Home Forums Bike Forum SS ratios ?
Viewing 9 posts - 1 through 9 (of 9 total)
  • SS ratios ?
  • justa
    Need some help with my new tricross single speed….
    first one – when i get a puncture and have to take the rear wheel off…..
    How do i get the tension right when i put it back on ? Also can i use a normal QR skewer or even a halo hex – i don’t want to carry round two spanners !
    Secondly, what ratio do you recommend for a beginner ? The tricross comes with 42 at the front and 18 at the back…
    I ain’t going to get up a lot of the hills around here…
    thanks 🙂
    dobo
    depends on how you intend to use the bike? off road, commuting, road etc
    i didnt help much did i 😉
    Merlinman
    1 ring spanner is enough
    Pull wheel back and nip up gently – QR won’t hold securely
    Try a 39t – Surly do a suitable one
    TTFU 🙂
    justa
    good point though
    well..
    commuting and general rides when I just grab the easiest thing out the garage….
    I suppose its the choice between getting up hills and spinning madly on descents ?
    Merlinman
    I can get up most stuff on the 39 – and 19-20mph on the flat before you spin out….
    justa
    hi rob – nice to hear from you
    was going to mail you but cant find your email address in the profile ?
    Garry_Lager
    Have you got a chain tug fitted? I find these helpful in getting the chain line straight and tensioned when you repair a puncture. Still need a spanner for the bolt though. The stock wheels on the tricross are poor, so a slightly misaligned chain can accelerate wear and tear on the hub – mine only lasted a few 100 miles.
    It’s not possible to choose a ratio for a SS CX bike that will do everything – the difference in ratio necessary for proper trail work and beasting along down the tarmac is massive. It’s a bit different from a SS MTB in that sense. The stock 42×18 is a good start – this would be on the light side of things IME, you wouldn’t want to go much easier than this if you’re riding mainly on roads.
    stoney
    I run a 32-18 and i can still pedal at 16-18mph on the flat and i am by no measure that last to the bottom of a fell/hill.
    soobalias
    im on 52:18 but its only used on tarmac, and keeping up with traffic is more important than anything else.
    the hills took a while to get used to.
The topic ‘SS ratios ?’ is closed to new replies.
