you need something with a pressure reservoir. The electric ones are just pumps.
Ive got one like this (although it was from a carpenter friend, I didnt have to buy it)
https://www.machinemart.co.uk/p/clarke-bandit-iv-8-litre-air-compressor/
that is the Clarke branded one, you should be able to get cheaper on eBay. They’re all the same, made in the same factory in china.
Its a very useful bit of kit. Doing tubeless inflation, but also for air blasting stuff clean, or dispersing water. It’s also handy for doing the car/van/motorbike tyres as you can carry it to each wheel, just taking it back to a socket to reload the air reservoir each time.
Interestingly, on ebay the 8L is not so easy to find, and in fact the larger vessel (24L) is cheap http://www.ebay.co.uk/itm/AIR-COMPRESSOR-25-LTR-NEW-c-w-WARRANTY-ct178-/311649016819?hash=item488fba9bf3:m:ml0kKY21pnwFfmo8xn_EJFw
but they’re not quite so easy to move around I guess, at 24Kg vs 16Kg, although the pump and valves are the same on both models.
