@FuncyDunc I changed to a 561 as my Cotic was an awkward size/downtube angle/shock position combination that meant it never quite sat as nicely as I’d like on the 591.
I definitely prefer it, take the wheel out and slide a chunky metal collar over the axle (comes with all combinations of endcap for different fork sizes) and then do the axle up as if it’s got a wheel in it. Then it just drops into the Proride and clicks into place, super solid and really quick to do. For me quicker than juggling it onto the rack with the front wheel on, but that’s partly as I’m short anyway. I’d definitely recommend it as long as you have boot space for the front wheel and won’t leave it in the carpark/at home by mistake!
All the clamping is on the supplied collar/sleeve (basically a simplified wheel hub with a locating feature in the middle) so as far as the fork/forces on it are concerned it’s just the same as holding it in place by locking the front wheel solid.
