Home Forums Bike Forum what bearing puller for 6001 bearings?
Viewing 18 posts - 1 through 18 (of 18 total)
  • what bearing puller for 6001 bearings?
  • big_n_daft
    needed for campag scirocco and hope xc hubs/ freewheel
    recomendations please
    nbt
    I removed the bearings from Hope XC hubs with a drift, i.e. a length of metal rod.
    Remember to remove the circlip from inside the freehub before trying to drift out the bearings 😳
    big_n_daft
    no lip for a drift on the campag wheels hence the need for a puller
    m1kea
    big_n_daft
    The rrp will not work on the campag wheels, there is nothing for it to push against.
    I need on with the thin lips that hook over the edge of the inner race
    Suggestions?
    nbt
    Ask papa lazarou if he got the kit in this thread, if it contains a puller?
    http://singletrackworld.com/forum/topic/heckler-main-pivot-bearing-replacement
    m1kea
    B n D
    Just as an FYI for me, am I right in saying you need something like the 3 arm hub / gear extractors to pull the bearing out from one side?
    stumpyjon
    Nope he’s after something like this
    Great as long as the bearing stays together, need to makesure you pull the hammer straight or the outer race will get stuck and the inner race will explode 😳
    big_n_daft
    I agree with Jon
    http://www.ebay.co.uk/itm/400320900413?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
    do you have one I could borrow?/ bring the wheel around to yours?
    wwaswas
    bit of heat on the hub shell beforehand to free the outer race/expand the hub a bit – as above you can end up just pulling the inner race and the bearings out.
    seanodav
    Good thing about above tool is if bearing does explode one of the larger collets will grip the outer, where do you live big n daft?
    emac65
    Much cheaper option,tighten the bolt up till it’s nice & tight, then tap out with a drift.This method has never failed for me..
    big_n_daft
    Ramsbottom,
    I like the DIY solution from emac65
    m1kea
    Am I right in saying that that’s a slide hammer, and you’re wanting to to use it as a blind hole puller? – I was looking at stuff like this a few months back but couldn’t quite get my head around the terminology.
    Something like this Clarke set – http://www.machinemart.co.uk/shop/product/details/cht251-10-pce-slide-hammer-puller-set?
    ahwiles
    big_n_daft – Member
    Ramsbottom,
    i’ve tried it on a few ‘jobs’ – and never got it to work…
    m1kea – Member
    correct.
    emac65
    Well you must be one ham fisted,err person,easiest thing in the world to do….as I’ve already said,used this method many times, on wheels & FS frames,it’s worked perfect everytime 😀
    m1kea
    ahwiles
    correct.
    Cool
    Wonders if he can blag such a set as a birthday pressie?
    stumpyjon
    Sure we can arrange a time for you to bring the wheel over. Shouldn’t take more than a couple of minutes (if nothing goes wrong 😯 )
The topic ‘what bearing puller for 6001 bearings?’ is closed to new replies.
