Home › Forums › Bike Forum › the big ring??
- This topic has 202 replies, 68 voices, and was last updated 11 years ago by palmer77.
the big ring??
RealManFree Member
So if you ditch the 44t on an existing triple XT set up, can the existing front mech be ‘limit-screwed’ to prevent inadvertent shifting onto the bash ring?
Yes. In my picture above everything is normal – chainset, front mech, etc. etc. Just two chainrings instead of three. Also those are 26 and 38 teeth chain rings.
And what would be the largest cog you could fit in the ‘middle’ ring position and still get a sweet shift from the original front mech?
Not sure – I think general rule is 12 teeth between chain rings? Mine shifts fine from 26 to 38 and back again.
mrmoFree MemberNot sure – I think general rule is 12 teeth between chain rings? Mine shifts fine from 26 to 38 and back again.
Mine is 40/26 Chinook rings and seems to work ok.
timravenFull MemberI use mine all the time. If it’s flat or non tech downhill I’m in it. I can’t understand how a 36 up front can replace 44 with the same block at the back. I hate spinning out and I’m a lower cadence kind of rider anyway.
+1
tpbikerFree MemberI run a 22/36 up front with a normal front mech with the limiter adjusted. Works fine.
I can totally see the 2 ring argument, but I must say looking at those ratios above I’d be screwed running a single ring. I’m there or there abouts in the granny ring whenever I’m going up steep climbs on the big bike…f*ck doing it with a 32 or 36 ring.
njee20Free MemberSome bloke on WeightWeenies was running 24/42 (iirc), he claimed it worked fine, but I’d take that with a pinch of salt! 14t will certainly be fine.
GWFree MemberNjee. 22/40 works fine too
Careful, I replaced the salt with piss earlier 😉
jamj1974Full MemberWhen going to a double and bash using RaceFace Deus, e13 bashing and Blackspire chainrings, I optimised my chain line by spacing the RH cup out using 3mm of spacers, wound my low and high adjustments in and use the bottom two shifts on the LH shifter. By doing this I have minimised the angle the chain runs at in the inner ring and have got very fast and reliable front shifts in both directions.
CaptainFlashheartFree MemberI still run 3×9 on my trail centre skill compensator Enduro. No bash guard, etc.
This is my “weekend away” bike. My, let’s go play somewhere nice bike. As such, it ends up doing all sorts. For example;
Road transfers back to Machynlleth after a day on the trails (Last trip was ten of us doing team time trial, complete with elbow flicks!)
The Gap, Brecon. Big ringing it down the far side. Helped stop chain bouncing as well.
Chalkland, Hermitage to Swindon. (Very much the wrong bike for the day, but hell!)
The big ring also gets plenty of use at NYA, CYB, Cwm Carn, Brechfa and more, where the trail gets fast and swoopy.mboyFree MemberThe Gap, Brecon. Big ringing it down the far side. Helped stop chain bouncing as well.
More reason than any other to ditch the big ring and shorten your chain!
99% of the time I was only in the big ring to keep the chain tensioned and stop it making a racket or jumping off altogether. Ditch 22/32/44 and replace with 24/36/bash, shorten the chain significantly, and you only lose effectively one gear ratio and all of a sudden your bike is a whole lot quieter and just works better!
Someone should have patented it, and given it a catchy name and sales spiel, he’d have made a fortune! 😉
grumFree MemberDitch 22/32/44 and replace with 24/36/bash, shorten the chain significantly, and you only lose effectively one gear ratio and all of a sudden your bike is a whole lot quieter and just works better!
Yup.
njee20Free MemberThe big ring also gets plenty of use at NYA, CYB, Cwm Carn, Brechfa and more, where the trail gets fast and swoopy.
Aye, of course it does, but not the very top gear, the one you lose by ditching the 44.
CaptainFlashheartFree MemberI suppose you’re right, njee20.
In fact, that may just be the excuse I need for a new chainset! 🙂
soundninjaukFull MemberI’ve actually got as far as taking the big ring off a Race Face Evolve XC triple (22/32/44) and putting a bash guard on it (my calves feel safer already). I’m should be able to replace the 32 with a 36 no worries right? The only thing I’m mildly confused about is that Shimano seem to have 2 suitably cheap/hardwearing 36 chainrings that are the same except for the model numbers.
They’re obviously not the same, so what are the differences and which one should I go for?
rp16vFree Memberok what the hell have i started i thought it was just a simple question….. i was wrong
was just wondering as i see allot of highend xc bikes still with triples thats all not really something to get all worked up about
were u lot not out enjoying a wet ride?soundninjaukFull MemberRain, sun, rain, then hail. That was how my Saturday at Swinley went 🙂
ononeorangeFull MemberTo me it depends where / how you ride. I wouldn’t be without my big ring – ride mostly in it (it’s the one I have to replace first) and any flat blatting (of which there is a lot round here) will see me in the littlest sprocket a fair bit, also on sections of road (a necessary evil). Probably not true somewhere where there’s lots of vertical bits though.
devsFree MemberIf you say a wrong thing often enough, it doesn’t make it right! 36:11 is not the same as 44:13. As far as I’m concerned you lose 2 gears at the top but the clincher is the chain line. I can feel the difference and I break enough chains as it is without stressing a chain because it’s trendy. Horses for courses, my nomad has double and bash but my other non SS bikes have triples. You lightweight spankers might be able to beat me round one of my loops with your small rings but I wouldn’t beat me for sure.
mikewsmithFree MemberI can feel the difference and I break enough chains as it is without stressing a chain because it’s trendy.
You have bigger problems then. Gray and work out why you are snapping so many chains.
22/36 shouldn’t strain the chain any more. Not broken chains in a long time.
Your the one breaking the chains
devsFree Member22/36 shouldn’t strain the chain any more.
Not true. An outer ring to the smaller rings is almost a straight line instead of kinked in 2 places. Add to that 17.5 stone of raw, awesome Guinness fuelled power and the flimsy kit designed for 8st racers gives in eventually. To my surprise the 10sp stuff has not failed yet but also, enough gut to stem interfaces teach you to spread the load about your chain rings more wisely, hence the big ring staying. Ken?
njee20Free MemberMore torque in the smaller rings too, and more opportunities for bad chainlines with a multiple ring set up. I find chain wear massively reduced on 1×10 compared to a double or single. But then I’ve actually used all 3 set ups, where as you’re basing it purely on conjecture, so I bow to your superior knowledge!
As long as you’re happy with what you ride the huraah, it doesn’t mean folk are running something else purely because it’s ‘trendy’, I’m not sure why you feel the need to criticise something you’ve not tried.
CaptJonFree Membermboy – Member
Haha, brilliant! LOVE this argument…
I suppose you typed this on an 386 connected via dialup? Are you the guy I passed the other morning, commuting to work via horse and cart?
Its called progress! And more often than not its a good thing…
This genuinely makes no sense to me.
devsFree MemberI’m not sure why you feel the need to criticise something you’ve not tried.
If that is aimed at me that would be incorrect. I will also have a 1x whatever’s cheapest on my current singlespeed soon for thrashing around my local playground. For the real mountain biking however, triple is king. You should come try it. TdBN?
njee20Free MemberIf you’re paying for me to come up there of course! On holiday for this years event, maybe next year? Always like to ride new events.
Odd event to use as an example of your epic awesomeness though – 70km with 1500m of climbing? I do significantly more climbing than that in Surrey. I’m sure there are unrideable climbs, then I’m thankful of the weight saved by running a single ring…
mikewsmithFree MemberFor the real mountain biking however,
Ah the fabled real mountain biking, that stuff the we are all missing out on by going er…. Mountain Biking
Having tried 1×9 (for a year) the lack of a 22t in the lakes was too much of an issue. (No snapped chains though)
Back to the 2×9 which is perfect for ME 98% of the time. If we end up on a route with that much long 42t road pedaling then I know I’m on the wrong route. If I want to go touring or something I wont take the mountain bike.
Used 3×9 twice in 3 years now to do the Isle of Mann End2End which has some long road sections. Probably not worth the hassle of swapping really.
think I spotted the problem there, get tougher kit 🙂
All in don’t knock it till you have tried it. going to 2×9 from 3×9 initially cost me a bash ring and £20 chain tensioner. Upgraded the 32t middle to 36t a bit later. Not exactly an expensive upgrade.
mboyFree MemberIf you say a wrong thing often enough, it doesn’t make it right! 36:11 is not the same as 44:13. As far as I’m concerned you lose 2 gears at the top but the clincher is the chain line
So you’re arguing with maths now…?
Brilliant!
Creationist are we?
If you drop your 32/44 rings and replace with a 36T, you only lose one ratio off the top end. The resultant new top ratio of 3.28:1 is as near as dammit the 3.38:1 of the 44/13 previously, so much so you wouldn’t notice. The next ratio down would have been 44/15 which is 2.93:1, so as you CAN NOW SEE, you’re only losing one ratio!
As for chainline… The best chainline in most gears comes when in the middle ring on most cranks on most bikes. The outer position gives an acceptable chainline in the smallest few cogs, but otherwise isn’t ideal. Running a 24/36/bash setup, I get a better chainline much more of the time.
Says the man who then admits he owns one or more singlespeed bikes! I’m confused… 😕
Losing chainrings up front isn’t about being trendy (though maybe for a few it might be seen as that), it’s about simplifying and optimising the performance of your setup as best as possible, without introducing too much of a compromise. There is of course always some form of compromise, with a single ring setup you have only 9 or 10 distinct ratios Vs what is reckoned to be 14 distinct ratios in a conventional 27 or 30spd setup (with lots of ratio duplication). In a typical 2×10 setup, you’re getting an effective 13 distinct ratios, so you’re only really losing one gear, usually the very top one which most people never use anyway.
EDIT: Anyway… Chains snap because people put too much torque through them… The easiest way to lower the torque going through a chain, is to use easier gears and learn to spin the pedals faster! I snapped chains years ago when I was a pedal masher. These days I’ve upped my normal cadence from about 60rpm as it was, to around 90rpm in normal riding, and even on 10spd chains, with a double (on one bike) and single ring (on the other) setup I haven’t snapped a chain yet, and don’t expect too either as I’m now MUCH easier going on my kit because I learnt to pedal properly…
I was being sarcastic… My references were to outdated, antiquated pieces of equipment that were once fine for their intended uses, but these days we use much more modern and higher performance tools for the job…
Quick, trademark “real mountain biking”, sell it to the manufacturers as the latest fad, you’ll make a fortune! 😉
There are people on here that could probably overtake you or me on bikes that weigh twice as much, with a 2:1 singlespeed ratio, going up the steepest of hills whilst we had as many gears as we could shake a stick at on a lightweight bike to do the same job. Your point is what? I know people that can and do ride everything on a Singlespeed. It’s not for me… I can just about manage pretty much everywhere on a 1×10, though I’ll concede that a couple of times I have wished for a slightly lower gear than 32/36 offers me on very steep climbs on a long ride. But certainly I’ve never wished for a taller gear than 36/11 on my full sus bike.
devsFree MemberSo you’re arguing with maths now…?
Brilliant!
Creationist are we?
You are not losing one ratio, you are losing 2 and gaining a different one which is still significantly below the 44:13 present previously.
44/11×26=104
44/13×26=88
36/11×26=85Also, I use 32-11 cassettes which have 11-12-14 spacing which blows your theory even further. I presume you are basing your argument on 34-11 cassettes, which would be poor form in a triple ring set up.
44/12×26=95.33
How does your saying go? Classic facepalm or something like that?
devsFree MemberChains snap because people put too much torque through them… The easiest way to lower the torque going through a chain, is to use easier gears and learn to spin the pedals faster! I snapped chains years ago when I was a pedal masher. These days I’ve upped my normal cadence from about 60rpm as it was, to around 90rpm in normal riding, and even on 10spd chains, with a double (on one bike) and single ring (on the other) setup I haven’t snapped a chain yet, and don’t expect too either as I’m now MUCH easier going on my kit because I learnt to pedal properly…
How come my singlespeed chains don’t break then? Oh yeah I know it must be crap shifting eh?
mboyFree MemberYou are not losing one ratio, you are losing 2 and gaining a different one which is still significantly below the 44:13 present previously.
Dear God! I’m losing the will to live here…
36/11 gives you 3.28:1, 44/13 gives you 3.38:1. The difference between these is roughly 3%. Blindfolded, you really would not be able to tell the difference between riding a bike in a 36/11 gear or a 44/13, especially as you’ve got a hell of a lot more variation than that just in tyre sizes and volumes alone, and on a bike with a triple chainring setup, well over 500% gear ratio range anyway! So you lose the top gear, the 44/11, the next highest gear then is, as I have said before, essentially the same ratio as the next one down on most triple setups, the 44/13 ratio.
They’re quite old to be fair. Used to use 9spd XT cassettes with the same ratios, think all the newer 9spd stuff went 11-13-15 at the bottom, but yes all 11-34 cassettes do anyway. Was actually referring to an 11-36 10spd cassette anyway, as that’s what I run.
How so? I thought you seemed to think you needed a million percent gear range anyway? Many many many bikes come off the shelf with a 22/32/44 setup and an 11-34 cassette… It’s overkill IMO, but obviously some manufacturers think it worthwhile.
I dunno, I guess you’re going to tell us though! I’m guessing as you usually require 3 chainrings for most riding, with your singlespeed you’re either off and walking it up a hill, or freewheeling it down a hill as you can’t pedal a 2:1 fast enough. Thereby the chain gets a very easy life, or something to that effect! 😉
langyFree MemberBeen 2×9 since ’09.
Have 38/28 up front. Lose a little on the road sections if I try to race the roadies, but really, not a big deal.
Although there is road sections to link stuff up locally, most of it is uphill, so lower gearing is not a huge drama.
Will be staying 2x in all likely hood as I upgrade to a new bike. Though also pondering 1x…
walleaterFull MemberDid a day at Whistler Bike Park yesterday and I think my top gear is 36/11, but I just stayed half way up the rear cassette all day to keep decent chain tension. Why on earth does anyone want to pedal when going down hill?
oldgitFree MemberWell the dreadful deed has been done. 26/38 on it’s way to use with a 11-32.
TBH if you’re just riding along you’ll get up and over anything on any of the ratios discussed here, singlespeeds, 2×10 2×9 and 3×9.
If I never wanted to race again I’d go singlespeed again. I took my singlespeeds everywhere, but I’d never ever do a short XC race on one.
When the new rings turn up, the first thing I’ll do is ride some of my local XC course. The long straight with the stop and stand still switchback leading to a wall of tight singletrack will be first. Where it was 44 drop to 32 then to 22 then up the cassette, it should be a far smoother transition? we’ll see.njee20Free MemberOh rly? You’re bound to win then huh?
Where did I say that? You’re using it as an example of ‘real mountain biking’, the inference being that I’d struggle with a single ring. I’m just saying that’s got less climbing than my local trails, and the distance isn’t a challenge either. Of course it’s much easier to stick your fingers in your ears and assume I never ride up any hills because you need a 22t chainring for that 🙄
devsFree MemberGot a gpx of your local trails that have more than 1500m of climbing in 70kms? Not that I don’t believe you or anything but I must visit this mountain mecca. I’m not saying that you will struggle on a single ring either. I would and I would also be a LOT slower round the course.
devsFree MemberThey’re quite old to be fair. Used to use 9spd XT cassettes with the same ratios, think all the newer 9spd stuff went 11-13-15 at the bottom,
You appear to have based your arguments on something you didn’t check. All mine, XT and pG980 have the 12T.
grumFree MemberGot a gpx of your local trails that have more than 1500m of climbing in 70kms? Not that I don’t believe you or anything but I must visit this mountain mecca. I’m not saying that you will struggle on a single ring either. I would and I would also be a LOT slower round the course.
Um….. I’ve done about 1200m of climbing in 30k before in the Lakes (on a 36t double).That’s pretty normal tbh.
docrobsterFree MemberDevs:
Here’s one I prepared earlier
Will 1500m of climbing in 50k do?
I rode that on a bike with a triple, but have since ditched all big rings and now have a choice between 2×9 22/36×11-32 and 1×9 32×11-34.
I would want a granny ring to do that route but not a 44t ring.
Horses for courses.glenhFree Memberwalleater – Member
Why on earth does anyone want to pedal when going down hill?Errr…to go faster?
devsFree MemberYes yes, I’ve ridden out of Castleton myself a few times. It wasn’t in Surrey the last time I did it and it wasn’t a big mountain day either.
Edit: FWIW I probably wouldn’t use my big ring on that route much either.
The topic ‘the big ring??’ is closed to new replies.
