Seemed about right for me.
86kg + bikes (think I put 92kg and 96kg for road and gravel bikes)
27mm road tyres 80-85psi
37-41mm gravel tyres ~35 psi.
Generally I would probably go 85-90 psi on the road bike simply because any less than that sometimes feels vague when cornering. But then the calculator doesn’t know if my 27mm tyres are Schwalbe pro ones (they are) or Schwalbe Marathons (which would probably ride just as well without any air they’re so stiff).
Offroad, 35psi in the gravel bikes seems about right. I go lower in winter and higher in summer, like the road that’s more to do with the tyres not squirming than chasing grip. I run a foam insert in the rear wheel but don’t feel it bottom out on the rim unless I’m running ~25psi.
No, I’m not going to give them my personal details so they can sell them to spammers.
It doesn’t check it, just put DomCummings@number10.com
