Home › Forums › Chat Forum › The Electric Car Thread
- This topic has 7,888 replies, 407 voices, and was last updated 2 days ago by jp-t853.
matt_outandaboutFree Member
With now only 9 years until diesel is gone, throwing 20k on 2nd hand diesel GLC in the interim seems a waste and that we’d be throwing a Merc away in 2030.
They’re banned from sale, not from use.
wayniacFree MemberThat’s right about pure EV needing the 12V lead acid to run, well it is for a Leaf anyway.
The 12v system is required to energise the HV system and run all the usual stuff like control units, radio, etc. Then when the car is in run mode the lithium battery keeps the 12V topped up.
I’ve had to jump start a Leaf several times even though the lithium battery had entry of charge.
snapsFree MemberWell, I installed this today – it’s 11kw 3 phase & replaces a 7.2kw single phase charger, users say it’s 3.5 to 4 times faster to charge their cars.
Cost £1195 less 18% discount plus about £50 for some 16mm cable & a 40A MCB
DaffyFull MemberThat makes no sense. How can an 11kw charger be 3-4 times faster?
My car has a 33kwh battery pack. On a 7kw charger this takes just under 5 hours from empty, with the car taking 7kw for 91% of the pack and then slowing to 5kw for the next 4% and 3kw for the remaining 5%. I can see that it would be 50% faster for 90% of the charge, but how could it possibly by 300-400% faster?
luketFull MemberI think my 3 phase charge point is theoretically 3x a single. The limitation is in the car, for which 11kw is common. Mine’s max is about 17kw which also isn’t 3x faster, but it’s not so far off.
It makes no difference for overnight charging but on accession has been handy.
DaffyFull MemberBut those chargers up there state 11kw.
My guess would be that when two cars were charging when it was on single phase that each was getting just over 3kw, whereas now, each car is getting the full 11kw. Which would be 3.5* faster.
For a single charge point it would only be 50% faster.
dave661350Full MemberIs rapid charging at home something that’s needed? I thought most would charge overnight when they’re in bed so 3 or 7kw would be sufficient?
B.A.NanaFree MemberIs rapid charging at home something that’s needed? I thought most would charge overnight when they’re in bed so 3 or 7kw would be sufficient?
That^ looks like a commercial Rolec unit not a domestic, so could be for delivery vehicles or whatever.
nickewenFree MemberNice whip @bensales! The facelift M3 looks much better with the chrome delete and I think it also benefits from a heat pump that will help with range. Enjoy, they are absolutely silly fast! I still drive around laughing like a lunatic at the turn of pace on mine, 9 months in. Great cars
B.A.NanaFree MemberThe facelift M3 looks much better with the chrome delete
They had them at Leeds at the end of November, I’m sure on black it looks good but I wasn’t so taken with the black trim on white (which of course is the base colour now). With the ^Blue it looks better I think yes.
luketFull Memberdave661350
Is rapid charging at home something that’s needed? I thought most would charge overnight when they’re in bed so 3 or 7kw would be sufficient?Yeah, >7kw not really needed at home. It’s really only once in a blue moon that an overnight 7kw wouldn’t have done the job. More applicable for locations you might be at for a couple of hours or other applications like commercial maybe.
NB none of these is “rapid” as such. All basic AC speeds and charging over a few hours.
However slightly faster charging can be a “nice to have” and if you happen to have a 3 phase connection etc, I think it doesn’t cost much more to install a 3 phase charge point over a single phase. Eg a Tesla wall connector is essentially the same hardware either way.
B.A.NanaFree MemberIf you have a big battery car and are on Octopus Go tariff, you might want a faster than 7.2kw home charger to be able to charge within the 4hr cheap tariff window.
luketFull MemberThat new model 3 does look very smart @bensales. Hope it goes well for you.
I read somewhere that there have been lots of little improvements along the way already. Heat pump obvs but more besides I believe.
A lot seems to go into small efficiency gains in Tesla I think. My EV experience is all tesla then I test drove the MG estate EV the other day. All things considered I thought pretty good, but the energy consumption it was reporting was a bit higher than I expected, like same as my much bigger and heavier car would report and it was nearly all pretty slow driving.
Also I really hope there’s a good engineering reason the regen braking doesn’t go down to zero and it’s not just an effort to make it feel like an old auto. When I go back from my EV to anything else that’s what I miss the most. Much better to spend all of 5 minutes getting used to that change (which is mostly positive anyway, it seems to me) than design a whole car round avoiding it.
luketFull MemberAnyway, reason for MG test drive was for my sister who needs an estate, ideally, or similar access and storage space, and doesn’t really want an SUV. Seems there isn’t much out there and we’ll have to try some of the SUV EVs too.
She’s also a user of hand controls for disability. Hard to judge how the shift to EV and that change in how pedals work will be advantageous/disadvantageous for that but my starting assumption is a genuine “one pedal driving” mode might be lovely for her, because no arm push required for deceleration to a standstill. Trouble is, can’t really fit hand controls for a quick test drive.
beamersFull MemberI’ve got to place an order for a new company car.
I was looking at the hybrid Leon, as I currently have the petrol version, but I’m going to end up paying about £300 a month in BIK / personal contribution for a car which will spend quite a bit of time sat on the drive, even when we eventually return to a post COVID-19 world.
The current deal with my Leon is pretty much cost neutral so that £300 a month is going to put a big dent in my bike part purchasing fund / putting food on the table budget.
VW ID.3 works out to £30 a month.
I can’t see the downside. Is there one?
pedladFull MemberWas looking forward to the ID3 being a good alternative to the Tesla 3 but been a bit underwhelmed with reviews tbh. Range not that good. No supercharger equivalent. Not big storage considering it’s a dedicated ev. Looks meh. So so to drive. Performance is average. Drum brakes on rear (! Didn’t we get told 30 yrs ago disks were far better?)
B.A.NanaFree MemberWhen I go back from my EV to anything else that’s what I miss the most.
I’ve got a petrol courtesy car at the moment and I think the main thing I’m missing (especially at this time of year) is the instant heater, or even having the car nice and warm before you get in it.
chestrockwellFull MemberI can’t see the downside. Is there one?
Not for the price. My i3s is cheaper to lease than a fiesta due to the BIK reduction so it made the decision a no brainier.
snapsFree Member“That makes no sense. How can an 11kw charger be 3-4 times faster?”
11kw 3 phase is not just 3.8kw more than 7.2kw single phase, its a lot more.
The left cable in the picture is charging a 67 plate Mitsubishi PHEV, the driver lives further away than the battery range so the vehicles battery is fully discharged when he arrives in the morning, when he goes for lunch at 1300 the battery was only 65% charged on the 7.2kw charger – now its 90% (but as charging rate reduces as the battery gets full its difficult to calculate how much quicker)
The right cable is charging a 19 plate Merc EQ diesel hybrid E class & the driver lives within the vehicles battery range.
From the drivers app, the data shows:
7.2kw single phase charging from 12% to 90% takes 4h56m
11kw 3 phase charging from 10% to 90% takes 1h36m
sharkbaitFree Member7.2kw single phase charging from 10% to 90% takes 4h50m
11kw 3 phase charging from 11% to 90% takes 1h39m
I still don’t understand that – surely you can’t cheat physics.
What size battery is it charging and is that 3 phase charger 32A?igmFull MemberMerc EQ diesel hybrid E class
11kW 3 phase is a 230V ac 16A charger, 7.2kW single phase likely a 230V 32A charger. The 11kW really is 2.8kW more.
So I think that’s a 13.5kWh battery no?
So in both instances it’s putting in around 10.9kWh.
So the 11kW charger has an effective charge rate of 6.8kW across 96 minutes.
And the 7.2kW charger 2.2kW.
Something other than the charger is throttling that process.
I suspect the car’s on board charger (AC/DC conversion etc) can’t handle 32A of input on a single phase (probably not on 3 phase either).
A 10A onboard capability in the 3 phase AC bit of the car’s charger, would give roughly those charge times.
Bigger chargers are not always the answer.
More phases? Possibly.
More convenience? Almost definitely
robbo1234bikingFree MemberOn my eGolf it cant charge faster than 7kW unless you use a DC connection then it will go up to 50kW so for us it would be pointless getting a faster charger installed at home. Take about 3 hours to charge though (the range isn’t great compared to other electric cars mind) unless you are really low on battery and then the first 20% or so is at about 3.5kW rate. We have a 32a breaker for the charging point.
luketFull Memberbut as charging rate reduces as the battery gets full its difficult to calculate how much quicker
In a big way on 100kw+ DC, sure, but not really relevant on 11kw (or whatever speed) AC.
As above, something else is throttling the single phase example. If a car’s on board charger limits single phase to 2.2kw (so essentially 3 pin plug speed) for the whole charge that would be potentially seriously limiting, although less so for a hybrid sized battery.
phiiiiilFull MemberThere are a few cars that can only charge at 3kw per phase, so they will charge at 11kw on a 3-phase supply but only 3kw on a single phase supply; they are fine in Europe with more common 3-phase supplies but pretty pointless in the UK. The skoda citigo-ev is one of them; might the car above be another?
Most cars with a 7kw single phase charger will charge slower on an 11kw 3-phase supply than they will on a 7kw single phase supply. Trying to charge a pure EV at 3kw is something I’d do only if I had no other options, it’s veeeeery slow indeed.
beamersFull MemberOrder placed for my VW ID 3 this afternoon. Delivery date requested for May 21 when my current contract expires.
nickewenFree MemberI think the ID3 is a great car. My SiL has just got one in white and it looks fantastic in the flesh. Her husband picked it up from St Albans and drove it home to Northumberland with 1 splash and dash at a rapid charger halfway up. I’m trying to convince my wife to get one.
DracFull MemberIt’s what I was going to go for but they were delayed, they then released just before my E-Tron arrived. They do look good but I’m not sure about the interior, need a proper look at one.
bensalesFree Member@nickewen @luket thanks chaps, really enjoying the car so far. Mind bendingly fast, and I come from a background of riding superbikes, so that’s saying something!
Lost my supercharger virginity this evening. So easy, it’s how all charging networks should be. Although it’s going to cost me a fortune in Costa hot chocolate.
bensalesFree Member(ID3) Drum brakes on rear (! Didn’t we get told 30 yrs ago disks were far better?)
Must admit, I thought that when I watched a review of the car.
But then I thought, given the regen of the electric motors, drums are probably more than sufficient at the back so why carry the expense of disks?
DracFull MemberMind bendingly fast, and I come from a background of riding superbikes, so that’s saying something!
I think the biggest noticeable difference is they don’t pause at any point, they just seem to accelerate faster the quicker you go.
luketFull Member@bensales welcome to the future!
Since my 6 months free elapsed I’ve barely used a supercharger. In about 20k miles over mainly 200 mile journeys. Unless you’re doing seriously long journeys you might be the same. So you might get away with only very little money spent on shit coffee.
Don’t tell anyone we don’t much rely on charging networks though. Motoring journalists’ brains would explode.
phiiiiilFull MemberBut then I thought, given the regen of the electric motors, drums are probably more than sufficient at the back so why carry the expense of disks?
Given how little the brakes on an EV actually get used, could drum brakes be better in terms of maintenance? I can’t imagine disc brakes being very good if they don’t get used much, whereas drum brakes are more enclosed and might not mind so much.
kerleyFree MemberDon’t tell anyone we don’t much rely on charging networks though. Motoring journalists’ brains would explode.
My next car will be electric and I can’t see me ever having to charge it away from the house based on the driving I do.
However, there is still a BIG problem to solve for those people who don’t have a drive and for example live on a terraced street where their car could be parked 50 metres away from their house. And millions of people are in that situation.pedladFull MemberI can’t imagine disc brakes being very good if they don’t get used much, whereas drum brakes are more enclosed and might not mind so much.
that makes sense yes.
bensalesFree MemberSince my 6 months free elapsed I’ve barely used a supercharger. In about 20k miles over mainly 200 mile journeys. Unless you’re doing seriously long journeys you might be the same. So you might get away with only very little money spent on shit coffee
I didn’t really need to use a Supercharger last night, just there’s one close, I’ve got some free referral miles, and it was an excuse to drive the car! 😉
But that said, the Supercharger network was one of the key reasons I picked the Tesla. My job requires me to work away from home, stopping in hotels. So my driving is either tooling around town, or it’s long distance on a Monday, stay away, then long distance back home later in the week. The superchargers take all worry and hassle out of this kind of driving.
beamersFull MemberI think the ID3 is a great car. My SiL has just got one in white and it looks fantastic in the flesh.
I went for the standard grey as it was free. I opted for some alloys though:
DracFull MemberHowever, there is still a BIG problem to solve for those people who don’t have a drive and for example live on a terraced street where their car could be parked 50 metres away from their house. And millions of people are in that situation.
Yeah this pops up ever EV thread, charging stations will help, on street chargers will be easy enough to install and then charging on route or destination.
luketFull Member@bensales the supercharger network should sort you out no trouble at all. However with your usage you might find quite a lot of AC options incidental to your parking/overnight stays.
I work 200 miles away a fair bit too, for a few days at a time, but it’s always the same location and I can charge there. I now spend less time in service stations than I did with a diesel.
I don’t think it makes a real difference unless you’re a really heavy user but worth bearing in mind that super fast DC charging is worse for batteries than AC over the long term.
