Home Forums Chat Forum Wallpaper behind Stove? Will it stick?
Viewing 7 posts - 1 through 7 (of 7 total)
  • Wallpaper behind Stove? Will it stick?
  • huggis
    Hey all – I’m looking to install one of these stoves in my hoose and to wallpaper the wall behind it. It is on natural gas so won’t have the raging heat you might get with a wood burner (It’s rated at 7kw. ). Does anyone think wallpapering behind is a bad idea? Concerned it might just not stick.
    http://jotul.com/uk/products/gas-stoves/Jotul-gf-373-bf
    huggis
    No one 🙁
    kcal
    I don’t think it’ll work. Will just dry out and peel / curl.
    That’s a fair heat output, and even given its a gas fuel, the heat will affect nearby furnishings.
    e.g. I expect it’ll have a safe distance for combustible materials (wooden mantle &c) – paper might be classed similarly.
    granny_ring
    As in other kind of related thread, combustible materials need to be about 600mm away from the stove (I think) 🙂
    Edukator
    There’s a pdf document for the safety distances for combustible materials for each Jotul stove on the site. The side distance on mine is 700mm which meant cutting and shutting a kitchen cupboard to comply.
    sharkbait
    You can fit a piece of vermiculite board, or metal sheet, between the wall and the stove and it you can then put the stove 50mm from the board (needs to be a spacer between the board and wall).
    You can paint the board with heat resistant spray if you like.
    mitsumonkey
    You’ll boorn your hoose doon!
The topic ‘Wallpaper behind Stove? Will it stick?’ is closed to new replies.
