Home Forums Chat Forum What Razor Do You Use?
Viewing 40 posts - 1 through 40 (of 54 total)
  • What Razor Do You Use?
  • SurroundedByZulus
    Am having to shave every day just now and it’s hacking my face to bits no matter how careful I am. What razor do you use and is it any good?
    heuer27
    Shave with oil in the shower job done
    doctornickriviera
    Ruddock.
    onandon
    One of these, for me it’s better than wet shaving.
    fasthaggis
    SurroundedByZulus
    Anyone tried the King of Shaves razors?
    jonny-m
    Yeah. There shite, dont get one
    fasthaggis
    Yup,too big and the wrong shape for anything but flat skin (IMO).
    I had one thought it was Ok, then I couldn’t get blades locally so switched back to a Gillette job fusion thing as it was on promotion. I realised for me I should have stuck to Gillette, Ok blades are expensive but they last around a month for me.
    Electric razors sill don’t seem to be anything near as good as wet shave for me.
    stuartlangwilson
    Mach 3s work well for me.
    Shaving immediately after a shower so the face and hair have been wet for a while seems to help. As does using a brush to apply your soap of choice.
    emma82
    Go hairy! Hairy faces are nice. It’s also nearly winter and cold so it would keep your face warm! 🙂
    _tom_
    Gilette fusion or mach 3, but I haven’t shaved for a while as I’ve got nothing to look smart for so I can’t be arsed 😆 Those safety razor things are the singlespeed of shaving.
    Kbrembo
    Using Merkur Futur since around 7 years..takes a couple of weeks to get the hang of it but once you do it’s awsome.
    Got to be paired up with Feather blades from Japan,good soap/cream and badger shaving brush
    Good Luck
    Junkyard
    the aldi one like a gilette but loads cheaper..is not desperate dan will never have 5 o clock shadow
    spooky_b329
    Spent years using Mach 3’s and getting razor burn and acne, changed to a third hand Merkur Futur and some decent soap, and its like I have a new face 🙂 I found the Feather blades a little ‘bitey’, get on best with Astra Superior Platinum which are sharp enough not to drag, but don’t cut you too often. Some are rubbish, including the Wilkinson Swords you can get in the supermarket. I’m sure they are fine in some razors, but didn’t get on with them with the Merkur.
    Markie
    Used a King of Shaves Azor for the last few years and found it fine – I guess the key point to note is that my stubble isn’t very heavy. I wanted something even easier to use, and a month and a bit ago bought a Panasonic ES-LA63 Pro electric shaver… fantastic!
    I never had nicks or shaver rash with the Azor and always would have said it was as gentle on my skin as anything could be, but using the Panasonic has been a revelation! I’d been a bit concerned as apparently it can take a month or so for your skin to become used to the action of an electric shaver. If your skin is very sensitive the Panasonic can be used on wet skin (even in the shower), which apparently makes it even more gentle (and more hassle to clean)!
    When I was trying to work out which shaver to buy I called up shavers.co.uk and they were very helpful on the phone.
    rob-jackson
    all the shaving **** to the forum please
    ScottChegg
    Using Merkur Futur since around 7 years…
    You must have been a hairy little fecker. Are you part troll?
    I use a wobbly Fusion, and it’s tremendous
    bigbloke
    Kevevs
    cheapo bic razor does the job….
    Frankenstein
    Gillette fusion version XXX etc.
    weirdnumber
    Gillette Mach 3 or Wilkinson Sword quattro. I got fed up buying the wrong blades because I couldn’t remember which razor I had I just bought the one I didn’t have.
    To be kind to my skin I found shaving in the shower and using Bulldog shave gel the best solution for me, king of shaves gel (blue one) is OK as well.
    If you are cutting yourself try to not to worry about cutting yourself and hold your face in a way that the skin you are shaving is taught.
    matthewjb
    Merkur Futur here as well.
    I’ve been using the Merkur blades but I’ve just bought a selection of blades from http://www.shaving.ie/.
    I’ll see how I get on.
    Klunk
    thank god i don’t have to close shave any more, the pleasure of the occassional 30 second once over with a phillips beard trimmer, stubbly rocks.
    RealMan
    Tried the DE safety razors, tried the gillette 200 blade razors, but none of them come close to a nice bic.
    carbon337
    I only shave about once a week once told to by boss or wife. Even then it’s just using a babylis I stuble thingy. Take the heavy off down to .5mm. When I have to go clean I would use a bic as above or just not go to whatever requires I need to shave.
    Wedding and daughters christening was last time I had a proper shave. I just hate that tight burning feeling.
    HermanShake
    Clippers. Shaving uses a whole lot of time, effort, aerosols (if you use them), plastic and other things we could do without.
    You gotta take the rough with the smooth 😉
    saladdodger
    I now use a double edge safty ( Muhle R89 with 7 oclock sharp blades) razor I tried everything else and just bleed.
    the most important thing I find now is the soap you use, Blue Beards Revenge and a good brush
    Have a look at the shaving shack on t net
    mattrgee
    Stopped clean shaving 5 years ago, never looked back.
    chaos
    Trumpers Shaving Tips
    Worth a read…
    Stoner
    merkur progress for me.
    dial it in all the way “pissed bastard face saving position 1” to avoid blood.
    saladdodger
    Oh forgot to say after shaving use a skin cream
    now I may get ridiculed for this comment but Assos Chamois creme is ace gives a nice cooling sensation
    crikey
    Strange.
    Almost STW in minature, this thread.
    I’m bad at X, therefore if I buy an expensive, or niche, or both type of Y, things will get better…
    I’ve shaved my own face with cheapo razors all my adult life and can do it perfectly well. I also get to shave other peoples faces with cheapo NHS razors and can do that perfectly well. In days gone by I also had to shave people from nipple to knee before surgery using cheapo NHS razors and I did it perfectly well.
    Anyway, as you were..
    Kevevs
    3 or 4 days without shaving then a cheap plastic bic. but I don’t have an important job where being cleanfaced is somewhat and enforced. well, it is, but I don’t care.
    mikewsmith
    beard
    freddyg
    cruzheckler – Member
    <waves>
    Merkur Progress and feathers for me at home. Gillette Tech and Gillette 7 o’clocks when travelling. A selection of soaps and creams depending upon how decadent I’m feeling. 🙂
    youngrob
    Merkur for me too. I just got pissed off at the expense of the Mach3/fusion/whatever blades.
    It’s the best shave I’ve ever had, it does take practise, I use oil and soap applied with a brush.
    chewkw
    Traditional Gillette fat handle (think it’s 1940 to 42) safety razor of course and not those modern metrohomosexual razors advertised by Woody Tiger and his mates. 😆
    Traditional Gillette fat handle (bought it for less than £25 but can be expensive) + £0.49 Palmolive shave stick + ebay £8 unbranded far east inhumane cruelly made badger brush + £1.00 Pyrex bowl + £5 Nivea Aftershave Balm.
    There you go.
    samuri
    Cheapo ASDA razors for me. I always wash before hand, make sure my face gets well soaped and soaked. Makes a big difference.
The topic ‘What Razor Do You Use?’ is closed to new replies.
