Home Forums Chat Forum US agents exacting revenge?
Viewing 32 posts - 41 through 72 (of 72 total)
  • US agents exacting revenge?
  • 2
    Ewan
    The US government playing the long game here. Decades of pumping co2 in the atmosphere has just culminated in a plan of unparalleled evil genius.
    matt_outandabout
    I’m going more with the killer Beluga and Ukrainian links theory….
    thecaptain
    Of course the car thing could be a hit job but the water spout? Hardly.
    2
    paino
    Conspiracy theories aside, I’m really struggling to come to terms with how a micro burst can sink a boat of that size unless there’s some kind of manufacturing defect. In general most sinkages occur due to loss of keel.  Yachts are designed to be in much worse conditions at sea with all sorts of lateral forces at play. That boat was anchored out of the prevailing wind/chop so the water conditions aren’t a factor so doubt loss of keel was the issue. It’s got massive design flaw written all over it, bloody trophy boats with masts too big for a their intended purpose. Speculation I know, but a mast of that size and weight could easily do some serious structural damage if it fell in the right place. Either that or a wee guy in a suitcase.
    hot_fiat
    @paino warm muggy night, at anchor in a supposedly calm bay, I bet all the cabin windows were wide open, which you’d not do while under way.  Wouldn’t take a lot to swamp it.
    The conspiracy crap is amusing. HP might be an evil company (the water glasses chained to the dispensers in the office I worked at in Bangalore were evidence of that), but competent of skullduggery on that scale? Nah.
    dakuan
    i reckon it was the orcas
    1
    MoreCashThanDash
    I’m more concerned that I don’t seem to be able to report the post.  Just because you can do/say something doesn’t mean you should.
    2
    martinhutch
    HP can’t even make a functioning printer, let alone control the weather.
    I’m sure the chemtrail/cloud seeding nuts are having a field day, but I suspect there are easier ways to off someone if it’s really necessary.
    1
    molgrips
    You remember those orcas attacking small boats near Gibraltar, last year?
    Orcas aren’t real.
    2
    cheers_drive
    A freaky coincidence like this is manna from heaven for the conspiracy nut jobs.
    My closest near death experience on a bike came on that road the jogger was killed on. You’d think that straight roads with clear sight lines would be safer but quite the opposite compared to other places I’ve lived.
    3
    oldnpastit
    Some of the comments on this thread might be seen as quite insensitive by any relatives.
    matt_outandabout
    Go read the thread on Sailing Anarchy about it…
    The boat had a fricking huge mast (50m+ ) and a 4m draft, large glazed openings and as a 12 person or less boat was not designed past certain heel angles etc etc
    The windage from a bare mast mixed with a massive few minute storm, plus possibility of the boat ‘tripping’ on its anchor = crazy forces.
    Even if well built, even if the crew were trying to respond, they may have been overwhelmed.
    There’s a *rumor* someone’s home CCTV caught a good portion of things, and severe heeling to sunk was less than a minute…
    https://forums.sailinganarchy.com/threads/56m-luxury-sailing-yacht-sinks-off-sicily-7-missing.247750/
    matt_outandabout
    And I’ll go look on YouTube, but I’ve seen shore CCTV of a storm in I think NZ where a 40′ catamaran weighing a few tons was flipped backwards and behind it a 40m yacht has it’s spreaders in the water for a few minutes before the storm stops….
    8
    fenderextender
    Orcas aren’t real.
    It’s not a black and white issue.
    1
    northernsoul
    IIRC the yacht sank at around 5 am – also potentially a contributing factor to the outcome.
    That’s just click bait…
    hot_fiat
    Thanks Matt, that’s a really interesting read.
    1
    avdave2
    If Ocean Gate made super yachts……….
    TroutWrestler
    The latest I have read is that the mast did not snap off. It looks like the yacht was blown over, and water entered through open windows and doors, which had been left open as the weather was hot.
    The hull was swamped by the water entering and sank. The yacht is lying on its side in 50m of water, otherwise intact.
    It would be very hard to control the weather, but easier to compromise the stability of the yacht by interfering with ballast, then hoping for a gust, but actually getting an extreme weather event.
    Usually the simplest cause is the correct one.
    winston
    The yacht had a lifting keel. It was up.
    The yacht was a badly designed vanity project like most ‘super'(stupid name) yachts. Massive deck doors, huge heavy superstructure and a massive mast that was basically a cock substitute.
    A real super yacht, so basically most sub 40ft sail craft would have been knocked down and sprung back up again with minimal water ingress even if all hatches had been open.
    Harsh yes but that’s the truth. Such a shame and a waste of life but the superyacht industry needs to look at itself.
    2
    fenderextender
    Shall I start a pod-cast?
    susepic
    A Cefalupod-cast?
    dissonance
    This one?
    jkomo
    Still suspicious it sank. Windows were 3cm thick so it must have been built to withstand much worse. Very sad for all involved.
    mrbadger
    Captain Being questioned on whether some hatches were left open apparently.
    Sandwich
    It was the Orcas what dunnit!
    Speeder
    martinhutch
    I’ve just had to wrestle with an HP Plotter and was thinking exactly the same thing. I’d sink HP if I could.
    matt_outandabout
    It seems it is a lifting centreplate on the bottom of a near full length keel. It can be seen on the plan and photos. And the plater, while adding to stability at rest, can (as any dinghy sailor gybing will tell you) can add to the ‘tripping’ effect if the boat is moving or loaded sideways. Like in a sudden storm.
    Let’s wait for the MAIB to put out a report.
    mashr
    TroutWrestlerFree Member
    I’ve seen this in a few places but struggling to get my head round it. Would expect a modern yacht that size to have aircon throughout and everything kept closed as a result
    tillydog
    Now confirmed by “a source close to the family” that Mike Lynch’s body has been recovered.
    As someone who was acquainted with Mike many, many years ago (before he was rich), I am just sad that such a clever bloke is dead. He was someone who managed to make money out of his own ideas and brainpower and he should be celebrated for that.
    1
    matt_outandabout
    I think MAIB will issue a report on due course.. There’s so much unknown at this point that the respectful thing is to wait for that report.
    dakuan
    videos of the dives to the yacht have been leaked, all the relevent hatches were closed. Looking like a crappy design was a leading cause of the sinking.
    matt_outandabout
    Again, too early and not enough clear information as yet. MAIB report will bring this all together and that is the one source for all speculation….
    (I am clearly new here….)
