but its worth noting that they rely on 11/12 speed HG spacing, which is different to 10 speed HG spacing (the length of the casette body is longer)
Not it isn’t. 12 speed HG MTB cassettes use the same freehub size as 11/10/9 and 8 speed MTB cassettes. 11/12 speed road HG use a wider freehub but you can use a spacer to run an MTB cassette.
All types of MTB 12 speed gears (Shimano and SRAM) will work with a HG cassette, but your cassettes options will be limited to lower end SRAM or a multitude of smaller manufacturers, check out eBay for a variety of options.
As long as you can fit an 8+ speed MTB wheel into your frame, there’s nothing stopping you going 12 speed if that’s where you want to be.
Cue a line of people telling you that 10 and 11 speed are cheaper and just as good! :-)
