Ah slightly too late but I wouldn’t recommend them. They use a tektro specific bleed kit, by the time I’d bought that and the £30 replacement hose they were no longer quite so cheap.
Nope standard bleed kit from Amazon/eBay.
I used hose from an old, leaky calipered Shimano brakeset :-)
They take all the same hoses, olive and fittings as Shimano brakes.
They also don’t come with mounting adapters
Mine did – though it came with 203mm Tektro discs, so the adaptors were for those.
I used 180mm discs, and had spare 180mm adaptors.
the adapters I have mean the caliper sits slightly proud of the rotor meaning not all the pad is engaging it.
You have the wrong adaptors for your disc size then!
The feel isn’t great, they’re a lot weedier than 2 pot SLXs and despite bleeding three time I still have air somewhere in the line
Totally disagree. They’re as powerful as the TRP Slate Evos imo. Good modulation, and very comfy levers.
You need to bleed them properly! Top down method, with cup at the top and syringe at the bottom.
