Vertical bike stora...
[Closed] Vertical bike storage...
24 Users
 IA
...without drilling holes in anything (rented accom). I mean for storing bikes vertically, not one above another. To fit two bikes in a smallish space.
Considering some of these http://www.chainreactioncycles.com/Models.aspx?ModelID=50399 but other suggestions etc welcome. Or even pics of your setup. Screwing stuff in may be acceptable as I could maybe build some sort of frame to take it.
Inspire me!
Posted : 26/07/2012 1:07 pm
why won't you do one above the other? as those types will rest against a wall i think.
Posted : 26/07/2012 1:08 pm
How do you open the door from the other side ?
Anonymous from United Kingdom Owner 09 March 2011 15:32
It's good but, I've installed this and my door no longer opens. Unless I'm taking my bike with me I have to go in and out via the window.
Posted : 26/07/2012 1:09 pm
I presume there's a clever automatic hatch that opens in the wall to accommodate the bike when the door opens.......
Posted : 26/07/2012 1:10 pm
this is the stand i was thinking of:
[url= http://shoeboxdwelling.com/wp-content/uploads/2011/08/Public1.jp g" target="_blank">http://shoeboxdwelling.com/wp-content/uploads/2011/08/Public1.jp g"/> [/img][/url]
Posted : 26/07/2012 1:11 pm
not keen on the wheels/tyres.
Posted : 26/07/2012 1:12 pm
 IA
"why won't you do one above the other?"
needs more width/length, if that makes sense? Need to fit a fairly narrow space.
Would be on the door to a cupboard full of all that stuff that you need to stash somewhere but don't need regularly.
Posted : 26/07/2012 1:54 pm
You could make something up like the thing shown in theflatboy's post using a few cut lengths of galvanized scaffold tube and some [url= http://www.tubeclamps.co.uk/fittings.htm ]tubeclamps[/url] - would be much more robust and you could custom make it to fit your particular bikes and the space you've got available.
Posted : 26/07/2012 2:12 pm
 kcal
 IA
Ahh, tubeclamps, was wondering what they were called, cheers for the heads-up. I can feel some big-boy's mecanno action coming on 🙂
Kcal, cheers for the link, but I want to store the bikes on their end, I think, if that makes sense?
http://www.ikeahackers.net/2008/02/stolmen-bike-rack.html
Seems a good option for the 2 up horizontal rack, but requires bolting in. Though I reckon could be bolted into some plates of ply or whatever instead.
Posted : 26/07/2012 2:56 pm
See the road bike and hardtail on the left? They are hanging off an Element Systems Upright and Bracket from Screwfix, with some pipe insulation over the bracket and a zip tie to hold the bracket into the upright when you lift the bike off.
B&Q are slightly more expensive but they sell longer brackets which means you would get two bikes and the front wheels hung, or three bikes and the wheels stacked underneath.
[url= http://farm8.staticflickr.com/7070/6774846324_dbddbea17d_z.jp g" target="_blank">http://farm8.staticflickr.com/7070/6774846324_dbddbea17d_z.jp g"/> [/img][/url]
[url= http://www.flickr.com/photos/ojr/6774846324/ ]IMG_0368[/url] by [url= http://www.flickr.com/people/ojr/ ]Ollie and Sally[/url], on Flickr
(Obviously some drilling is required, but to be honest any stand worth having will need this, also the bikes will scuff the wall up anyway unless you are really careful.)
Posted : 26/07/2012 3:42 pm
I've got one thats like an acroprop, so adjusts to reach the ceiling. It holds 2 bikes and is for sale £15 collected from Bristol......
Posted : 26/07/2012 3:46 pm
 IA
Ah interesting, basically shelf brackets and some cunning hanging action, right?
I guess Ideally I'd not take wheels off, but it does let you get the bikes flatter as your pic illustrates. Though the vertical wheels-on approach like hooking over the door would provide means only rubber bits touch the wall/door. Less likely to pull chunks out.
Wondering about a kinda tall thin A-frame (think like a swing.) and hang the bikes from hooks, though they may move too much.
Collected from Bristol you say? Tis where I'm moving to, hmmm. Does it need bolting in, or secure without it? What height range does it do? I'd need to wait till I actually move in september to measure up etc properly to see if it'd do. Just gathering options/brainstorming for now.
Posted : 26/07/2012 3:51 pm
You could just ask the landlord if you could put in two wheel hooks from Halfords for £3.95 each, on the agreement that you then make good when you move on.
Posted : 26/07/2012 6:08 pm
I've got one of these,
http://www.chainreactioncycles.com/Models.aspx?ModelID=28862
It doesn't need any fixings, but is still nice an solid, admittedly it's a bit pricey but as it is over my bed I wanted a good quality one as I didn't want to be rudely awoken by a bike to the face, here's some pics to give you an idea of the space it takes it up
Hope this helps
Posted : 26/07/2012 7:04 pm
 IA
Cheers guys, pics of the real-life setups much appreciated as the marketing pics generally are guff!
Posted : 26/07/2012 8:25 pm
Made one of these up from Ikea parts, some aluminium bar, and a bit of wood.
Could be modified to hang bike vertically.
Wide top piece, with innertubes stapled to top side, and big spikes on bottom piece going into carpet means it doesn't need to be bolted either end.
Posted : 26/07/2012 10:28 pm
 IA
Ah cool, yeah was thinking of that sorta setup if I end up going with horizontal bikes, though I'm not sure that'll fit so well in the space I have. Good to see it works though. You find it plenty stable?
Hence looking for this sort of option:
Except somehow I need to a) not drill stuff b) get the bikes closer together and c) be easy to load/unload them (for the gf).
I shall also be mounting the moon on a stick 😉
Posted : 27/07/2012 8:52 am
i would have thought you'd struggle to mount them like that without drilling or some sort of fixing at the wall, due to the centre of gravity of the whole set up. you'd need a massive foot coming right out under the bikes to stop it wanting to topple over.
Posted : 27/07/2012 8:55 am
You can easily get them closer together by topping and tailing them. We have a similar set up in a shed and can get 5 road bikes (or 4 mountain bikes) in a 6' length. I can get the bikes out ok (as a girl!), but it depends on the weight of the bike.
Posted : 27/07/2012 9:14 am
Go horizontal if you can, makes the bikes a lot easier to move, and the rear wheel won't scuff the wall/door. I had the vertical hanging hooks in my garage, and they were a pain.
Also not sure how good it is for brakes if you store bikes non-horizontally.
Posted : 27/07/2012 9:20 am
I'm in rented and the landlord has no problems with me drilling holes for things, so long as I ask and promise to fill them before I leave.
That vertical option up there - can you just alternate and hang every other bike upside down? That way you can get them closer together.
If they're going indoors rather than the garage, go to your local carpet shop and buy a couple of samples to protect the wall. I got some 2' square for about 2 quid each.
If you're hanging MTBs then my preference would be horizontal so fluids don't go to the wrong places (fork for example). No idea if that's just me being a bit odd.
Posted : 27/07/2012 9:21 am
 IA
Don't think fluids are a huge problem, though ideally would be front wheel up for the brakes. Have stored bikes upside down in the past and even that's only a problem if you leave them there months.
I hear you all about asking to drill etc. but that's always very landlord dependent, as I say, just looking for options just now.
I wonder about something like a pole like the above pics, but instead of horizontal, have a hook to go under the fork crown, so the bike just about hangs from the crown with the back wheel on the floor, if that makes sense?
I remember putting my bike on a chairlift which hung like that once, but not sure if it'd work for a static rack so well. Can't quite visualise it.
Posted : 27/07/2012 9:56 am
 IA
Ahah, I'm liking what I see here:
http://mikelevy.pinkbike.com/blog/Arbutus-Racks-Interbike-2011.html
(i know, it's for a car, but I like their freestanding trolly thing and the general idea)
http://arbutusracks.com/
Posted : 27/07/2012 10:02 am
 IA
Hmm, or like this:
http://www.instructables.com/id/Bicycle-Stand/step6/Bicycles-can-be-hung-cross-ways-vertically-or-wha/
but using one of those ikea stolmen bars, a hook for top wheel and then a plate of wood or something for the rear wheel. Hmmmmm.
Posted : 27/07/2012 10:06 am
Bikes are considerably easier to handle horizontally, at least once they're off the ground, particularly if there's not much space.
Posted : 27/07/2012 10:12 am
 IA
Yes, but the exception here is where you can (ideally) just wheel a bike in, pop it up onto its back wheel, then hook it in place somehow.
Another idea I'm thinking of is having a board on the floor with two batons about a wheel width apart, so you pop it on the back wheel, wheel into the gap, and they stop it rolling about (and the front wheel is hooked somehow). This has the bonus of collecting any crap falling off the bike if it's wet/dirty.
Posted : 27/07/2012 10:23 am
Could You fasten one of them hooks that hold the bikes by a wheel vertically to some form of free standing support?
Posted : 27/07/2012 11:18 am
IA - Member
unless it falls anywhere outside the wheel-width batons...
Posted : 27/07/2012 11:46 am
Got the same as bigrich.. from lidl / aldi at about £35 ish.. leans agains t a wall, really sturdy. Plus a cable wil pass through teh upright so you can lock stuff up..
Posted : 27/07/2012 12:01 pm
Go to Halfords and get the cheap wheel hooks. i have 3 in my garage and they are great and cheap, got them for buy 2 get 1 free!!
Clearly you will have to drill a couple of holes but its nothing tht cant be fixed when you leve with some filler and touch up paint, its the cheapest option
Homebase have loads of wall fixings.
Posted : 27/07/2012 12:12 pm
I had that 'Gravity' stand from Lidl. Its in the loft now...even with the main post 3 inches from the wall (resting against a rad at the bottom and a spacer at the top) my handlebars still touched the wall as the arms aren't long enough.
Also, although it appeared stable without the big screw and rawl plug it comes with, I had to fit it as it tended to lean drunkenly to the right as the post is in three sections and the fit is quite loose.
Storing the bikes with the back wheel on the floor and the front wheel in a wall hook takes up a surprising amount of space, the handlebars stick into the room. If you are pushed for space you haven't really got a choice, you either loosen the stem and rotate the bars or remove the front wheel.
Another possible option is to get a big old sturdy wardrobe off the free-ads, pine or other solid wood. Stick it in the room and you mount your shelving brackets/hooks to the inside top or back of the wardrobe, remove front wheel and hang bike/s in the wardrobe, riding gear and other crap will go on shelves, then you shut the doors and forget about it. There was a photo doing the rounds on Facebook a while back with a wardrobe like this.
Posted : 27/07/2012 12:20 pm
 IA
Hmm, makes me think. good option might be front wheel off, and hang bikes by a fork leg flat against the wall/whatever stand. Need something to protect against pedals, but that's it.
Posted : 27/07/2012 12:30 pm
[i]good option might be front wheel off, and hang bikes by a fork leg flat against the wall/whatever stand.[/i]
I tried this, but found it was much more secure to hang by passing the frame over the bracket so the bike was hanging off the head tube.
Posted : 27/07/2012 12:32 pm
Ian at AQR stores a lot of his fleet vertically. Rubber bands to pull in the brake levers stops any problems with air.
Posted : 27/07/2012 12:38 pm
I hang our bikes in all directions, a mix of Formula and Hope brakes and they don't seem to have an issue. If there is no air in the system I don't see how there could be a problem.
Posted : 27/07/2012 12:43 pm
 IA
Interesting, I'd have thought by the fork would be better to stop the bars flapping about?
Cheers all, this is all helpful advice. Maybe I should've made the thread title a bit more generic, as there's advice here that could help a lot of folk!
Posted : 27/07/2012 12:56 pm
Bike hung by fork leg, fork crown/stanchion, by head tube: (click to make bigger)
[url= http://farm9.staticflickr.com/8161/7656202146_dfc744636c_n.jp g" target="_blank">http://farm9.staticflickr.com/8161/7656202146_dfc744636c_n.jp g"/> [/img][/url]
(risk of sliding off the bracket)
[url= http://farm9.staticflickr.com/8022/7656202892_c94d1a1fe6_n.jp g" target="_blank">http://farm9.staticflickr.com/8022/7656202892_c94d1a1fe6_n.jp g"/> [/img][/url](secure and the bike is vertical so takes up least space, but didn't like the idea of all that mud being ground into the stanchion - inevitably the bike would get knocked and it could scratch it nearer the seals)
[url= http://farm9.staticflickr.com/8151/7656203686_78b5d7c031_n.jp g" target="_blank">http://farm9.staticflickr.com/8151/7656203686_78b5d7c031_n.jp g"/> [/img][/url]
(secure, being able to move the bars a little helps fit other bikes/wheels onto the bracket)
[url= http://farm9.staticflickr.com/8425/7656204604_d1f61f0ebd.jp g" target="_blank">http://farm9.staticflickr.com/8425/7656204604_d1f61f0ebd.jp g"/> [/img][/url]
(the whole lot...as you can see I much prefer to just vacuum up the mud that drops off rather than clean each bike every time 🙂 )
Posted : 27/07/2012 1:55 pm
Posted : 27/07/2012 2:19 pm
 IA
Spooky, excellent! Cheers for the illustrated guide to hanging bicycles 🙂
Surrounded by hills, liking your work, though I think road bikes maybe easier to store than large MTBs as they're narrower bars (rather than a 23" odd 29er with 760mm bars + bar ends)
Posted : 27/07/2012 2:41 pm
I have to say, good thread OP. It's quite fascinating to see all the photos of kitchens and bedrooms full of racked bikes 🙂 I might have to point the missus to this thread next time she moans about too many bikes in the garage!
Posted : 27/07/2012 3:24 pm
I've got a Topeak Two Up Tune Up with a 3rd mount. I also have a small child so one of them needs to go. I'm accepting offers....
Posted : 27/07/2012 7:47 pm
 IA
Whereabouts are you based?
Posted : 30/07/2012 8:53 am
