I had a jockey wheel de-bond from the bearing and wrote the mech off at the same time. SRAM warrantied it within a week.
Definitely get the jockey wheels with the lip on the lower one to stop the chain coming off and jamming between it and the cage.
Uberbike are coming out with aftermarket ones but they’re still £40 unless you can grab them in a sale. Also lack the lip but I don’t know if there’s any other change in the design that helps the derailment issue. It’s also much less of a problem on the x01 mechs as there’s less clearance between cage and jockey wheel.
Sram have also standardised the jockey wheels across the eagle range so they’re the same for x01 to NX eagle I believe.
