Home › Forums › Chat Forum › Simple Photoshop CS5 question…
- This topic has 221 replies, 28 voices, and was last updated 14 years ago by simonfbarnes.
glenpFree Member
only asks "are you sure?" when trying to step outside a few common-sense parameters.
Of course it does presume common-sense in the first place.
MrSmithFree MemberA masterpiece of trolling SFB..
not really. just somebody who was offered advice from various users who use the software without issue every day.
but despite all this advice has decided that everyone else is wrong and he is right.
but then nobody ever changes their mind because of an internet forum 'discussion', as i'm still 100% certain that i'm correctly using a very capable well developed piece of software.GrahamSFull Membernobody ever changes their mind because of an internet forum
Blimey, you're right!
I used to niavely think they did, but you've just convinced me otherwise. 😀
TalkemadaFree Memberbut then nobody ever changes their mind because of an internet forum 'discussion'
I have done. I've learned stuff which I didn't know before, and been educated and enlightened.
simonfbarnesFree MemberA masterpiece of trolling SFB…
on a point of information, just because someone disagrees with you, that doesn't make them a troll. I believe what I'm saying, and I have a professional interest in program design.
It doesn't tell, it asks me what I want to do. It trusts my judgement.
right up to the point where you try to close a file, when it suddenly assumes (as do most editors) that you have decided to abandon your edit and discard all the changes you have made, but then pops up a stupid dialog to ask if you really meant it. In fact is should carefully and silently save all your work unless you click a thing saying "Throw all changes away I've changed my mind" – with me this would be about once a month.
You may be a programmer, but airing your view that PS is poor software design anywhere – and I mean anywhere – and you will get laughed out of there.
you are sadly mistaken if you think programmers talk to each other, except perhaps in expletives, though why I should be concerned about being laughed at I don't know :o)
God knows why I am sticking up for it. Adobe certainly doesn't need me to do that.
yes, I wondered that!
simonfbarnesFree Membernot really. just somebody who was offered advice from various users who use the software without issue every day.
but despite all this advice has decided that everyone else is wrong and he is right.the advice was a ludicrously complicated workaround. I don't expect to have to pay through the nose for software which then needs to be customised to perform simple functions
GaryLakeFree MemberDon't use adjustment layers, the whole point of them is that you can tweak them later rather than commit. If you then want to save as jpeg you have to flatten them before it can save as a jpeg.
So just use normal adjustments (Image > Adjustments) and you shouldn't be bothered with having to go through the save prompt.
If you don't want to use a PSD fine, but don't expect to be able to use all of Photoshops features properly. It's like you're saying photoshop sucks because jpegs don't support all the lovely tools they've created.
glenpFree MemberI can't believe you're still going! Can't you see you're only half doing it right? If you use layers you are making something other than a jpg, so you then have to build a jpg again.
You can do all of the alterations you described the quick way, and re-save the jpg just exactly as you want to do. Its just that you don't know how to, or a are being willfully stupid.
Don't know how much more simple it could possibly be. It only appears to not work in a simple way because you are doing it wrong! If you want to edit a jpg and do a straight save then don't put non-jpg features (layers) into it.
GrahamSFull Memberit suddenly assumes (as do most
you really meantIt doesn't "assume" anything. By choosing to save the file as a 8-bit single layer JPG, rather than the standard multi-layer PSD you have EXPLICITLY told it that you would like to flatten and commit all your changes into a new file type.
about once a month.The point of non-destructive editing is not just that you can throw ALL your changes away and get back to the original image, but that you can tweak the changes you have already made:
eg you might take an image, do a normal capture unsharp mask, fix the white balance, adjust the levels, straighten and crop it, convert to sRGB, do output sharpening save and print it.
If you then decide that the resulting image is still a little cool then you can re-open it, alter the white balance in your second step and leave the rest as they are.
glenpFree MemberA great trick is to use layers to do High-Pass sharpening and localised contrast. Means building one or two new layers, and takes time to learn, but its a really powerful move once you've got used to it. Naturally, you can write an action to create the necessary additional layers and set them up with a good first guess for settings.
GrahamSFull MemberI'm going to try a nice software metaphor:
Start Microsoft Word
Open a plain text document
Make some text bold, add some headings and a diagram
Now try saving it back as a plain text diagram…Stupid Word complains. Says it will throw away my formatting if I save as plain text. That's ridiculous eh? 🙄
MrSmithFree MemberI don't expect to have to pay through the nose for software which then needs to be customised to perform simple functions
"simple functions" this is why you don't need photoshop.
there must be other software out there to do the basic tasks you require?glenpFree MemberOne more go, for the hard of understanding:
Open your pic.
Rotate canvas (image menu).
Adjust Levels if desired (shortcut is L)
Adjust curves if desired (M)
(Or, if that is too confusing use one of the other contrast adjustment tools, they all are different ways of doing the same thing)
Are you sure you like it?
Save (S)Until you close the file the History line lets you undo anything you like.
GrahamSFull MemberAnd if that is all your doing then as MrsMith says, you are wasting your money on full Photoshop. Try paint.net, Elements, Paint Shop Pro, Gimp – all of which are free or considerably cheaper.
Or use CaptureNX which is hundreds of pounds cheaper and (IMO) has better support for that kind of basic non-destructive editting of Nikon NEFs.
NorthShaunFree MemberHa! Programmer meets end user!… Irresistable force meets an immovable object! A very good friend of mine, and veteran fellow photoshop user of several years summed this up perfectly using the following acronym….
"Its a PICNIC error, Problem In Chair, Not In Computer! "
GrahamSFull MemberAlso called a PEBCAK:
"Problem Exists Between Chair And Keyboard"
simonfbarnesFree MemberI open a .psd and select "save for web…" and get:
on a machine with at least 2GB free (bearing in mind Photoshop is using 900MB to edit a single image). No link to help to explain what this means or how to fix the problem, no tick box to say "don't show me this again"so then I close the file, having only saved a reduced jpg version, and it says "do you want to save your changes ?". But I haven't made any changes, so it isn't protecting me from anything, just some lazy programmer seems to have assumed that any action modifies the .psd. I checked and it doesn't even save the reduced size I used, so if I go back and try again it has jumped to full size again 🙁
LuckyJimFree MemberWhat are the pixel dimensions of your image?
The warning pictured has nothing to do with computer performance – and everything to do with a sense of propriety and respect for web audiences/bandwidth.
simonfbarnesFree MemberWhat are the pixel dimensions of your image?
4288×2848 like every other shot from my camera
but at the time the warning is displayed it does not know the final size because it hasn't given me the opportunity to tell it, unless you think it is able to anticipate my choice using telepathy ? FYI it always assumes full size…
LuckyJimFree Member"4288" har-de-har.
No. Save for web is not a tool to alter the pixel dimensions of an image. As I said before, it's an optimisation tool, allowing fine control over compression settings and colour palette.
What size is your screen? I would guess perhaps 1024 x 768 pixels?… then why in the name of f00k would you -or anyone else – want to look at an image on a website where you could only see 1/16th of the content at any given time?
Think about it. No, really… THINK. Please.
simonfbarnesFree MemberSave for web is not a tool to alter the pixel dimensions of an image
so why does it contain boxes to specify the dimensions? And surely since most web images will be smaller than the original, it should ? I draw your attention to the boxes bottom right which allow choice of dimensions and compression method – are these just to kid novices to the program ?
1920×1200
. then why in the name of f00k would you -or anyone else – want to look at an image on a website where you could only see 1/16th of the content at any given time?
indeed not, which is why one normally reduces the size…
LuckyJimFree MemberMy mistake. I don't have CS5. Must be a new feature.
Novices such as myself are obviously lagging far behind. There is nothing I can possible teach you.
Good luck with everything. Toodle-oo.
simonfbarnesFree MemberMy mistake. I don't have CS5. Must be a new feature.
it goes back to CS3…
GrahamSFull MemberIt does seem odd that it complains about memory. I agree that it shouldn't be an issue.
My best guess is that the Save For Web thing might be written as some kind of plug-in and may not have access to all the working memory pool that Photoshop uses so may genuinely run low on the memory it can access.
Or maybe it's just a bug? Possibly left in from when you had to resize before doing the Save For Wen thing.
simonfbarnesFree MemberMy best guess is that the Save For Web thing might be written as some kind of plug-in and may not have access to all the working memory pool
except an actual plugin can load a 14761 x 2366 panorama without complaint ?
MrSmithFree Memberi would have thought that 'save for web' would be sRGB (or untagged) and have a different compression logarithm optimised towards smaller file size and smaller image dimensions.
if you wanted to make an image smaller you would re-size the image (apple>shift>I) and choose the resolution/dimensions/DPI/sampling method etc.
this would leave your profile intact and be re-editable by using history/snapshot or just saving a copy.no idea about the memory error, get a programmer who knows about computers to sort it out.
simonfbarnesFree Memberif you wanted to make an image smaller you would re-size the image (apple>shift>I) and choose the resolution/dimensions/DPI/sampling method etc.
this would leave your profile intact and be re-editable by using history/snapshot or just saving a copy.so you mean I should ignore the tool designed for the job and do it a different way ?
that's not how it works, the Adobe programmers have to fix it.
GrahamSFull MemberA quick Google on the Adibe forums seems to suggest that the warning appears when the image is over 3374 x 2241 pixels.
http://forums.adobe.com/thread/369681I guess the Save For Web thing does have a 4-up display so it may theoretically need 4 times the memory of the main image.
But I still can't see any good reason for that dialog on a machine with plenty of RAM.
simonfbarnesFree Memberyeah, thanks for the link, it looks as if it may be a hangover from previous days when images that size were too big to handle, but is symptomatic of inadequate testing if it's been left in.
Of course, that doesn't address the fact that using the tool makes PS think the original has been changed…
Another question, how do I create my own toolbars to perform custom functions ?
MrSmithFree Memberso you mean I should ignore the tool designed for the job and do it a different way ?
possibly yes. photoshop offers different ways to do similar things.
i can think of 4 different ways to sharpen an image, none of them is the 'correct' way but all have their uses and advantages.
the save for web facility is just one interpretation of saving a jpeg for web use. that interpretation of what constitutes a web jpeg may not be what other people want.
(personally i want to control the sharpening and resampling method when making small jpegs from large files as they can get too sharp/brittle looking with some subjects)simonfbarnesFree MemberJeez – colour balance ?? The tool applies to shadows, midtones or highlights, with no option to select all at once. And it's not calibrated in colour temperature, and there's no button to reset to original 🙁 I'm partially colourblind, but I can usually drag a single slider to get the colours about right, but THREE of them ??
NZColFull Membern fact is should carefully and silently save all your work unless you click a thing saying "Throw all changes away I've changed my mind" – with me this would be about once a month.
I wrote an app once that did this as its default action. USers fckn hated it and after what i would consider hate mail i changed it back to what they 'expected'
Oh crap I seem to have just agreed with Sfb. Bugger. 😆
GrahamSFull MemberJeez – colour balance ?? The tool applies to
calibrated in colour temperatureYou generally do the white balance thing during conversion from RAW/NEF, where it will be labelled in temperature.
Doing it after the fact to a JPG isn't really the same thing at all.
singletrackhorFree MemberWhat manual/tutorial for a partially colourblind engineer who wants to redesign the interface of the most popular image manipulation program? 😉 🙂
This might not be correct. but isnt the compression settings from save for web stored in the psd, so by altering the settings in save for web, youll need to resave the psd or discard the settings.
Those 3 different colour balance settings are for fine tuning, try variations or auto color instead.
own customised toolbar 😯 , not sure Ive been using the one provided by adobe since 1992.
An image that size will slow the computer down when saving for web, 2gb ram aint much when processing a 950mb image, save for web is effectively taking a huge 300dpi raw image, scaling and compressing 4 different versions of it.
hth
MrSmithFree MemberJeez – colour balance ?? The tool applies to shadows, midtones or highlights, with no option to select all at once. And it's not calibrated in colour temperature, and there's no button to reset to original I'm partially colourblind, but I can usually drag a single slider to get the colours about right, but THREE of them ??
again multiple ways of changing colour. through curves(RGB channels), adding a photo filter (80A etc) hue/saturation, channel mixer,
photoshop assumes you are already aware of how additive/subtractive colour works and how the 80-82 85-81, red/green cc filters work etc.
a °kelvin adjustment is usually done when processing the raw.
you could also argue the other way, if the colour balance was global. why can't you adjust the highlights and shadows separately?it's far more useful to have highlight/midtone/shadow controls.
glenpFree MemberYet again you are essentially complaining that you don't know how to use the software. Colour Balance is only one tool for adjusting, er, colour balance. Other methods (curves for example, or hue, levels and more) do amend the full range of tones simultaneously. You need to find the one that suits you – I would suggest something but clearly you have no intention of listening.
In that save for web dialog screen grab you are still showing the image's original size. Are you saying it gives you a memory error even when you enter a more appropriate pixel dimension in the fields? What pixel dimension are you asking it to reduce to?
Yet again we come back to the beginning – your OP title is simple Photoshop question, but you don't have questions really (at least you are totally unwilling to listen to the answers that have been helpfully provided). You just want to piss, moan and troll. If you can think of something you want Photoshop to do, it will do it. You will, however, need to find out how it works first.
GrahamSFull Member2gb ram aint much
when processing a 950mb imageWell no it wouldn't be, but Simon has 6GB of RAM and is seeing that message when doing "Save For Web" on a normal 4288×2848 photo from his camera, which will only be a couple of MB.
So why is there an issue?
MrSmithFree MemberSo why is there an issue?
dunno. but i doubt any prefs have been changed regarding cache/history states/scratch disk/graphics redraw/compression when saving/ amount of ram allocated to photoshop.
all of the above affect saving/working speed.NorthShaunFree MemberWhat GlenP said!
Why don't we all start a thread ridiculing programming language, illustrating our total lack of knowledge of the subject?….. "why oh why can't they just use plain english?"
The topic ‘Simple Photoshop CS5 question…’ is closed to new replies.
