Home Forums Bike Forum What CX bike with disks and a full mudguard option?
Viewing 40 posts - 81 through 120 (of 130 total)
  • What CX bike with disks and a full mudguard option?
  • maxlite
    Would go for a TCX or CAADX, Arkose is to much like a mtb with drops.
    Mixed review of Arkose 2
    http://grit.cx/reviews/rated-pinnacle-arkose-two-2015
    firestarter
    Well bob i figured design implementation construction and materials pretty much spoke for itself. You stick to your plastic ill thought out stuff tho im not fussed what other people do. But if it were me buying new id go straight for pdw especially as so close in price to sks now. Infact thats exactly what i did
    fasthaggis
    There was a time before Garmin when Cateye ruled the bike puter world.
    If you still have those old magnet sensors that went on the forks,theP clips make an excellent bodge for fitting SKS (tape the frame first). If you put long bolts and a double lock nut on,you can quickly remove the guards for any CX racing action.
    firestarter
    Actually that sounds ar5ey. But what i mean is in their day sks were spot on but that time has now passed. Others designers have evolved and moved on sks still make them the same
    bikebouy
    Y’allreet there chicken… heres a few picks of guards on TCX’s
    Just a few random images when googling TCX with mudguards.
    They DO come with guard clips, seriously they DO..
    bikebouy
    And for balance heres a CAADx
    firestarter
    Pdw guards fitted as a comparison to sks
    bikebouy
    ^^ likes that I dos.
    Kryton57
    Firestarter, how are those fitted at the front of the rear guard to the bike, and under the fork?
    firestarter
    I have a threaded hole down the rear of the seat tube and one in the fork crown. But they come with fittings to bolt to seat stay and fork crown for more standard setups
    And cheers bikebouy
    Kryton57
    And the winner was…. My current defy 3 which has full guards. I’ve decided I won’t actually do much CX so it’s not worth the outlay. Instead I’m going to tart up the defy by treating it to some sale 105 levers, cranks and and mechs from Merlin.
    Sorry to disappoint.
    cynic-al
    Lol, fanny!
    ransos – Member
    27 years, not happened to me yet. I do fit them properly of course!
    It’s a common failure mode. Are you seriously suggesting that this is because most people haven’t fitted them properly
    Been in the trade 11 years on and off since 1988, its not a common failure mode ime.
    I have seen plenty snap due to poor fitting.
    Kryton57
    uwe-r
    I have full guards on my synapse. Fantastic bike.
    bikebouy
    Well if you’ve chosen to upgrade a bike you already have then hey, you’ll save a few quid for sure.
    Tell us what you are upgrading, we’ve put too much time and effort into this thread to let this one go 😆
    RustyNissanPrairie
    Kryton57
    I have a Giant Defy 3 2013 with full guards which is used as my winter/bad weather/turbo bike already. This one http://www.giant-bicycles.com/en-gb/bikes/model/2013.giant.defy.3.white.blue.black/11833/56804/.
    It already has 105 calipers and a wheel upgrade on it, and I have a 105 crankset in the shed. So for the sum of £198 I’m changing the sora/square taper/FSA spec to:
    105 Levers
    105 Front/rear mech
    105 HT2 BB
    105 cassette
    Deda Zero 100 Stem.
    Not very exciting but good as a workhorse for the winter
    ransos
    I’ve seen quite a few crack, and 30 seconds on google tells me it’s pretty common. The point where the steel bracket crimps onto the rear guard usually, and there are reports of SKS replacing them under warranty.
    I also know how to fit them because a)I’ve worked in a bike shop and b) I’m capable of following simple instructions.
    Back to mudguards now I’m back in from my ride Metal mudguards? Are you mad? What a din. And ‘better in every way’ but I note no details forthcoming…
    You’ve already been told why – read the thread. And as for a din, perhaps I should get my ears tested because I haven’t noticed it in the last year I’ve been using them.
    senorj
    I’ve been following this thread and I’m saddened that you’ve postponed the crossover to gravel core. 😀
    I was planning on offering to show you some lovely cx friendly bits and bobs in herts etc. fairly winter friendly too..
    Hoping to do the trail break/cx sportive things again this year,…I’ll look out for bikebuoy…:-)
    bikebouy
    Well the reason I asked K, simple one.
    Lots of folks followed this thread, if you’ve chosen to upgrade what you have some here might be interested in the mods..
    I’ll look out for you too senior j.. 😀
    cynic-al
    ransos – Member
    The ones I have seen snap/crack have been poorly fitted – due to stress at these points – because the installer hasn’t followed the natural curve of the mudguard.
    Merak
    ransos
    And I’ve seen one crack that did follow the natural curve of the guard. In any case, it’s not always possible due to the position of the fixings on the frame – that doesn’t make it poorly installed.
    The stainless guards I use now are much better in that respect – they can be gently moulded to the frame shape without causing a stress point.
    boblo
    @Kryton. What’s the clearances like on that Defy? Can it take a ~35mm CX type tyre? For me, that’s the one major difference between the winter road bike and the faux CX brigade; you can actually get the right tyres on. The rest is mostly the same.
    @Ransos. What religion do you practice? Mudguardery? You seem to getting all of a lather over your choice of guards. Well I’m convinced. Off to buy several new sets at ~£60 a pair due to your eloquence 🙂
    firestarter
    39 quid for pdw at triton 😉
    I worship the spaghetti monster btw
    dragon
    Both my front and back SKS mudguards failed in under 3 years of use (about 1 per week ride on average). I admit the roads I ride on a horrific but even so.
    Front rivets failed due to fatigue (fixed that), seatsay bracket failed probably fatigue (fixed that), rear guard cracked in half at seatstay bridge mount due to fretting (guards binned). Both guards installed correctly.
    Google suggest all the above failure mechanisms are common. SKS might be fine on continental smooth roads but not great on UK pot hole ridden B roads.
    scotroutes
    Metal guards on my wifes Cube are a bit noisier when they pick up wee bits of gravel but not so loud as to be a issue.
    My rear SKS Chromoplastic has “failed” at the middle/top stay but I’ve just fitted a wee bolt instead of the rivet. Should last another few thousand miles.
    thisisnotaspoon
    If you’re using it more from road surely a racier CX bike like the TCX would be a better option that a tootlier Pinnacle with more relaxed riding position?
    Surely the other way around? the Pinnacle is a road bike with concessions for pootling (slightly more relaxed, biger tyres and disk brakes). A CX bike would probably be much stiffer, but even more relaxed to allow it to handle off road?
    Fwiw the ridley bb drop is 1cm less than the caadx. I am having this issue a bit as trying to decide on a cx bike for similar purposes but do have the short legs, long torso issue.
    The BB height is a European Vs USA thing (Ridley Vs Cannondale in this case). European bikes traditionally have high BB’s to allow riding over stuff like steps and sinking into the mud a lot. CX in the USA is often a lot dryer, more like a crit race on gravel and grass, so the bikes developed around that and handling and speed came first, clearance second.
    Left field suggestion, Gnesis Fugio? Frames are £500 from some places, and I’ve seen them down to £299 sometimes, might squeeze a 105 groupset and some half decent wheels into the budget, then raid your parts bin for finishing kit?
    Kryton57
    Erm…
    “No mudguard eyelets, no rack mounts just a clean, pure, fast quality steel CX frameset”
    s1m0n
    Kryton, just picked up on this thread and appreciate you’re going to upgrade the Defy, but FWIW I have a 2014 Giant Defy 1 (with upgraded wheels) and a 2015 TCX SLR 1 as winter commuter/fun/mix it up type of ride bike (no racing).
    I love both, but have different sizes (S in Defy and XS in TCX – I am a short *rse though).
    I use Raceblade XLs on TCX (nothing on Defy) – I like being able to whip them on and off in a couple of minutes depending on the weather/forecast. They provide adequate coverage for me, but can be a bit rattly offroad – nothing I can’t live with though. Just put them back on this week for the constant rain earlier this week in Leeds.
    S
    cynic-al
    ransos – Member
    1? That’s all?
    It’s pretty much always possible unless the frame isn’t right for the guards. The stays can be bent easily to make alignment perfect.
    My guess is SKS failure appearing common is because there are probably MILLIONS of them out there. Just like a few bad Planet X transactions gets amplified on here.
    I don’t doubt you love your mudguards, and they may be great, let us now in a few years, nothing before then counts IMO.
    servo
    I have been commuting on various bikes with SKS mudguards for 25 years.
    The metal brackets that go behind the rear brake do fail and the mudguards also tend to split across at right angles. I get several years out of a set but the rears don’t seem to last as long as the fronts.
    Never bothered to claim on the warranty. Reckon I have had my monies worth over a few years.
    Do not be tempted to get Race Guards by Crud. Worst cycling product ever, went in bin after 2 weeks.
    jameso
    Probably got 15,000 pot-holed back lane winter miles on my P35s now, no probs. They fail where they flex or are stressed, that can be minimised by good fitting that doesn’t force them out of the natural shape or re-forming with a hair dryer if needed but any guard can fail that way, metal or chromoplastic. Still, makes for a good Shimano/Hope brake type debate. Race Blades were on one of my bikes for about 3 miles and that was enough.
    I’m offended : )
    But I’d agree if an Enduro bike is an XC bike with concessions for pootling, more relaxed .. etc ; )
    dragon
    Mine weren’t fitted out of shape, but repeated vibrations (from my commute which is on some awful roads) caused fretting of the plastic and fatigue of the brackets and then they fail. There are some ways of reducing these problems, and I’ll take them if I fit another pair
    ransos
    No, no. You must have installed them incorrectly. It’s not possible for them to fail otherwise, didn’t you hear?
    convert
    To be fair as a lifetime user of SKS who has never had any bother with them, I do like the look of both the guards suggested earlier in the thread. But at twice the price even discounted I’d kind of hope I would! Will defiantly consider when I next need to buy a pair, but that might be a while.
    cynic-al
    ransos – Member
    🙄 When have I said that? Give it up 🙄
    jameso
    Agreed, the PDWs do look neater. If they came in matt black and the right size for one of my bikes I’d have a set.
    ransos
    Do you have shares in SKS or something? They’re perfectly decent guards but there are better options for not much more money.
    pebblebeach
    1? That’s all?
    I’ve been using SKS chromoplastics for years on my commuter. In the past 2 years the quality has really deteriorated. They used to last years but now the metal fixing at the seat stay breaks, front guard cracks, rear guard cracks. I’ve been fitting them to the same bike for years and the difference is in the quality of the guards, not the fitting technique.
    Switched to the pdw full metal guards now at £39 from triton, so much better than sks.
The topic ‘What CX bike with disks and a full mudguard option?’ is closed to new replies.
