Home Forums Bike Forum specialised Boomslang bearing removal tool
Viewing 7 posts - 1 through 7 (of 7 total)
  • specialised Boomslang bearing removal tool
  • lungman
    Grrrr I’m finding this most frustrating, these are great pedals but the right hand side feels a little gritty in the bearing. So i thought I’ll strip them down and sort it. And thats where it all goes wrong no one seems to have the special tool to undo the bearings. I spoke to local Specialized dealer and they have never heard of it and cant find it on their B2B website so expensive pedals now resigned to the spare parts draw. The only place i can find the part is the USA but in a full bearing kit so £80+ inc import duty so might as well buy new ones. Can anyone help? do you have the tool i can borrow or buy?
    Thanks
    Jay
    Bagstard
    I’m in the same boat, I now have three sets of expensive pedals that need serviced!
    Tracey
    Mine came with the bearing kit. I was told I could order it via the local store but didn’t need to.
    Part no S155300007
    bigyan
    Out of stock, but gives you the part No. S155300007 to check with a specialized dealer
    https://www.thebikefactory.co.uk/product/215053/specialized-specialized-boomslang-pedal-bearing-cover-removal-tool/option/
    If its not that tight you could use a pin spanner, if its tight then it will probably slip and damage it.
    lungman
    yep used that part number to no avail, as I mentioned only part kit i can find is in USA and lots of dosh
    Tracey
    Got my kit from one of the German stores. Its showing in stock below, I would ring them to confirm it comes with the tool as mine did. I couldn’t have done them without the tool and a vice, it was that tight.
    https://www.thebikefactory.co.uk/product/215054/specialized-specialized-boomslang-pedal-axle-bearing-rebuild-kit/option/
    lungman
    cool thanks for that, never came up on internet searches
The topic ‘specialised Boomslang bearing removal tool’ is closed to new replies.
