Home Forums Bike Forum SRAM Rival 1 lever with TRP Hylex caliper?
Viewing 14 posts - 1 through 14 (of 14 total)
  • SRAM Rival 1 lever with TRP Hylex caliper?
  • baileyswalk
    Any reason why I couldn’t swap out my TRP Hylex lever with a SRAM Rival lever?
    Looking to go from SS to 1×11 while replacing as little as possible (also suspect the TRP caliper might be better) so thinking Rival lever, long cage mech and a shimano XT 11-42 cassette
    thisisnotaspoon
    No, the Tektro’s use mineral oil (shimano fluid) and SRAM use DOT4/5.1
    baileyswalk
    Darn it – when are shimano going to sort their s&*t out for a good 1×11 road/cx rig
    jakd95
    How about these from Gevenalle? Should do exactly what you’re after and they have options to work with either Shimano road or mtb derailleurs.
    Linky[/url]
    baileyswalk
    @jakd95 I have seen those but wasn’t sure about them – looks like it might be an odd position for the shifter but I do like the compatibility factor of them.
    steve_b77
    jakd95 – Member
    Linky
    They’re a good idea, but they sure look shit
    baileyswalk
    baileyswalk
    Might look at the Tanpan solution from wolftooth…
    cookeaa
    See I really like the Gevenalle solution, partly because of it’s somewhat clunky, unconventional appearance…
    The other option to consider is perhaps trying a bar end shifter?
    An SRAM SL-500 Aero shifter would work I think?
    slightly prettier, no need to change or mod the brake lever, but slightly trickier to operate…
    baileyswalk
    Yea not sure I would get on with a bar end shifter, I think I’d prefer the Gevenalle rig.
    downhillfast
    Just replace the calipers as well, it’s not the end of the world.
    Flog the Trp calipers to recoup some funds.
    Gotama
    You could get the Di2 kit for your hylex levers and go that route? My Hylex have been superb brakes.
    Edit…will leave the post there but appreciate it’s not particularly helpful given the groupset level you were originally targeting!
    baileyswalk
    Yea, I saw the Di2 kit for the Hylex that would be the best solution but will probably just get rival throughout – Di2 is way too pricey for me & I’d probably need a new frame too!
    andysmiff1
    I could be tempted by the hylex set-up (dependant on condition) if you want to recoup some cost……..
    Mail in profile!
    A
The topic ‘SRAM Rival 1 lever with TRP Hylex caliper?’ is closed to new replies.
