Home Forums Bike Forum Tubeless tyre fitting revelation?
  • This topic has 44 replies, 39 voices, and was last updated 7 years ago by Del.
Viewing 40 posts - 1 through 40 (of 45 total)
  • Tubeless tyre fitting revelation?
  • jamesfts
    Brought a wheel* into the office today to fit some new spokes.
    When finished I realised I’d left my pop-bottle-inflator-jobby at home. After a few unsuccessful attempts with a track pump and a removed valve core I spotted an old 26in tube, wrapped that around the outside of the tyre to help seal it against the rim and it beaded straight away with much less faff than using an inflator…
    Is this a trick I’ve previously missed or have I done an invention?
    *650b – important later in the story
    Northwind
    I do something similar with cable ties on my fatbike tyres, never needed it with normal tyres but I like it!
    weeksy
    never seen it… but i like it !
    stevied
    Don’t forget to take the tube off after.. 😀
    scotroutes
    This is why we need a LIKE button!
    whitestone
    I’ve done something similar by simply wrapping my arms around the tyre, sort of hugging it, basically reduces the volume so when you start pumping air into the tyre it pushes the beads out quicker. (I think)
    jamesfts
    May just cut the valve off and run it like a budget semi-slick 😉
    igm
    I think that’s a genuine invention.
    Of course you now need to sell your OuterTube (pat. pending) at say £30 a throw.
    5% to me for the name
    DiscJockey
    haha, thanks whitestone – glad to see I’m not the only person who hugs their tyres in place 😉
    jamesfts – nice way of making the obsolete inner-tube feel wanted, just one last time !
    mintimperial
    Clever!
    *notes for future use*
    jamesfts
    Did initially thing of doing something similar but couldn’t work out how to hug and pump at the same time (that sounds so wrong).
    Logic behind it was to pull the bead in against the taped section of the rim to create enough of a seal to allow it to ‘pop’ onto the rim.
    Kryton57
    This is excellent.
    ‘cept now I find myself wondering if I need a 650b tube for my 29er tyres.
    molgrips
    I tried it using a strap, but failed miserably. The use of a tube as the perfect tool is inspired though, so good work.
    hols2
    There are some quite astounding videos online if you know the right search terms.
    benp1
    That’s a great idea.
    I suppose you could use other things rather than an inner tube (if you don’t have one). For example those straps (ratchet or otherwise) that you use for securing loads (e.g. to a roof rack)
    oldnpastit
    Awesome! Surely got to be worth a kickstarter project?
    johnw1984
    Where was you a couple of weeks ago!
    Think it’ll seat a Mary on a Hope rim?
    Northwind
    benp1 – Member
    Ratchet strap isn’t ideal because it doesn’t pull evenly, it tends to fold th tyre a bit and create caps. Cable ties work great because you can tighten them one at a time round the outside… I guess the tube would do soemthing like that too.
    Onzadog
    I’ve done similar on a very floppy tyres with clothes pegs. Reduced the volume and pulled the bead out by pegging the side wall. The all pinged off as the tyre went up though.
    ads678
    This was my first* thought as well.
    *Just after ‘what a cracking idea’….
    igm
    Shouldn’t. The tube is outside the tyre so is already running bigger than designed.
    But test and find out.
    greyspoke
    Well you’ve just stuffed your chances of patenting it by telling us.
    jonnyboi
    Genius OP, I’ll pinch that idea
    jimfrandisco
    Will be trying this as soon as i get home this evening…but if it doesn’t work i’ll demand my money back!
    Fingers crossed.
    bgascoyne
    I wish my office had a bike stand and a place to work on my bike!
    BoardinBob
    I’ve done that before with a big ratchet strap but that’s far simpler
    mark90
    I’ve had success using a cam lock strap but this seems a much more apt solution 😀
    jamesfts
    I’ve as many bikes at the office as I have at home… shhhh though, don’t tell Mrs FTS 😉
    Bream
    So simple it’s genius 😆
    belugabob
    Another ratchet strap user here, but only had to resort to this twice.
    Liking the inner tube twist on things, though.
    centralscrutinizer
    I’ll be giving that a try, if it works you’ve changed my life OP 😀
    martinhutch
    Good work!
    welshfarmer
    Good thinking Batman. Have done it a few times with Land Rover tyres during races using a ratchet strap. Same principle but this is a far better solution for bike tyres I can already see. LIKE
    takisawa2
    I still ended up having to pack the rim trough on my fat rims though. Jumbo Jim just wouldn’t hold any kind of shape.
    juanghia
    If I’ve ever had to seat really baggy tyres I’ve always used a daisy chain of Toe Straps.
    Hightowers are shocking for this.
    Junkyard
    Just tried it and it certainly made the two i did easier – One tnt to tubeless rim one non tubeless to non tubeless
    I would recommend it
    Alphabet
    [like button]
    Gaz.dick
    Good effort fella!
    dangeourbrain
    Is that a valve stem or the tail pinned on your cunning plan so you can call it a weasel?
    Bream
    I take that back as it didn’t work for my skinny XC tires when I tried it last night on a 2.1×29 Rocket Ron Evo!
The topic ‘Tubeless tyre fitting revelation?’ is closed to new replies.
