Reports vary on this one.
If you look on YouTube, you can find the full reverb service video, which is quite frighteningly complicated and needs special tools, but basically carries out a full seal replacement and post bleed (rather than just the “remote bleed” that is easy to do). This should fix the slight play issue, as that play is a sign that air has got into the internal hydraulic circuits, and hence the post isn’t quite a solidly “locked” as when there is no air (air being compressable)
But, various sources also suggest that even a full reseal/rebleed of the post won’t fix this slight play issue, but no one has ever been able to tell me why that might be case!
