spur. FWIW, my Spur (large GX) was 12.4kg without pedals when I got it, it’s now at 12.3kg (now with XT trail pedals) with a few upgrades.
Fair play Pigyn, they look great, is the frame the same as the NS Synonym? Looks very similar on paper. The only gripe I have is the seat tube on the large is super long, otherwise you’re spot on, it’s a very good comparison to the Spur. I just find it crazy NS charge so much for a catalogue frame built into a full bike!
The topic ‘What’s like a Transition Spur but not £5k, not a boat anchor, and available?’ is closed to new replies.
