Home Forums Bike Forum SPD's pedals with reflectors, for commuting?
Viewing 5 posts - 41 through 45 (of 45 total)
  • SPD's pedals with reflectors, for commuting?
  • aracer
    I thought that reflectors, by definition, reflect light directly back towards the source.
    Nope – they reflect light at an angle equal to the angle of incidence, but in the opposite direction. To reflect directly back to source you need an inside corner reflector as pictured above.
    Does scotchbrite work in the same way as prism type reflectors above then?
    Without googling, that’s my understanding.
    aracer
    I’m not sure that any sort of “absorb light from one direction and spread it around” product exists
    Anything bright white is a very good approximation.
    TandemJeremy
    reflective tape on my bike
    [/url]
    bike reflewct 2[/url] by TandemJeremy[/url], on Flickr
    aracer
    Googling reveals that Scotchlite actually contains microscopic glass beads – which is apparently also the standard way to make paint retroreflective.
    http://www.rema.org.uk/pdf/history-retroreflective-materials.pdf
    BTW if you want to set off a speed camera on a bike (assuming you can find one on a good downhill, or your name is Mark Cavendish), then using the corner of a box and covering in tin foil to make an inside corner reflector as shown above is a good way to increase your radar cross section so it detects you – or so I was told by the radar experts in work when I inquired about this.
    hs125
    Going back to pedals: I use a pair of the plastic ‘platform’ pedals that clip to one side of SPD cleats for commuting for just this reason. No problem to ride in if you’re only used to cleats, and a big help with visibility. The only problem is that I lost one on a root strike on an off road section. No idea if you can buy them, mine came with some SPDs a few years back.
The topic ‘SPD's pedals with reflectors, for commuting?’ is closed to new replies.
