Home Forums Chat Forum What was the last thing you repaired?
  • This topic has 360 replies, 195 voices, and was last updated 1 month ago by Daffy.
Viewing 40 posts - 1 through 40 (of 361 total)
  • What was the last thing you repaired?
  • twrch
    I really enjoy fixing things, and getting more use out of discarded (or cheap!) items. As a complement to the “What was the last thing you made” thread, to start things off here’s my latest effort.
    We got a pedal-powered digger toy for free, probably because it was missing the steering wheel and mechanism. I finally got around to putting something together:
    Repair 1
    Repair 2
    Works a treat! At some point I should sort out those sticking-out bolts.
    The little boy initially burst into tears because it wasn’t a steering wheel, but he soon got over it. Might be fun to make some kind of trailer next.
    ElVino
    not in your league but fixed my non functioning dishwasher by tilting at a 45 degree angle, freeing up the float trip switch. Saved me a £60 call out charge 🙂
    longdog
    Oven knobs had split so they rotated on the spindle. 5 minute epoxy and job’s a good’un.
    scc999
    Repaired a broken floor tile in the kitchen along with putting a support under the break to hopefully prevent it happening again.
    About to try and diagnose then fix an issue with the screen on a friends Lenovo laptop. I suspect the screen cable to be to blame – we’ll see.
    jimw
    Not exactly a repair, but the extending tv wall bracket I bought was poorly designed which allowed the second arm to dip under the weight of the tv as the bushes that held the spindle about which it rotated were loose fitting plastic. This meant that if the tv was horizontal when against the wall, it listed about 5degrees to the left when extended and if adjusted to be horizontal when extended, it listed against the wall.
    So I made an alloy bush that cured the problem. I don’t have a lathe so bought some thick walled alloy tube, drilled it out and then reamed it to the correct size by hand V. happy that it has worked.
    sirromj
    We’ve been given one of those exact same diggers. The red bits for hooking the arm up in front of the steering wheel broke, so I just removed the whole arm piece. Our 4yo boy is finds it difficult to play with as it’s so big for him but removing the arm mechanism helped. I really want to steal the wheels off it to make a barrow for the garden though!
    northernmatt
    I put new batteries in the TV remote
    tthew
    You should do it sooner rather than later, they look like an accident waiting to happen.
    dirtyboy
    Replaced condenser and compressor on my Honda civic air conditioning system.
    A black car with no AC is orrible.
    hatter
    Washing machine, worked out the motor needed new carbon brushes, never done it before, bit fiddly and awkward but managed it, fired up first time.
    +5 husband points for me.
    shortbread_fanylion
    Shower was cutting out during the wife’s mega showers – replaced the solenoid for a tenner and all’s working again.
    WorldClassAccident
    I healed after my last injury if that counts
    daftvader
    Last thing was the oven, fixed the pressure switch on the door and replaced the fan motor. Prior to that was a heating pipe that I slightly drilled into 😇
    plus-one
    Fixed my track pump(rubber washer had cracked) new washer I found in my box of tricks. Pumping away an normal now 🙂
    superleggero
    Replaced the elements in a Dualit toaster. Ordered spares from the factory and watched a ‘how to’ video on YouTube.
    1
    stumpy01
    The lift off bit of our vacuum cleaner fell over and the tab keeping it shut snapped off…
    IMG_20190925_211633 by STW stumpy01[/url], on Flickr
    I designed these bits in Fusion 360, printed them and fitted them.
    Still going about 3 years on…
    IMG_20190914_103756 by STW stumpy01[/url], on Flickr
    IMG_20190925_212639 by STW stumpy01[/url], on Flickr
    martinhutch
    Washing machine rubber door gasket. Needed a new jubilee clip to hold it on, so bodged it with a chain of zip ties while I waited for it to arrive. Zip ties still holding well, six months later.
    bikesandboots
    Pedal bin linkage.
    I’m not sure repairs above involving buying a replacement part and fitting it should get a full point.
    oldmanmtb2
    Made a new choke lever/mechanism for my petrol leaf blower….
    Yep baby Robin death machine
    nick1962
    S*** never thought of that just ordered a new TV 🙂
    Glued a glass oven door back on recently can’t believe they are only held on by glue.Also sourced and replaced the carbon bushings for the motor on the washer.
    Still can’t get the fridge light to work.It’s not the bulb but something to do with switch that turns the light on when you open the door but it’s a built in and I can’t be arsed dismantling everything to get it out.Similar problem with the oven light,the housing disintegrated when i tried to change the bulb.Mind you the hob ignition is also goosed.I know this as it wouldn’t stop clicking even when not in use so I pulled all wiring out to cure it.Think it’s probably time for a white goods upgrade.
    woody2000
    Cheap crap exercise bike for the MIL. Belt had snapped, £5 for a new one and half hour or so of tinkering = maximum brownie points 😄
    40mpg
    Just this evening helped my daughter replace the wiper motor in her aging clio. And un-bung the drain holes which meant it had been sitting in a trough of water.
    AA man had told her it would cost £300 at a garage. £25 for a new motor, sorted.
    Only tricky bit was getting the leverage bits in the right place so the wipers went up not down. Which we only realised once we’d reassembled all the plastic covers etc doh!
    drnosh
    Unblocking scuttle drain holes is a regular part of the car washing routine at Nosh Towers,
    jeffl
    Replacing the piezo ignition lead for one of the burners on the hob. Fixing a new drain hose on the seconds hand washing machine as the previous owner, my dad, decided to cut it off 🙄. Fixed the garden fence, post and gate that were rotten by replacing them all. Oh and a new bulb for the number plate light on the car so it passed the MOT.
    God I’m such an awesome middle aged, middle class white bloke 🤣
    dmorts
    @40mpg
    aging clio
    Have you checked the bonnet catch recently/ever? They’re known to fail if not maintained and it’s a fault Renault acknowledges can happen
    yiman
    Today was unusual because I repaired/fixed a couple of things.
    1) The U bend on the bath waste. It’s been leaking for months, with an empty ice-cream container underneath it collecting the drips. Today I fixed it (I think) with a replacement costing the princely sum of £5.18
    2) My son’s schoolfriend’s bike. A bmx with the rear wheel nuts slightly loose so the wheel had been pulled up the sliding dropouts and the chain had gone slightly slack. The poor lad’s dad died in his sleep a couple of months ago so I was more than happy to help.
    reeksy
    Recent successes:
    – The kid’s Dirt jump – needed a bit of a kicker on it and lengthening
    – Water main – we have a 350m driveway, after it was graded there was a significant leak. In trying to locate it I created an even bigger leak, which i eventually fixed before finding the original leak (operative had driven into a valve causing an underground connection to loosen) and fixing that. A weekend i’ll never get back.
    Failures:
    – Waeco fridge … i’ll just get the casing off to replace the thermostat – nek minute covered in refrigerant.
    – Youngest’s bike’s headset clicking 🙁
    p7eaven
    The lip/handle of the lid of the chest-freezer. 6:30am and it stinks of epoxy in here. So far 2021 feels like being stuck in the worst parts of the 1970s.
    yourguitarhero
    Replaced the ignition switch in my van with one from an Austin Metro. Required some cutting and crimping to the old multiplug
    Hand drilled out the pinlock hole in my motorbike helmet visor to fit a pinlock branded insert so now I can see through a non scratched and non foggy visor
    Kitchen cabinet downlighter
    Bathroom fan
    Oven fan
    Washing machine brushes
    ^ they’ve all been this week. I generally find 2 or 3 things I need to fix per week.
    Annoyingly it’s always something new so I’m learning from scratch every time. Guess it means my fixes generally work!
    molgrips
    Mercedes
    Same. It’s good to do, but once you realise you can then you have endless jobs.
    Daffy
    10 year old 55″ TV. Lost a little brightness at the bottom and would occasionally turn off. New back (side actually) lights from China (the only place with new parts) and 3 hours later and we have a nice functional TV again. No landfill!
    richmtb
    Old Hope Mono M4 brakes from 2008. They’d been languishing in a box for 10 years. Stripped them down cleaned all the pistons and replaced the reservoir cap. A full bleed and new pads and they are as good as new.
    p7eaven
    @Daffy – nice job!
    grahamt1980
    I had the apparently known mazda rattly speaker issue in the car.
    Took the door card out, removed the speaker and glued the speaker cone back to the frame.
    Probably cost 50p and half an hour of my time against £100 or so for a new speaker.
    Crap design
    Murray
    My track pump
    Replaced the o-ring on the piston and then undid all the damage I did by greasing the wrong parts
    tonyd
    15 year old gore waterproof jacket – velcro cuff adjusters were delaminating so I’ve literally just super glued them back together. Glue is drying as I type.
    pocpoc
    Nintendo Switch joycon repaired for my lad. L1 button wasn’t working. Stripped and cleaned and still not working so £6 for a new button and ribbon cable. Replaced that and one happy son. And one happy me saving £40 for a new joyon.
    Also replaced the sticking timer on our 14yr old Dualit toaster, but they’re designed so that you can do that. Does it still count?
    thenorthwind
    Fixed my 1/2″ router which was cutting out under load. I thought I’d just killed the cutter fitting oak worktops and was pushing it too hard, but it did it with a new cutter too, and with minimal load. Thought maybe the brushes needed replacing, but it seems one of the holders was just loose. Nice to see that you can still buy pretty much any part of it as a spare though (DeWalt 625E, same as the Trend T10).
    Fixed my track pump as well… sort of. I replaced the O-ring on the piston which had come off, stuck inside the cylinder and disintegrated, with one from my generic O-ring selection but it doesn’t seal perfectly, so while it works as pump, it does let some air out. Need to replace it with the proper size.
    misteralz
    Our not very old but no longer in warranty AEG dryer was throwing the same fault code for months and it had gotten to the point where a reset wasn’t fixing it. Pulled the board and resoldered the cracked soldered joints. Then did the rest of them as I figured they wouldn’t be far behind. Been washing and drying EVERYTHING this past week.
    Murray
    SJS Cycles or BikeTart are your friends for Topeak spares
