Hi all – it’s been a while.
I have a Whyte e150 RS that I bought new in 2021. It’s never had a service or had it’s firmware updated, so it is still on the original. I understand an LBS needs to update the firmware, which is a bit inconvenient, but anyway…
I took my bike in for a service to have cassette and chain swapped out, and I asked them to update the firmware at the same time. The chap hooked it up to his PC using a USB cable, and the purion display showed ‘USB’. The problem is that his PC didn’t see the connection. We tried a few different cables and even a different USB port on the PC, but no joy.
The chap thought there must be something wrong with the purion display and said he’d contact Bosch to see if they can swap it. Everything works normally, and the port cover on the display looked well sealed and the port itself was clean.
What do you think? Do you reckon there could be something wrong, or do you think there is a different way to update the firmware on a 2021 Bosch motor? The software tool he was using was called ‘DiagnosticTool’ or something like that.
Any ideas? I wish I could do this myself TBH.
